Question about Lexmark X1270 All-In-One InkJet Printer
How do i photocopy an identity card on both sides?
Advise on the right steps to be followed.How do i refill the cartridge-my place doesn't have a service center around.
    President:
  • 2,692 Answers
You photo copy on both sides by turning it over and placing it in a different position and put the first side paper back into the top of the paper tray. As for the second inkjet cartridges are not intended to be refilled but replaced . You can obtain replacment ones but having the model number and either ordering on line or at any office or computer supply  store.
Posted on Dec 27, 2008
Ink light and paper light keep flashing alternately on my epson l110, how can i fix this ?
It may be a paper jam error. I find when you use an old or rough page in your printer, it don't properly go to its way and cause to displace a sensor that is situated at under the Head carriage of this printer which can be seen in following pictures.
Solution: check if this problem is occurred after paper jam then check the sensor is on its proper place or not if not then open the printer upper cover, open the lock of carriage rod from both sides. Set the sensor at its proper place and then check it.
Apr 17, 2015 | Epson Workforce 1100 InkJet Plotter...
We just replaced the water filter cartridge for our Kenmore refrigerator (model # 25352649305). The new cartridge was easy to install but doesn't stay locked in place. As soon as we go to use th
Pull the new cartridge out and check it side by side with the new one. make sure they are identical or that there are no tabs to pull off before install.
Please mark this as helpful if I helped to solve your question.
Dec 14, 2017 | Kenmore Refrigerator Replacement Water...
I have try to print but its not printing. i've allready fill the ink still the page come out blank.
It could be due to the refilled cartridge that you are using. Refilled cartridges tend to degrade print quality and cartridge performance.
You can try to clean the cartridge nozzles. Please follow the steps below to fix the problem:
  1. On the printer control panel, press Copy.
  2. Press Options until Maintenance is highlighted.
  3. Press the right arrow until Align Cartridges or Clean Cartridges appears, and then press Select. A test page will then be printed forcing ink through the cartridge nozzles and clean them.
Try to print your document again to verify that the cartridges are working.
If that doesn't help, I would suggest you replace your cartridges with new genuine Lexmark cartridges.
Aug 17, 2011 | Lexmark X6150 All-In-One InkJet Printer
How do I replace my ink cartridges on my epson sx425w ?
Follow the below mention steps:
1.First you should make sure you get the correct ink refills. You can order them online, or pick them up at your local office supply store.
2.Go into you MY COMPUTER icon on your desktop, click on change a setting, click printers and fax, and then right click on your Epson printer. Go into properties, then maintenance.
3.Next, click on the refill or replace ink cartridge. It will then move the printer ink refill into position on the printer. Lift the cover and remove the old cartridge.
4.Take the tape off of the new ink cartridge, and snap it into place with the matching color. Close the cover, and push the button on the printer that is blinking. It will take a minute, but should move the ink back into position.
5.On the computer screen, follow the on screen directions. You can then click finish.
Jun 26, 2011 | Computers & Internet
I have the 1522 printer. The toner ran out and I refilled using Chinese toner fron Deal Extreme. Black toner leaked out the right hand side of the toner cartridge messing up printing. I tried refilling...
I would not advise you to refill a toner cartridge becausethe toner powder is very fine and you do not want to breath in this tonerpowder. You may be able to print a few more pages by removing thetoner cartridge and shaking the toner cartridge in a horizontal position a fewtimes and then placing it back into the printer. This will give you an opportunity to print a few more pages and giveyou time to purchase a new toner cartridge for your printer. A cheaperalternative is to purchase a re-manufactured toner cartridge for your modelprinter. A re-manufactured printer cartridge also replaces worn partsas well as refilling with toner powder.
Mar 25, 2011 | Office Equipment & Supplies
Hp laserjet 1100 toner catridge refill?
Hi follow these steps..
1.Purchase a refill kit for your model of printer. It is important to purchase a refill kit designed for your specific model, since generic refill kits do not work well with HP printers. There are a number of places to buy these kits, but you must make sure you get the right kit for your printer model
2.Take the toner out of the printer and clean it carefully. Over time toner cartridges will accumulate paper dust, dried toner and other debris, and all of this must be cleaned away before the cartridge is refilled.
3.Flip the cover out of the way to expose the developer roller, then use a soft clean cloth to clean the roller. It is important to clean this roller before refilling the cartridge.
4.Make a small hole in the toner cartridge, using the instructions provided in the refill kit. It is important to follow the refill kit instructions carefully, since the toner refill process will vary from model to model.
5.Place the replacement toner in the hopper, then carefully pour it into the HP cartridge. Be careful not to spill any of the toner, and if you do spill the toner be sure to clean it up promptly. Reseal the hole you made after the cartridge has been refilled.
6.Sit the refilled HP cartridge on a clean flat surface and let it remain there for 20-30 minutes. Pick up the cartridge and make sure no toner has leaked out. If you do see any leaks you will need to reseal the hole you made again.
7.Pick up the cartridge and make sure no toner has leaked out. If you do see any leaks you will need to reseal the hole you made again.
Good Luck & cheers:-)
Jun 30, 2010 | HP LaserJet 1100 Printer
Cartridge Errror
How to Reset an HP Inkjet Cartridge
Hi there
Instructions
Things You'll Need:
Adhesive tape
HP inkjet cartridge can be refilled easily, getting it to work again in the printer is another matter.
The contacts on the back of the cartridge are programmed to read the ink level, but they don't reset for the printer just because you add more ink.
You must get the printer to recognize the cartridge as new.
You can do this easily if you have two other old cartridges, or you can manipulate the contacts on the refilled cartridge.
Step 1
Insert the cartridge you refilled into the HP Printer.
Have the printer print an alignment page, thus recognizing the cartridge. The printer will still read the ink level as where it was before you refilled it.
Step 2
Remove the cartridge from the printer and replace it with another old cartridge.
Have the printer print an alignment page with this cartridge so it recognizes it as a different cartridge from the first one.
Step 3
Replace the second cartridge with a third one and run the same alignment page.
Because the printer only retains the memory of two Print Cartridges, it will erase the memory of the first (refilled) cartridge.
Step 4
Insert the refilled cartridge into the printer.
The printer will now recognize the cartridge as being full.
Next Steps
Step 1
Tape over the contact squares on the top left corner of the cartridge's contacts. Insert the cartridge into the printer and run an alignment page. Ignore any messages that might appear saying there is a problem with the cartridge.
Step 2
Take the cartridge out of the printer. Remove the tape from the left corner and tape over the contact squares on the top right corner. Place the cartridge backs in and run another alignment page.
Step 3
Remove and reinsert the cartridge, this time with no tape on any of the contacts. Check to see if the printer recognizes the cartridge as being full.
Step 4
Repeat the above steps if the cartridge is still shown as being empty.
This time, use the bottom corner contact squares instead of the top ones. If you are still unable to reset the cartridges, using multiple cartridges is likely the only way to do it.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); All I ask is to call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Mar 05, 2010 | HP PSC 2355 All-In-One InkJet Printer
I need to change the ink in my printer, Epsoon
hi friend,
step 1
First you should make sure you get the correct ink refills. You can order them on line, or pick them up at your local office supply store.
  • Step 2 Go into you MY COMPUTER icon on your desktop, click on change a setting, click printers and fax, and then right click on your epson printer. Go into properties, then maintenance.
  • Step 3 Next, click on the refill or replace ink cartridge. It will then move the printer ink refill into position on the printer. Lift the cover and remove the old cartridge.
  • Step 4 Take the tape off of the new ink cartridge, and snap it into place with the matching color. Close the cover, and push the button on the printer that is blinking. It will take a minute, but should move the ink back into position.
  • Step 5 On the computer screen, follow the on screen directions. You can then click finish.
  • jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); Tips & Warnings
    • Have the new cartridge before your remove the old one.
    • Contact epson if you have any questions.
    hope this helps u
    please rate me..........................
    thank u for using fixya
    regards
    sivaranjini
    Nov 25, 2009 | Epson WorkForce 600 All-In-One InkJet...
    Refill Process of Samsung Toner
    Dear sir,
    1. open your printer cartridge drum cleaning blade unite wast toner clean.
    2. open two side from your cartridge left side and right side
    3. open plastic cork
    4. filling toner
    5. assembling again
    6. start print
    Aug 19, 2009 | Office Equipment & Supplies
    SHarp Z-20 home photocopier toner refill- Manual?.
    There is a small door at the right front, unlatch from the top, open the door and unlatch the green tab on the cartridge and pull the cartridge out.
    Mar 17, 2009 | Sharp Office Equipment & Supplies
    Lexmark X1270 All-In-One InkJet Printer Logo
    59 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    mukhtar21 shaikh
    mukhtar21 shaikh
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
