Question about Nikon D50 Digital Camera with 18-55mm Lens
I want the On board Flash to turn on manually
  • ejvicioso Jan 27, 2009
    Under low-light conditions the flash pops up but it does not flash when the picture is taken.
    Scholar:
  • 48 Answers
If you operate the camera in green Auto mode you don't control the flash, it controls you. Choose any other exposure mode (P is good if you normally use Auto) and the flash will only pop up when you press the release button on the side.
Posted on Feb 07, 2009
Flash off, no flash
I had exactly the same problem, very annoying.
The camera does not need a new tube, transformer or flash board, it only thinks that you are in the wrong mode and won't let you turn on the flash. Do the following to avoid the problem:
1. Touch "menu" then under the "rec mode" change from Burst to NORMAL.
2. Touch the flash icon and now it will be possible to turn the flash on...
May 26, 2010 | Sony Cybershot DSC-T200 Digital Camera
Sony Cybershot DSC-W55 Flash Error Code
1. Turn OFF cam
2. Remove the battery or the power supply
3. Turn the switch to CAMERA for about 30 sec
4. Turn the switch to OFF
5. Install the battery or power supply
6. Turn the switch to MEMORY
7. Open the LCD cover and press the RESET button ( small inner button )
8. You will be prompt to adjust date/time. Do it
9. Take some pictures
Mar 24, 2008 | Cameras
How can I turn the flash off on a cannon power shot a400 camera
Your menus will have options to be able to turn off the flash in certain modes.
The camera also has external buttons which will turn the flash on or off. Read your user manual.
The button which has the SET inside has four selectors. The right selector has a flash on/off button to turn the flash on or off. The flash usually will flash when set to flash all the time and not in AUTO mode. The AUTO mode may not allow you to turn off the flash. You probably have to choose another mode to allow the flash to be turned off.
If you do not have a user manual, here is a link to a free pdf download: User manual Canon A400
Nov 06, 2009 | Canon PowerShot SD400 / IXUS 50 Digital...
95 Maxima Pulling Codes
pull the little black cover off on the floor board next to the gas pedal, the silver box is the pcm the screw you see on the side there is what you turn, 1st turn the key on ,then turn the screw all the way to the right , wait 2 seconds then turn all the way back , the check engine light will flash slow for the first half of the code then flash fast for the second half for example 3 slow flash then 3 quick flash would be code 0303 , it may flash 10 slow and 5 quick that would be code 1005 and so on
Dec 21, 2008 | 1995 Nissan Maxima
Flash off
Remove the camera case (about 10 screws) and expose the circuit board that is attached to the camera chassis. Look at top button board (shutter and video buttons). This is also the flash board. The capacitor is attached to the board. The flash board has a serial cable and two wires that connect to the main circuit board. Severing one of the wires will stop the flash from working. After re-assembling the camera, the camera will not take pictures with any of the flash settings. You will see a constant charging flash message every time the shutter button is pressed. Turn off the flash setting on the camera for your camera to operate.
Nov 08, 2008 | HP Photosmart M425 Digital Camera
Kodak flash circut, need one, maybe a manual to show how to replace
Kodak will not sell the service manual or any replacement parts to non authorized contracted service reps.
Most of the fixes in these cameras is replacement of boards. They do not support component level servicing.
Jerry G.
Jun 10, 2008 | Kodak EasyShare Z650 Digital Camera
Frozen on one setting
Try this site and follow the photos.
It worked for me.
327093-how-repair-canon-speedlite-580-ex-dupa-ce-vibreaza-capul.html
May 26, 2008 | Canon SPEEDLITE 580EX TTL Flash
FLASH UNIT WON'T FIRE
Those Xenon flash tubes last for a long time. You likely need a new flash PCB (printed circuit board). Typically, the trigger coil is at fault when you get the ready light but no flash
Feb 08, 2008 | Nikon D50 Digital Camera
Need diagrams for a Vivitar 285HV Flash
I had the same problem on a new 285HV flash. I pulled it apart and found a blown resistor and track in the head of the flash.
The flash was fairly easy to pull apart, there is a clip hiding behind the blue disk, the rest is just screws.
There are 3 circuit boards, two in the base and one in the head.
The blown resister is in the head and is the large resister next to the violet wire. From the edge of the board there is R22 brown-black-brown, two diodes, another resistor yellow-violet-brown and then the one that died.
I have the service manual for the flash and it is titled 285/285HV but the circuit board in the service manual and in the flash are different.
After much studying of the circuit diagram I believe the value of the resister is 12K 2watt (90% sure, if not it is 10K 2watt).
I replaced the resistor with the 12K and was able to use the extra length of the leg of the resistor to bypass the blown track, used some heat shrink to insulate the leg from shorting out with the board.
I have tested the flash and it is working but I have not used it extensively.
Disclaimer: this board is right next to the capacitor, you don't want to touch it if it has a charge. Use a multimeter to check.
I bought the resistor from here: www.digikey.com Part No. P12KW-2BK-ND $0.206 (min order 5 still only a $1.03)
Good luck and remember I am not an electronics tech and your problem may be different to mine.
Richard
Jan 07, 2008 | Vivitar 285HV Flash
Panel resets
Hi Tim, there was a service flash out on this model which has to do with the circuit board in the dispensor. Frigidaire has redesigned this board causing your problems. This should be covered under this service flash. The number of the service flash is 46-470. The solution is to replace the water filter and dispenser board. Contact Frigidaire and inquire about the service flash. Refers that were included in this flash have the serial numbers between LA113---- to LA146----. If yours fall into this range you should be covered. Circuit board kit number is 240533603. Your model is included in this flash...Catriver..post back.
Aug 21, 2006 | Frigidaire PLRS267ZAB Side by Side...
Nikon D50 Digital Camera with 18-55mm Lens Logo
91 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
