Question about GE 27935GE3 Cordless Phone
"No Data" on Caller ID display
If my two cordless phones are in their cradles, incoming calls are shown as "No Data" on their Caller ID displays. But, if the phones are out of their rechargers when I've an incoming call, they provide the Caller ID information. How might I solve this?
  • 201 Answers
SOURCE: Ge cordless 900 mhz home phone
What is "Bell" and "Cogeco"? Did you change phone line provider companies? If so, you would need to ask them if it's possible to change. You are getting the information they are sending you. I do not believe the information is being altered by your phone.
Posted on Jul 07, 2007
SOURCE: Caller ID Problem on the GE2811 Twin cordless phone system
Still have not been able to solve the problem of having inconsistent caller id display when the telephone rings
Posted on Mar 24, 2008
SOURCE: No caller ID information for GE Caller ID phone ( Model # 29385GE1)
I must have gotten your unit. Mine did work ONCE after it had been installed for about a week. But it never worked again and we pitched it. Buy something else.
Posted on May 04, 2008
LilBit 4 U
SOURCE: GE 5.8 GHz Cordless Phone model # 25836 EE1-A
Press prog..then hit select and use vol to change time and date..I could figure it out, I am sure it will be a breeze for anyone !!lol Have a grrr8 day !! SpanishMoss001
Posted on Oct 15, 2008
SOURCE: how to activate caller ID after moving the phone
please tell me how to set up caller id on my 6.0 fusion
Posted on Jan 12, 2009
  • 54 Answers
SOURCE: Problems with GE 25952EE1 5.8 GHz Cordless Phone?
acctually there small cable is connected to the display so bettter poen it with help of some drivers and connect the cable it will work
Posted on Mar 15, 2009
0 characters
1 Points
All incoming calls say Private
Hi Helen,
Try disabling caller display. Prove that you have managed it and then enable it
Aug 03, 2015 | Uniden DECT 6.0 Cordless Telephone...
I live in the USA. My caller ID stopped displaying incoming calls. Last incoming call on the display says 12.2.14. Even when phone is ringing, caller ID does not display name, number,time,date,etc.
Call Phone Co and see if you are programed for the Caller ID feature. In some areas this feature cost more. Whether or not you are paying for it, it may not be programmed in their switch for you?
Feb 06, 2015 | Vtech 5.8GHz Cordless Phone with Digital...
Uniden cordless phone caller id quit working
Using the Caller ID and Redial Lists
Caller ID (CID) is a service available from your telephone provider that shows the phone number (and sometimes the caller's name) of incoming calls. Contact your telephone provider for more information.
Caller ID list
Redial list
When a call comes in, the phone displays the number and name (if available) of the caller.
The phone saves the information for the last 30 received calls to the
CID list.
When it's in standby, the handset shows how many calls came in since the last time you checked the CID list.
Each handset remembers the last 5 numbers you dialed on it. The redial list is separate for each handset.
Dec 02, 2012 | Uniden Cordless Phone
When there is an incoming Call, the display shows,
You must have caller ID provided by your local phone company for Call ID to work. This is an additional charge on your phone bill.
Feb 21, 2012 | Office Depot Ativa D5765 58 GHz 1Line...
Thanks for using FixYa. I think you have stored more than 100 Caller ID messages and hence the caller ID is not showing on Uniden Tru8888. In the following cases the caller ID will not be shown-
If you answer a call before the Caller ID message is received (for example, before the second ring), the Caller ID message will not appear.
When the call is received via a telephone company that does not offer Caller ID service, the caller’s phone number and name does not appear. (This includes some international calls.)
When the call is via a private branch exchange (PBX), the caller's phone number and name may not appear.
You may receive any one of the following messages:
When a private name is received; Private Name
When a private number is received; Private Number
When a unknown name is received; Unknown Name
When a unknown number is received; Unknown Number
When invalid data is received; Incomplete Data
The Caller ID list stores information for incoming calls - even unanswered calls. You can store up to 100 Caller ID messages and phonebook entries (including Speed Dials) for each handset and the base. You can view the Caller ID list through the handset or base during a call or when the phone is in standby mode.
Memory locations for Caller ID messages and Phonebook entries (including Speed Dials) are common, you can store up to all 100 entries for each handset and the base. Caller ID messages are not stored when you have 100 phonebook entries. When you have stored a total of 100 phonebook entries and Caller ID messages, the oldest Caller ID message is overwritten.
Please do rate the solution and revert for further assistance.
Aug 16, 2009 | Uniden Cordless Phone
Caller id is not working
If the caller ID in displaying "Incoming call" either you have not subscribed to the service (caller ID to be pushed to your phone) or you are using a US type phone in UK type countries.
There is also a possibility of Caller ID memory in your phone full, in case it does not overwrite last records by new ones.
Dec 05, 2008 | Uniden Cordless Phone
Uniden CXA15198 not showing caller id
Hi! There is a small device available in the market which is a converter. By connecting this between landline and phone, caller ID start display simply.
It cost to me Rs.450/- made by Fintel. Try to get it cheaper at your place.
Try this and the problem is solved.
Apr 08, 2008 | Uniden CXA15198 Twin Corded/Cordless Phone
Not sure it this is a solution for ALL your problems, but...
I had a similar issue: Phone rings, caller ID info displays then seems to hesitate, then displays only "INCOMING CALL."
The issue seemed to be caused by interference with other devices on the same line (in my case, an alarm system).
Tech support had me change a setting on my TRU9466 base unit (this is one of the PowerMax 5.8ghz models). This is how we did it step-by-step on the base unit:
select LINE 1
switch to TYPE B
This seems to have solved the Caller ID "interference" issue -- my Caller ID now displays as it should. The Tech Support person suggested trying that TYPE A/TYPE B setting on "OFF" if TYPE B didn't solve the problem, but thankfully, it did.
Now Cheryl, it sounds like your issue is more involved than this -- I didn't have any connection problems -- but perhaps they're related -- you might try my solution.
Mar 07, 2008 | Uniden 5.8GHz Cordless Phone
Caller id
This means the person who is calling you is hiding his number from caller IDs. There is no problem with your caller ID.
if you try and call your phone from a mobile phone and you type #31# and then your phone's number you will see that the number of your mobile will not be displayed. (#31# service must be provided by your mobile company)
Please rate this solution as "Solved" if you are satisfied, otherwise please ask again here.
Thank you :)
Oct 11, 2007 | Uniden Cordless Phone
GE 27935GE3 Cordless Phone Logo
598 people viewed this question
Top GE Phones Experts
Are you a GE Phone Expert? Answer questions, earn points and help others
