Question about Dishwashers
Detergent tablet didn't dissolved - Dishwashers
  • 750 Answers
Welocme
If the tablet did not dissolve this means either your soap dispenser door did not open, or your water is not hot enough. let the hot water tap run till it comes out hot before starting the dishwasher.
Thank you for trusting us with your questions.
Please remember to leave a solved rating before you sign off. Huum
Posted on Dec 22, 2008
  • 19,396 Answers
This canhappen because either the water is not being sprayed with sufficient power,or because the water did not reach sufficient temperature , or for both reasons.
Ensure that the spray arms are not blocked, check that the inlet the pump is working, and try to find out if there is also a problem with water temperature.
Dishwasher tablet does not dissolve so crockery not clean
Are you using a rapid wash program, ie 30 minutes total?
if you are, put the tablet in the cutlery basket, not the soap dispenser. The wash time is very short on the 30 min program, so putting it in the cutlery basket gives it more time to dissolve.
Other problems might be problem with water level, (should be just above the filter but below the lip of the wash tank), pump not working or the spray arms not turning - (check the angled jet at the very end of the spray arm for blockage by food particles).
Feb 04, 2018 | Dishwashers
Think the element or thermastate has gone as it's not disolving the tablets can I fix it myself
One of the first things to check if the dishwasher detergent is not dissolving is the water temperature that is in the dishwasher. If the water temperature is too cold, it may not be able to dissolve the tablet effectively. . If it is below 130 degrees Fahrenheit the setting needs to be increased or contact a plumber for assistance.
Read more : http://www.ehow.com/info_8597080_dishwasher-tablet-not-dissolving.html The Dishwasher Tablet Is Not Dissolving eHow
Nov 18, 2015 | Dishwashers
Detergent tablet not dissolving.
sometimes the dispenser doors are not designed for tablets, and they don't let enough water in to dissolve them....next time you wash; put the tablet in one of the silverware compartments....should do the trick. and leave the dispenser door for liquid detergents only.
if this is helpful please click the correct button. thanks
Jan 22, 2010 | Zanussi Dishwashers
Dishwasher 3 in 1 detergent tablet not dissolving.
I believe that the instructions for using these 3-in-1 tablets is to place it in the open dish detergent cup, rather than in the closable compartment, since the tablet needs to get doused by a lot of water in oder to fully dissolve and be effective in getting the dishes clean.
Since the tablets are designed to dissolve more slowly, they are able to be used for the entire range of washing cycles. If it's a constant problem and you don's have an open detergent cup below or next to your closed detergent dispenser, just toss it into the bottom of the dishwasher instead.
The reason that the tablet isn't getting dissolved fully is because the door is preventing the tablet from dropping all the way out and the door is shielding the tablet from quite a bit of water spray.
Another option is to take a look at your owners manual for the dishwasher and see if they recommend these all-in-one tablets versus regular powered detergent and liquid rinse aid.
Hope that helps and best regards!
Jul 31, 2009 | Electrolux Dishwashers
Neff S5433 Dishwasher - Detergent tablet not dissolving
Hi!
Please run the machine without detergent for 2-3 washes. Also try using a little hot water. Also, don't used cleaner and softener together but add softener on the last rinse.
Feb 22, 2009 | Neff 24 in. S5456 Built-in Dishwasher
Tablet falls out & doesn't dissolve especially on fast cycle
Hi and wlecome...
You should not use anything other than powered dishwasher detergent in these products. They are not designed for tablet-style detergents. The reason is because the dispenser does not "open" during the wash cycle like you would see on a conventional dishwaser. The incoming water pours over the detergent and releases the mixture out the bottom of the dispenser. If you need a user guide, you can get one here: http://fisherpaykelparts.net/index.php?blockitemid=29
Jan 22, 2009 | Fisher and Paykel 23 in. DS603H W Built-in...
Tablets not dissolving
either there is not enough water (check water valve) or the pump filters are clogged (check and clean as necessary)
Jul 06, 2008 | Maytag 24 in. MDB8600AW Jetclean II...
Detergent
the tablet is dissolved by water spraying onto it from the spray arms.
check all the jets in the spray arms are clear
Jul 05, 2008 | Ariston Technologies LI640S Dishwasher
Tablet door dosn't open during cycle
It sound like a detergent cup issue (the door doesn't open at time) A very simple test for it is to place a tablet on the bottom of the dishwasher for a full cycle and to see what happen to the tablet. In case the tablet will be dissolved : - The detergent cup can become clogged with old dried detergent that prevents it from opening at time. Sometimes just cleaning the cup takes care of the problem. - The detergent cup opened by a bi-metal switch or a wax motor located inside your dishwasher door(behind the detergent cup). If cup's cleaning will not solve the problem, you should replace the bi-metal switch or the wax motor (depend which of them is used in your machine). Good luck !
Jul 02, 2006 | Hoover 24 in. DT999 Free-Standing...
Dishwashers Logo
325 people viewed this question
Top Dishwashers Experts
Mike
Marvin
Marvin
