Technical Support, Instructions, & Repair Service
Ask our Experts
Ask
Find a Solution
Most Common Problems for:
Scanner locked
shyam_person on Dec 22, 2008
my multifunction xerox workcenter m15i showing scanner locked. how to solve this problem
Sponsored Links
I have a similar problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Same Problem
Apr 14, 2009
-   Hey thanks a lot, it definitely helped. -   Guest
Best Solution
posted on Dec 22, 2008
Very Helpful)
tryit
Rank: Guru  Xerox ExpertXerox Expert
Rating: 88%, 1084 votes
There is a lock that has been hit and has the scan lamp locked.
Where to look is on the botom of the scanner. Look in where you remove the copies, on the bottom of the scanner you will see the only green part there, it is about 2 inches long and a half inch wide.
Turn the machine off, reach in and push the latch full IN, toward the back of the machine, then pull it our toward you until it snaps into place fully forward, It may be a little tight with it against the lamp carriage, but once you get it latched forward it will return to normal.
That latch is easy to hit when you are removing your copies from the tray.
Was this helpful?
Yes
No
4 people thought this was helpful
Related Problems
We have a Xerox 4150 that we use to scan to email a lot. Out...
my multifunction xerox workcenter m15i showing scanner...
Can you Help with these Printer problems?
No Vista driver available and when...
Solve
No Vista driver available and when computer reboots, printer will not print.
I wish to read the total copy count...
Solve
I wish to read the total copy count on Xerox WorkCentre M15i
Xerox m15i Scanner Won't Work
Solve
I enter CREATE PDF FROM SCANNER. Select XEROX M15WORKSERIES. ERROR MESSAGE : CANNOT BE SET TO THIS... (More)
Try to use scanner error says failed...
Solve
Try to use scanner error says failed to connect. I have deleted and added software etc. issue does... (More)
i use xerox M15i printer.i used...
Solve
i use xerox M15i printer.i used xerox pe 16 before.i could use zoom action from pe 16 but i cant do... (More)
Sponsored Links
Describe your Printers problem:
Top Printer Experts
Rank: Guru Guru
Solutions: 2826
Experience: I have yrs of experience dealing with many situations.
Ask Me
Find more Printer Experts
Top Printer Repair
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Repair & Parts
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
