-   How do I update the device driver for OSX 10.5? I wrote Sony's technical support who merely wrote back to say it won't be supporting OSX 10.5 and good luck. Great. So what do I do with a perfectly good scanner? Throw it in the trash?
-   sylvestag
May 09, 2008
-   I need a driver for windows xp -   kblack54
Apr 18, 2008
-   i cannot install the scsi controller-   wans
como eu faço para conseguir o cd de instaloação do scanner hp scanjet 2200c; para xp.
Solution #2
posted on Mar 18, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I lost hp scanjet 2200c CD
Solution #3
posted on Feb 13, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
dsf
Solution #4
posted on Aug 08, 2005
Charlie - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
Driver software tells a computer how to communicate with and control peripheral devices, such as scanners and printers. Upgrading to a new operating system or other software may cause conflicts with existing drivers. Sometimes device manufacturers create new drivers, which can solve problems when installed. 1. Figure out which driver version you currently have. On a Windows computer, right-click My Computer and click Properties; select the Device Manager tab. Click the plus sign to the left of a specific device to find the drivers that are currently installed for it. On a Macintosh, use the Apple System Profiler program to check driver versions. (If the Profiler doesn't list a device, check the Extensions Manager control panel.) 2. Find out whether a newer driver exists by visiting the Web site for the manufacturer of your device. A newer driver will have a later creation date than the one you have. 3. Follow instructions to download a newer driver. 4. Make sure you have the original drivers. If there are problems with the new driver, you want to be able to restore the old one. 5. Double-click the icon for the downloaded driver. 6. Follow installation instructions that appear. Look for a file named readme.txt or readme.doc. 7. If the installation didn't remove the old driver, remove it. On a Windows computer, right-click the driver in the Device Manager and select Remove. On a Macintosh, drag the old driver file out of the Extensions folder in your System Folder, and either save it elsewhere or delete it. 8. Restart the computer.
trying to install Nikon Super Coolscan 5000 ED, for some reason the installation disc doesn't have...
(More)
trying to install Nikon Super Coolscan 5000 ED, for some reason the installation disc doesn't have the LS-5000 ED driver software...? I am running Win Vista. Any ideas?
my mouse keeps freezing, after ive moved the mouse several times, but the computer will still carry...
(More)
my mouse keeps freezing, after ive moved the mouse several times, but the computer will still carry on any info i might be doing, then i have to switch off on the button
Message - the hardware has detected a problem. Try turning machine off and on. If this does not work...
(More)
Message - the hardware has detected a problem. Try turning machine off and on. If this does not work contact Nikon Service. Anything else i can do to fix the problem? For a whiole it still scanned images. But the thumbnail had vertical lines that were not in the completed scan. Later the colors sarted shifting to yellow. I stopped scanning
i am working on a very large scanning project. until recently things have been going swimmingly for...
(More)
i am working on a very large scanning project. until recently things have been going swimmingly for some reason now
my scans are not saving to my external hard drive
instead of saving with their titles when they scan
they just open as untitled images
what can i do to fix this?
please
Tool palette and layout tools palette won't open when I click on the Tools button in the control...
(More)
Tool palette and layout tools palette won't open when I click on the Tools button in the control area, or from View in the main menu. Progress window DOES open! What the !%!%!%??? Thanks for any ideas.
