Question about Garden
My lawn mower will not turn off
I have a rover mower with a briggs & stratten engine & cannot turn it off after startup
  • williedorsey Jan 18, 2009
    will start but stay running after i use it even if i remove spark plug wire.it a yard machine push mower 5.00 eng.
  • 211 Answers
Hi
From under the flyweel comes a wire(probably black).check it.It is connected with the off position of the trotle.
best regards savumihai71
Posted on Dec 22, 2008
How to hook up governor springs on a 3.5 engine
Google the Briggs and Stratten web site, it has all your answers.
Aug 21, 2014 | Briggs & Stratton Garden
Where is oil drain plug
On the right side of engine towards the bottom, a square plug
at the drain plug.
Aug 21, 2012 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
AIR FILTER briggs and stratten lawnmower
Yes the oil traps and holds the dust
Dec 28, 2011 | Toro Power Lawn Mower
I need a free copy (download) of a workshop manual to suit a Briggs and Stratten 375 petrol engine?
Workshop (repair) manuals are available for ALL of the Briggs and Stratton engines. They usually cost money though. The free downloads are only for the owner's manuals. You can do a search for Briggs engine repair manuals. There are many, many of them available.
May 22, 2011 | Garden
Lawn Mower wont start
You need to obtain a manual for Briggs & Stratten engines. All the info you need will be in it. The most common cause for non starting in these engines is "Tight Tappets" Wether it's an OHV or the old "L" head engine, because they rev and work so hard, the valves seat themselves deeper into their seat which reduces the valve clearance. There is no adjustment on the older "L" engines, so you have to remove metal from either the valve stem, ot the lifter itself. I have in the past done this in situ with a point file, but it is a tedious job. Otherwise you must remove the head and take out the valves and grind the stems. A tricky task and probably should be done by a mechanic.
Apr 06, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
I have a 17hp briggs and stratton vertical intek engine that needs the valves adjusted again. What are the adjustments for the valves?
adjustment with 4000 feeler gauge
adjust top valve when the bottom valve is fully compressed and than with the top valve fully compressed adjust the bottom valve the same way.
very easy But remember to losen the center tork screw before adjusting the rocker arm nut
Apr 01, 2010 | Parks Optical Briggs And Stratton Engine...
How much oil to put in a 6.25 briggs and stratten
They hold APPROXIMATELY 20 ounces. Put in around 18 oz and start checking the dipstick and adding a little until it gets to the full or MAX or whatever it says on your particular engines stick. Each time you ad a little, give it a chance to drain down or you will get a false reading
Sep 20, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
Garden Logo
1,593 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
