Dlink DSL2640T wireless router IP settings is not saving.when the power off and on the ip settings goes to factory setup....why?
  • zola80 Jan 07, 2009
  • 196 Answers
SOURCE: How to set a static IP address in Windows behind a WRT55AG Router
Windows 2000/XP 1. Click on the Start menu, and then click on the Run option. 2. When the ?Run? window appears, input control ncpa.cpl into the ?Open? field. 3. After the ?Network and Dial up Connections? or ?Network Connections? window opens, right click on the Local Area Connection or Wireless Network Connection which controls the connection to the router. 4. After the ?Local Area Connection Properties? or the ?Windows Network Connection Properties? window appears, click on Internet Protocol (TCP/IP) then click on the Properties button. 5. Once the ?Internet Protocol (TCP/IP) Properties? window opens, change the option from ?Obtain an IP address automatically? to Use the following IP address. Set the options under ?Use the following IP address? and ?Use the following DNS server addresses? to the following: * IP: 192.168.1.20 (If there are multiple computers being setup with static IP's, then the next computer would be .25, and next would be .30, etc) * Subnet Mask: 255.255.255.0 * Default Gateway: 192.168.1.1 * Preferred DNS server: 192.168.1.1 6. Click OK then OK or Close. Windows 98/ME 1. Click on the Start menu, and then click on the Run option. 2. When the ?Run? window opens, input control netcpl.cpl into the ?Open? field, then click on the OK button. 3. When the ?Network? window opens, locate the TCP/IP for the Wireless or Ethernet adapter in the PC, and click on it. Once it?s highlighted, click on the Properties button. 4. Change option from Obtain Automatically to Specify and input: * IP: 192.168.1.20 (If there are multiple computers being setup with static IP's, then the next computer would be .25, and next would be .30, etc) * Subnet Mask: 255.255.255.0 5. Click on the Gateway tab, and input 192.168.1.1 into the ?Default Gateway? field and click the Add button. 6. Click on the DNS Configuration tab, then go to the ?Host Name? field and input Computer, then go to the ?DNS Server Search Order? field and input 192.168.1.1 then click the Add button. 7. Click OK then OK once more, then windows will prompt for a restart.
Posted on Feb 16, 2006
latinmcgyver
  • 208 Answers
SOURCE: Checking the IP Address of my D-link Wireless Route
plug it in hardwired then check the ip of the pc. the default gateway is the router.
start run cmd type ipconfig /all
if u hold reset button on back for 20 seconds it should reset defaults.
Posted on Nov 07, 2007
SOURCE: Netgear usb not getting IP Address
I've just had a similar problem with my WG111T connecting to a Tiscali provided Thompson ST585 router.
My problem was that my WG111T was reportedly connecting OK to the router but that then the router would not assign an IP address to the PC.
I figured out the following - download the latest WG111T driver from Netgear (I used 2.1 from http://kbserver.netgear.com/products/WG111T.asp).
Follow the instructions to deinstall your old driver and to re-install the new.
THIS IS THE IMP BIT. When the Netgear instalation process gives you the option to use the Netgear config - it;s marked as (recommended) then DO NOT pick this. Instead pick the std. Win XP config option.
This then meant that I could control the input of the security key myself.
This worked for me!
Why? Well i'm guessing here but I think it's to do with differences in WEP / WPA-KSP.
Anyway hope that helps
Posted on May 18, 2008
  • 53 Answers
SOURCE: dlink wireless router, shows up, can't connect
the manual can be downloaded from the dlink website;
ftp://ftp.dlink.co.uk/di_broadband_gateways/di-524/di-524_manual.pdf
you are also able to get a couple of utilities from the dlink website; it's a very long link but this is the location for the relevent files.
http://www.dlink.co.uk/?go=jN7uAYLx/oIJaWVdDbgYU93ygJVYLelXSNvhLPG3yV3oVYx+g6ltbNlwaaRp7jksED2onGQTo48EE5+3n/K9K0MH8LubPtqzEMT8pnRbyctCCrpHKcCVuErk6TGEOcGXYPgp/FUnrIBfqygTYYTwlmHkgyBavmKsERo=
the formatting is messed up but just copy and paste into you web browser.
Posted on Nov 11, 2008
hdpanama
  • 65 Answers
SOURCE: wireless connection problem. laptop ip address is 60.60.x.x
D-LINK WILL HELP YOU...
Set up your new D-Link networking hardware in minutes using our new Quick Setup Wizard. The wizard will guide you through an easy to follow process to install your new hardware and connect to your network. If you need additional help, visit D-Link’s award-winning Customer Support Web Site for answers to frequently asked questions, product downloads, and easy access to D-Link’s friendly customer support team.
Posted on Nov 27, 2008
I cant setup my router to my computer
Press RESET button it is in the back side of router then all settings goes to factory defaults. Then connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
For belkin router http://192.168.15.1
or
http://192.168.2.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on wireless settings enable wifi Click on WAN settings set it as internet service provider enable DHCP Then save settings and restart router.
Thanks for using FixYa.
Oct 09, 2011 | Cisco Linksys E1000 WirelessN Broadband...
Does the d-link airplus xtreme g model DI-624 support WPS?
yes there is RESET or WPS button for RESET all settings to factory defaults. For that press RESET/WPS button for 1 seconds it is in the back side of router. Then all settings defaults . You need to configure your router with below method. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. Then set WAN settings as internet service provider settings enable DHCP. .Click on wireless and enabled it. Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Mar 03, 2011 | D-Link AirPlus Xtreme G DI-624 Wireless...
I can't connect to the internet with dlink router
http://192.168.0.1
or
http://192.168.1.1
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Click on wireless settings enable wireless then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Jun 06, 2010 | D-Link DIR-625 (790069292637) Wireless...
Hard drive crashed lost my dlink disc how would i put my dlink router on my new computer
You need to configure your router.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
Clickon wireless settings enable wireless then enable WEP Security then add WEP code .It isyour password to connect wi fi.Then save settings and restart router.
Jan 13, 2010 | D-Link High-Speed 802.11g Wireless PCI...
I can not connect to 192.168.0.1
To configure the DLink wireless router with the IP configuration address, connect a LAN cable from the computer to the DLink, then open IE browser and type http://192.168.0.1 login = admin and PW = blank (just press Enter - if you had not changed the default PW)
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
Nov 12, 2009 | D-Link DI 514 Wireless Router (DI-514)
I cannot get 192.168.0.1 to go into my router in order that i might change some settings d-link di-524
Plug a ethernet cable from your laptop directly into one of the ports on the dlink. DO NOT PLUG INTO UP-LINK PORT. Change the IP address on your laptop to an ip in the same sub-net (192.168.0.10,255.255.255.0) Then open a browser and type http://192.168.0.1. This should get you in.
Sep 17, 2009 | D-Link AirPlus DI-524 Wireless Router
Can not connect to internet
My first guess is that your Dlink ADSL modem is really a modem router, so you are getting double routing. Sometimes this works just fine, though, so I'm not confident that's the whole explanation.
You'll need to setup your IP plan carefully
set the D-Link modem(router?) to bridging mode & the DLink wireless router does the login to Exetel.
DLink wireless router WAN side: DHCP + login to Exetel
DLink wireless router LAN side: 192.168.0.1
Subnet 255.255.255.0
DHCP on: range 192.168.0.10 to .20
DNS Servers: 220.233.0.3, 220.233.0.4
with PC's wireless adaptor set to DHCP
so picks up eg:
IP address: 192.168.0.10
Gateway address: 192.168.0.1
Aug 03, 2009 | Computers & Internet
There is an Excellent signal but it's not connecting
That´s because of the ip assignment you have to set the ip of the router in the same net work ip scale of you modem that connects you to your isp example if ip modem is 192.168.0.10 then the ip you must set on the wan port mustbe 192.168.0.100, also check that you are connecting the out of the modem to the wanport on the wireless router.
Hope it helps
Jun 25, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Dlink WBR 2310 cannot connec to internet
Try to bypass the router and connect to your modem. Make sure you have Internet connection.
>If you have Internet connection. connect back your modem to the router.
>access the configuration page of your router.
>If you are given a specific IP by your Internet Service Provider, use that one.
>Login to your Dlink (type in on the address bar 192.168.0.1)
>Click Setup and Internet > Click on Manual Configure
>My Internet connection would be Static IP
>Type in your IP address, Subnet Mask, Default Gateway, Primary and Alternate DNS
>Click on Save Setting on top.
but if your Internet Service Provider did not provide you those informations
> Under My Internet connection Type choose DYNAMIC IP
>Click on Clone Your PC MAC address
>Click on Save Settings
>If it ask you to reboot, click on Reboot.
>At the very top click on Status
>Under Status look for WAN
>Under WAN look for IP address
>If you have values beside from zero it means you have Internet connection otherwise, call your dlink manufacturer for manual configuring your router for Internet connection.
Jan 30, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Internet connection lost when wireless printer added to network
for reseting the password of ur dlink router u have to press the rest button on the dlink router (genrallyit on the bottom or on the back of the router it is like a hole u have to use a pen or pin to reset the router back to its factory default settings after that password of the router will automatically back to admin or password login to ur router change the settings to static ip in the router so that u can provide the static ip of the other router to ur this router (example if primary router HL 2170 ip address is 192.168.1.1 then u will provide this dlink router the ip address as 192.168.1.5, subnet 255.255.255.0 default gateway 192.168.1.1 primary dns 192.168.1.1 now save the settings in the dlink router now the ethernet cable from ur other router will go directly in to the internetor wan port of this router. now connect wirelessly to any router both will work fine without any problem
Jun 03, 2008 | D-Link AirPlus DI-524 Wireless Router
Computers & Internet Logo
176 people viewed this question
David Payne
David Payne
