Question about Canon S520 InkJet Photo Printer
Canon s520x printer; error-message "Cartridge not Installed!"
Hello, I have replaced my cartridges and have the following error-message "Cartridge not Installed!"
I have cleaned the printerhead. When I swich my prnter on, it stops after 10 secs with only the GREEN light on (so no blinking orange light).
  • bpmacinc May 15, 2009
    Cleaned the print head and the 2 little pads. Now I get a solid green light and an error message saying 'cartridge not installed'. I put 4 new cartridges in and got the same message.
Buy a new printer! Honestly. What likley happened
it that the brown ribbon connector on the back of the frame that
holds all the ink wells has become ripped off or torn from
the green circuit board. This means that there electrical connection is gone, and the printer can't sense the frame
is in place.
This likely happened when you were cleaning it!
It's impossible to repair yourself, you need a new
black frame. And....you can't buy one separately.
You practically need to buy a whole new printer.
Sorry....
Michael
Posted on Oct 06, 2009
I cant print it says I'm out of black link and I just replaced it and it's flashing E 1 6
From http://www.refreshcartridges.co.uk/igloo/clearing-canon-pixma-error-message-e13-e16/
Locate the STOP/RESET/RESUME button on your printer which is represented by a triangle within a circle on the body of your printer and is usually in red, white or black as pictured below. With the reset button located hold it down for at least five seconds and then release it.
Aug 02, 2015 | Canon PIXMA Office Equipment & Supplies
How do I fix e07
I assume you have a Canon copier based on the E007 error code. The Fuser fixing film is torn and the Fixing film assembly or the entire fuser should be replaced. Very common issue.......You cannot reset that code without first replacing the part causing the code.
Dec 03, 2014 | Office Equipment & Supplies
I HAVE INSTALLED REFURBED CARTRIDGES WHICH I HAVE USED FOR MANY YEARS IN MY CANON IP 90....I RECENTLY REPLACED THE PRINT HEAD. NOW I GET THE MESSAGE INDICATING CANNOT FIND COLOR CARTRIDGES. I INSTALLED...
Hello and Welcome to FixYa!
Sir, if you have installed Color Cartridge but if you are getting the message about not finding the color cartridge then its means Color Cartridge in not installed properly.
Please follow the following steps to install the cartridge again.
1. First of all Confirm that the printer is powered on.
2. Open the card slot cover and then the front cover. The cartridge holder moves to the replacement position.
3. Remove the cartridges.
Note: Handle the cartridges carefully to avoid staining clothes and surrounding work area.
4. Insert the cartridge into the cartridge holder.
Note: Push up the cartridge until it clicks into place.
6. Close the front cover. Wait until the preparatory operation is complete; it takes about one to two minutes.
Now check the printer again. If you still get this error message then it means the Cartridge you installed is not exactly proper, or if you think that u got this cartridge from the reliable source and it is proper and exactly fine cartridge then the problem is in the Print Head. You need to check it again.
I hope you have a clear picture in your mind.
Don't hesitate to let me know if you have some confusion.
Sir, Your Rating for this solution as Maximum Stars and words of appreciation will be esteemed.
Thank you for taking my service.
Concerned: Muhammad Uzair
Nov 02, 2011 | Canon PIXMA iP90 Mobile Printer
Ink cartridges cannot be recognized in canon printer
Hello!
Remove the cartridges and gently wipe the cartridge contacts with a dry cloth, then put them back in. Then, hold the "resume" button for 10 seconds for each cartridge, that should reset them.
If that doesn't work, one of your cartridges (sadly) needs to be replaced.
Apr 15, 2009 | Canon PIXMA iP1300 Printer
Keep getting a U071 error message for cartge Y
Open the printer cover and check to make sure only one Yellow cartridge is installed. If so, try the following:
Remove each of the other cartridges, one at a time as necessary and see if the error message changes. Start by lifting the cover, then wait for the printhead to move to the left so you can access the cartridges inside. Pull out one of the other cartridges ( not Y) by pushing its front tab back then close the cover. Check the display, repeat as necessary. The error should have changed to U043 (bad or missing cartridge) once you remove the bad cartridge. When you replace it, the printer should work. My guess is the Magenta or Cyan cartridge is causing your error.
Apr 14, 2009 | Canon Office Equipment & Supplies
Error: ''Wrong Cartridge'' when no new cartridge has been installed
It is probably one of the cartridges. Usually, when the message "wrong cartridge" appears, the cartridge is faulty.
Apr 08, 2009 | Canon PIXMA MP780 All-In-One InkJet...
In canon pixma ip1700 Alarm light orange flashes 15 times
Fifteen Flashes: The FINE Cartridge cannot be recognized.
Possible causes are as follows:
- The FINE Cartridge may not be installed properly.
- The FINE Cartridge may not be compatible with this printer.
Install the appropriate FINE Cartridge. If lines are misaligned or the resulting output is not satisfactory, carry out the Print Head Alignment.
Apr 06, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Canon MP500 error message
If you're using Canon OEM (branded) cartridges you're going to need to ID the problem chip/cartridge so I'd try and get hold of some empty originals from somewhere (CartridgeWorld or similar perhaps?) and put those in as replacements for one cartridge at a time until you ID the problem cartridge/chip
If they're non-branded then chances are you do have more than one of the same chip but the solution is much the same...
If all else fails, take the printer to a friendly retailer who sell Canons and ask them to help you ID the problem cartridge.
Jan 19, 2009 | Canon Pixma MP500 All-In-One InkJet...
Inkjet cartridges
Hello hotstikss
The following are some error messages, if you are getting any of these, then you will have to investigate by reinstalling the cartridge or installing a new one.
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
If this does not sove the problem please let me know.
Thanks
Jun 23, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon S520 InkJet Photo Printer Logo
302 people viewed this question
old marine
old marine
mukhtar21 shaikh
mukhtar21 shaikh
