Question about Samsung LN52A850 52 in. LCD HDTV
Samsung LN52A850 no picture
Just purchased 12/08 when sits overnight or all day and first turn on, get no picture but get sound. Cannot get the menu to appear on screen nor input sources so this indicates not a problem with the cable box but with the TV itself. If I turn the TV off for about 30 seconds and turn back on I get a picture. What could be causing this, Im thinking of just taking this back to Sears. It worked fine for first days but started acting up a few days ago.
  • ryanandyori Mar 19, 2009
    This is the second set in 3 months I've had issues with. First one the convergence went out on half the screen at the 1 month old mark. The second lost all video exactly as yours did with only audio working at the begining of it's second month of use. I can get a split second of video after turning the set off for 5 min., other than that nothing. Did this happen suddenly while you were watching? Both LN52A850's I had went bad while in use.
  • Anonymous Apr 20, 2009
    my tv 52a860 3mon old turn on have sound but no picture i will never buy samsung again when it did work it was awesome team is coming out to fix will see what is going to be done i rather have a new tv not a repair!!!
  • 3 Answers
SOURCE: samsung tv turning off by itself
I have the same problem of the set turning off and on by itself. There is a circuit in Samsung TVs that would shut it down if a very loud noise occurs in the program being watched, but I have not noticed that correlation. My problem is solved by vacuuming the back panels of the set. They do not seem to have any significant dust on them, but I think the vacuum sucks somewhat inside of the TV and does some good with the fan that is supposed to be cooling the bulb and the mirror. It seems to work for months on end and when the problem recurrs, I vacuum again.
Posted on Oct 28, 2008
  • 453 Answers
SOURCE: HDMI outlet seems to be bad/ no picture
u need a main signal board replacement
Posted on May 08, 2009
SOURCE: Samsung LCD tv - Turns on and off by itself.
Not sure if this is the same problem, but I just moved and set up my Samsung 40" LCD and it has been going off and on by itself with the worst yesterday every 2-3 minutes. After speaking with a friend of mine who is not in the Tv business but just has good common sense, I determined it was likely a bad power strip. The bottom line is I replaced the crappy power strip (which was fully loaded with all 6 outlets in use) with the higher quality one I had in the other room. The problem is gone. I suspect the power strip was failing or real bad quality........try plugging the tv directly into the wall outlet first. hope this helped.
Posted on Sep 18, 2009
  • 927 Answers
SOURCE: Samsung LCD 40 inch LNT4061
Howdy,
It sounds like you have a Power Supply Board problem. The PSB is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM852 & CM853; 2200ufd 25volts.
Thanks for using FIXYA, big IRISH.
Posted on Jan 02, 2010
SOURCE: Sometimes Loses Sound
disconnect the hdmi cable from both ends it resets the sound signal!!!
Posted on May 10, 2010
While watching TV today, suddenly our Samsung LN52A850 screen went black. We have the audio, but no video. We can see extremely faint images in the background. I mean EXTREMELY faint! I have...
This problems it is alway the problems of the board that call the T-CON decoders board it is the problems and the causes.The T-CON decoders board sit at bottom in the middle of the LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON decoders board for the replacement.
Feb 13, 2011 | Samsung LN52A850 52 in. LCD HDTV
Tv has picture but no sound
Hello, is the TV connected to a cable or satellite box? If so how is it connected via HDMI or Component cables?
Nov 19, 2009 | Samsung LN52A850 52 in. LCD HDTV
52" Samsung LCD will not turn on. Blue light is on
Have you ssen the back light lit up? If not, the power supply may have problem. If it has back light, then the suspection are the main board, T-con and inverter. Those boards need checked to find out exact defective board.
Aug 17, 2009 | Samsung LN52A850 52 in. LCD HDTV
Faint ghosted picture
This is an easy one ,, i had the same problem myself
you either need to upgrade your scart leads because there leaking interfearence into your tv or move your sat/freeview system abit further away from your tv..and dont place anything ontop of your satbox ,
Jul 04, 2009 | Samsung LN52A850 52 in. LCD HDTV
Turns on But No Picture and No Sound
sounds like it could be a cabling issue, try replacing the cabling (if you have another tv, you can borrow the cabling before purchasing new set of cabling)
Apr 04, 2009 | LG 50PC5D Television
The picture on my LCD 52" 650 series TV makes everyone look short
There is an aspect ratio setting in your menu options. You will have to change the aspect ratio so you get a normal screen.
This will most likely fix your problem.
If by slight chance it doesn't, you will have to remove the back of the tv and find the manuyal adjustments for it.
All newer Tv's have the aspect ratio/picture change setting.
Jan 17, 2009 | Samsung LN52A850 52 in. LCD HDTV
Our Color TV is now Black & White
it sounds like the main board to me, I can purchase them if you want one let me know
May 22, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Samsung LN52A850 52 in. LCD HDTV Logo
95 people viewed this question
Henry  Thomas
Henry Thomas
