Solution on a slow Internet connections Problem
The major causes for a
slow...
slow Internet connections. A poor-performing connection can be caused by
broadband router configuration issues, wireless interference, or any of several
other technical issues with your home network. Follow these steps to diagnose
1. Broadband Router Settings
As the centerpiece of a network, a broadband router can be
responsible for slow Internet connections if configured improperly. For
example, the MTU setting of your router will lead to performance issues if set
too high or too low. Ensure your router's settings are all consistent with the
manufacturer's and your Internet Service Provider (ISP) recommendations.
Carefully record any changes you make to your router's configuration so that
you can undo them later if necessary.
2. Wireless Signal Interference
Wi-Fi and other types of wireless connections may perform
poorly due to signal interference, which requires computers to continually
resend messages to overcome signal issues. Household appliances and even your
neighbors' wireless networks can interfere with your computers. To avoid slow
Internet connections due to signal interference, reposition your router for
better performance and change your Wi-Fi channel number.
3. Internet Worms
An Internet worm is a malicious software program that
spreads through computer networks. If any of your computers are infected by an
Internet worm, they may begin spontaneously generating network traffic without
your knowledge, causing your Internet connection to appear slow. Run antivirus
software regularly to diagnose and remove these worms from your computers.
4. Running Background Applications
Some software applications you install on a computer run in
the background, quietly consuming network resources. Unlike worms, these are
programs designed to do useful work. Peer to peer (P2P) programs in particular
can heavily utilize your network and cause connections to appear slow. It's
easy to forget these applications are running. Always check computers for any
programs running in the background when troubleshooting a slow network.
5. Faulty Network Equipment
When routers, modems or cables fail, they typically won't
support connections. Certain technical glitches in network equipment, however,
adversely affect performance even though connections are maintained. To
troubleshoot potentially faulty equipment, temporarily re-arrange and
re-configure your gear while experimenting with different configurations. Try
bypassing the router, swapping cables and changing network adapters to isolate
the slow performance to a specific component of the system.
6. Service Provider Issues
Internet speed ultimately depends on the service provider.
Your ISP may change their network's configuration, or suffer technical
difficulties, that inadvertently cause your Internet connection to run slow.
ISPs may also intentionally install filters or controls on the network that can
lower your performance. Don't hesitate to contact your service provider if you
suspect they are responsible for a slow Internet connection.
www.temabcomputerssolution.blogspot.com
