I bought digital scrapbook and it is installed on my computer, but it won't open and run because it needs a .net framework. what is this and where do i find it?
  • 34 Answers
Its a software, you can find it at www.microsoft.com just search for it under this website and it will guide you the link to download it.
Posted on Dec 22, 2008
Click Free drive prompts to install Net Framework
There's a repair tool and other possible fixes in the following Google search:
https://www.google.com/search?client=firefox-b-1&ei=W-qIWqi6E6LW5gK1j7DYBg&q=install+Net+Framework+error+message&oq=install+Net+Framework+error+message&gs_l=psy-ab.3..0i8i30k1l2.44802.46095.0.46807.6.6.0.0.0.0.109.599.3j3.6.0....0...1.1.64.psy-ab..0.5.496...0i8i7i30k1.0.2qECe5BNIlY
Feb 18, 2018 | ClickFree Computers & Internet
Tip
How To Completely Remove .Net Framework
Directions:
  1. Download the .NET Framework cleanup tool
  2. Open dotnetfx_cleanup_tool.zip and run cleanup_tool.exe.
  3. Download and reinstall the version of the .NET Framework you want, .NET Framework 3.5 includes .NET Framework 2.0 service pack 1 and .NET Framework 3.0 service pack 1.
Prerequisites:
Note: If you are installing on XP 64 bit or Windows 2003 you might need to install the Windows Imaging Component. The Windows Imaging Component 32 bit can be found here. The Windows Imaging Component 64 bit can be found here.
on Feb 20, 2011 | Computers & Internet
My wife has been using Printmaster for years and has created thousands of projects. Her latest version is 18. We got a new computer with Windows 7 and it said that version 18 is not compatible. So we...
Installing PrintMaster 18 on any computer requires .NET Framework 1.1 to be installed on the hard drive. If NET Framework 1.1 is not installed, it will be installed from thePrintMaster 18 install disk before PrintMaster 18 is installed. If possible download .NET framework 1.1 If .NET Framework 1.1 is not already installed on the computer, the "Program Compatibility Assistant" in Windows 7 will display this message.To continue with the installation, select "Run Program".
Feb 18, 2011 | Broderbund PrintMaster Platinum Version 18
My scrapbook deluxe 5.0 fails to load. demands i install net frame work version 2.0.50727
It is very easy you just have to install the .Net(pronounced as Dot Net) framework.
You can download it free from
http://www.microsoft.com/downloads/en/details.aspx?FamilyID=0856eacb-4362-4b0d-8edd-aab15c5e04f5&displaylang=en
Also download and install the following .net 3.5 for avoiding future problems
http://www.microsoft.com/downloads/en/details.aspx?FamilyId=333325fd-ae52-4e35-b531-508d977d32a6&displaylang=en
Rate if you like
Feb 15, 2011 | Novatel Art Explosion Scrapbook Factory...
Reinstalling PrintShop 20 after 'computer failure'. Error installing Microsoft(R)NET. Framework. This is happening when installing PrintMaster & Creating Keepsakes Scrapbook, as well - all...
Hi
There are two things I need to know before I can solve the problem.
1. what windows is installed on the computer? Is it windows 2000, windows xp, windows vista, windows 7 or something else?
2. do you know if the windows is 64bit version? If you don't know, do you know how much RAM memory does the computer have? less than 4GB? more than 4GB?
To find out which version it is 32 or 64 hold down the windows key and press r, in the run menu that comes up write msinfo32 and click OK
Now on the system information page that opens, on the right of the window find system type
Tell me what it says there if you don't know if the computer has 64bit or 32bit windows installed.
Dec 07, 2010 | Broderbund Computers & Internet
When I try and download pictures from my camera ..I get a window which tells me to install Net Framework...this has only happened since my computer had a virus removed
.Net Framework is a Windows networking component that is required by a lot of programs to work. Try running Windows Update and let it check for new updates then see if .Net Framework is one of the available updates and install it. otherwise you can go directly to the Microsoft Windows homepage and find it there for a direct download. More than likely the virus that you had was residing in this module. I hope this helps you.
Best regards,
Bob
Oct 08, 2010 | Canon PowerShot A590 IS Digital Camera
Error code 643
Try this for starters:
http://support.microsoft.com/kb/923100/
Basically, it involves un-installing .NET Framework Version 1.1 Service pack
1.
Then download and use (Run as Administrator) the Windows Installer CleanUp
Utility, and remove all references to .NET Framework Version 1.1 Service
pack 1 (only!).
Then reinstall .NET Framework Version 1.1 Service pack 1:
http://www.microsoft.com/downloads/detai…
Then run Windows Update again, to install KB929729.
Jun 25, 2010 | Microsoft Windows Vista Home Premium with...
Definition of asp.net & .net frame work
ASP.NET is a web application framework developed and marketed by Microsoft to allow programmers to build dynamic web sites, web applications and web services
The Microsoft .NET Framework is a software framework that can be installed on computers running Microsoft Windows operating systems. It includes a large library of coded solutions to common programming problems and a virtual machine that manages the execution of programs written specifically for the framework. The .NET framework supports multiple programming languages in a manner that allows language interoperability, whereby each language can utilize code written in other languages; in particular, the .NET library is available to all the programming languages that .NET encompasses. The .NET Framework is a Microsoft offering and is intended to be used by most new applications created for the Windows platform.
Jun 02, 2010 | Microsoft ASP.NET Programming with MS...
Can not install Net Framewoek 3.0 because of
Sir,
Run the cleanup tool to clean out temporary files, run the .NET
Framework cleanup tool, Run the installation file, then reboot and try to install it again and see if it works. If not try the below following steps....
Step One:
1. Go to Add or Remove Programs, try to remove all .NET Framework.
2. Please download and install the Windows Installer Cleanup utility
from this link:
http://download.microsoft.com/downlo...BD/msicuu2.exe
3. Then, please run it from Start-> All Programs-> Windows Install
Clean Up.
4. Please remove all Microsoft .NET Framework shown there and click
Remove.
Step Two:
1. Click Start->Run, type INSTALLER and click OK.
2. In the open folder, click View menu and select Details.
3. Right-click the Date Modified column header.
4. Click Comments
5. In the Comments column, locate the cached Windows Installer file
that displays Microsoft .NET Framework 1.1 (English) RTL x86 enu.
6. Right-click the cached Windows Installer file and then click
Uninstall.
7. Close the window.
8. Delete the cached Windows Installer file.
Step Three:
1. Restart your computer.
2. While your computer is booting up, press F8 to invoke the startup
menu.
3. In the startup menu, choose Safe Mode.
4. Log on as an administrator.
Note: In Safe Mode, your system display and Desktop will look and
perform differently than in Normal Mode. This is only temporary.
5. Delete the folder C:\WINDOWS\Microsoft.NET
6. Delete the folder C:\WINDOWS\system32\URTTemp
7. In the C:\Windows\System32 folder, locate the file mscoree.dll.
Right click and rename it to mscoree.old
Step Four:
1. Click Start->Run, type REGEDIT and click OK.
2. Navigate to the following registry key by expanding the "+" beside
the registry tree in the left pane:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\.NETFramework
3. Delete this key in the left pane.
4. Repeat steps 2-3 to delete the following key:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\NET Framework Setup
5. Restart your computer to Normal Mode
Step Five:
1. Please download the Microsoft .NET Framework Version 1.1
Redistributable Package from the following link and save it to C:
http://www.microsoft.com/downloads/d...DisplayLang=en
2. Click Start->Run, type "c:\dotnetfx.exe /C" (without quotation marks
and there is a space in this command) in the open box and click OK.
3. Click Run, and type "C:\.NET Framework 1.1" (without quotation
marks) in the open box click OK
Note: If you are prompted to create this folder, please click Yes to
continue.
4. Locate the folder C:\.NET Framework 1.1 and double click the file
netfx.msi in it to install .NET Framework components.
If .NET Framework 1.1 can be successfully installed, we can go on to
install .NET Framework 1.1 Service Pack 1:
Microsoft .NET Framework 1.1 Service Pack 1
Step Six:
If the above two can be installed correctly, please download KB886903
from the following link and install again:
http://www.microsoft.com/downloads/d...displaylang=en
If the problem still exists, please describe the error message when
installing Microsoft .Net Framework Service Pack in further detail
Thanks
Good luck
Nov 07, 2009 | Microsoft Computers & Internet
Vista error codes 643 and 646
the error codes that you have mention is related to windows update of Microsoft .net framework.
To troubleshoot this issue, I suggest we first perform these steps:
Step 1: Download Microsoft Windows Installer CleanUp utility
1. Visit:
2. Save the file to your computer.
3. Right click "msicuu2.exe", click "Run as administrator" and follow the
wizard to install this tool on your computer.
Step 2: Remove .NET Framework
1. Click Start ->All Programs->Windows Installer Clean Up, click Allow.
2. See if you can find .Net Framework software. If so, remove them.
After that, please restart the computer and perform the following
suggestions to reinstall .NET framework 1.1 and the updates for it.
Step 3: Install .NET Framework 1.1 Redistributable Package and related updates
1. Please download the Microsoft .NET Framework Version 1.1 Redistributable
Package from the following link and save it to the C drive (C:\)
1) Microsoft .NET Framework Version 1.1 Redistributable Package
http://download.microsoft.com/downlo...6/dotnetfx.exe
2) Microsoft .NET Framework 1.1 Service Pack 1
http://download.microsoft.com/downlo...867460-X86.exe
3) Security Update for Microsoft .NET Framework, Version 1.1 Service Pack 1
(KB928366)
http://www.download.windowsupdate.co...d81a178b15.exe
4) .NET Framework 1.1 Service Pack 1 SYSTEM.WEB.DLL and MSCOREE.DLL Security
Update for Windows Vista (KB929729)
http://download.microsoft.com/downlo...929729-X86.exe
Please follow the steps above and if still problem persist please lets us know
Regards,
Om
Oct 20, 2009 | Computers & Internet
Computers & Internet Logo
24 people viewed this question
Alun Cox
David Payne
David Payne
