Hi, I have a hp dv2915nr laptop. I wanna replace its keyboard.coz one of its keys is broken. So how can I remove the keyboard from the laptop and fix the new one??
If a key on a laptop keyboard stops working it's usually bad news for the keyboard as it may well need to be replaced. Test the 'feel' of the button. Does it feel different compared to other buttons when you press it? I.e. does it feel loose, stiff, wobbly or like it sticks? Stiff or sticky could mean there is something stuck under the button, loose or wobbly could mean it is mechanically broken. Sometimes turning your laptop on it's side and tapping it firmly, not hard, can release it if there is a mechanical fault. Unfortunately however I think the fault is most likely to be an unrepairable one. You could always plug in an external USB keyboard to check if it the G key responds just to rule out an operating system fault but it is unlikely to be that. If the G button works when using the external keyboard you can be sure it is your laptop keyboard that is broken.
Replacement keyboards cost around $30 (eBay). There's a good guide on youtube showing how to remove the keyboard. http://youtu.be/OOor4uZRM9g
Please Open the following Website of HPAnd Download the drivers from thereSimply Put the Model number ( HP Pavilion dv2915nr Entertainment Notebook PC ) of your HP Pavilion Notebook in the drivers search box. Then click Search
Go to Driver - Network, and select the bluetooth driver. Bare in mind, not all HP Pavilion dv2915nr supports bluetooth. But, if your laptop does have bluetooth and you installed the drivers, but still not working, your bluetooth card might be faulty and must be replaced.
Hey, If a few keys do not work on your keyboard you can get them replaced , i recently got my new replacement keys from www.laptopkey.com Now my laptop keyboard is as good as new. Love them for they service and reasonable cost.
sometimes one can purchase seperate single keys for your keybpard
Or look on ebay keyboards are not expensive and very easy to fit if you ask the buying for fitting instructions he may send them if not just google or look on youtube for video.s on how to fit HP keyboard
Most keyboards can be popped out by pulling them straight out and replacing them by pushing them straight in. If you have several sticky keys, you are better off just buying a new keyboard and replace the entire thing. follow the instructions on the owner's manuel how to remove the keyboard on your machine as they are different. it usually requirer removing just a few screws either from under the machine or by removing the small face plate just below the screen..Again, all laptops are a little different.
