Question about Sony Xplod XM-554ZR Car Audio Amplifier
I have a car amp that doe not turn on. It dies on me yestaerday. I checked the fuses in the back of the amp and they are not blown. But the lights on the amp do not turn on
  • 15,935 Answers
Check the main fuse in the power cable. Should be within 1 ft of battery.
If that is in tact, use a voltmeter and verify 12V at the power terminal on the amplifier, as well as the remote turn on after you have turned the key on.
Also check ground continuity.
Posted on Dec 22, 2008
Number 21 fuse keeps blowing vw tiguan 2009
check the bulb it may be shorted out try new bulb and see if fuse stops poping if it does not the you have a shorted wire
Aug 25, 2017 | Cars & Trucks
03 Pontiac Vibe after rear ended several electronics died
10 amp fuse under steering column that says it is for 'Gauge' fixed this problem. That fuse had blown.
Oct 23, 2009 | 2003 Pontiac Vibe
My 1996 Ford Windstar Will Not Start....
Take all the fuses out and check them one by one and re install them and replace the blown fuse .
Tap on the relays to unstuck them .
Clean the batery terminals with sand paper .
Check the rear light and brake bulbs and sockets.
Vitally
Sep 03, 2009 | 1996 Ford Windstar
Instrument panel went dead
Checked Every fuse in the fuse box (no small task).This includes #4 - Power point Instrument Panel, #14 - Day time running lamps (auto lamps doesn't work nor does auto lock), #27 - ignition switch run feed, #35 - Instrument Cluster, #41 - Instrument Cluster, #42 - Delayed Accessory, #45 - Ignition switch run/start feed, #102 - Door locks body security module, #103 - Ignition switch, #110 - Ignition switch, & #116 - Ignition switch. But I also check all other ones as well, they all register OK. AC panel & radio work. Turn signals work. Mileage does not work, trip computer does. So, basically, everything works except auto head-lights, auto locks, and the dash cluster (no MPH, RPM, mileage display, Fuel, Temp, Tran Temp, and Oil Pressure).
Aug 19, 2009 | 2003 Ford Excursion
1999 cougar stuck in park and does nothing when you turn the key
Yout whole fuse box might be blown. I had to replace mine on a 2000 Cougar.
Jul 01, 2009 | 2000 Mercury Cougar
Car will not crank over
Check the fuse box and make sure no fuses are blown. I had the same problem with my honda motorbike and thought the worst of it but then checked the fuses and found that one had blown. Once replaced the bike was fine!
Hope this helps you in someway! Good luck!
Jun 19, 2009 | 2000 Ford Taurus
02 echo ac issue
I assume that the 7.5 amp fuse blew again, yes? If so, it looks like you may have a locked up A/C compresser, or too much freon in the system (if somebody tried to add some to make the A/C come on). If the compressor is locking up, the engine will turn slow, at least until the drive belt or the fuse fails.
Aug 27, 2008 | 2003 Toyota ECHO
Fog lights blow 15 amp fuse
i had the same problem...but mine is after i install a new set of HID kit..after a couple of weeks it just died..then i check the fuse it was blown..then i changed it and turn it on and it blows again...i did change it again ..same thing it fuse blown.
Jul 18, 2008 | Plymouth Voyager Cars & Trucks
Red light on Amplifier
if your amplifier has the internal Kicker card dealie "little computer card on the side that you can change out crossover settings and such," Turn off the vehicle, remove this device and make sure the contacts on the card are clean and free from black soot (showing a spark). clean the contacts with a pencil eraser or something hard but soft... and put the little card back in place, start the car again and see if that helps, I used to lose one speaker every once in a while with the same amp. I ended up replacing the module with a different one from my dealer and it worked fine (still does and it's been in my car 6 years). Check that little module. if this doesnt work, while the car is running and the music is "playing" wiggle the card and see if it works sometimes and not others. Likely is the little module.
Dec 28, 2006 | Kicker (ZX750.1) Car Audio Amplifier
Sony Xplod XM-554ZR Car Audio Amplifier Logo
Top Sony Car Audio & Video Experts
xxxxxx xxx
Mike Duncan
Mike Duncan
Marvin
Marvin
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
