No sound! Just weeks ago, I had to re-install windows xp to my compaq presario sr1603wm computer. After doing this, I discovered not only the windows program I have now is an older version than what I originally had , but I have all of the appropriate players to play things on the internet however I have no sound! I guess my thing is when I try to troubleshoot the problem, Windows says i have no sound card or appropriate mixer device so therefore, the volume control option is not available. It reconizes the hardware I have or need but it just won't start.I've tried everything from unstalling to reinstalling the hardware to even trying to look for sound cards all together. Any possible suggestions on what to do about this? my pc stopped producing sound.i tried to reinstall the driver but it could not work.my sound device is Intel Intel(R) 82801BA/BAM AC '97 Audio Controller. the volume mixer menu went away.,when i try playing anyting it reports an error(no mixer devices found).my system summary is: operating System: Windows XP Professional (5.1, Build 2600) Service Pack 3 (2600.xpsp_sp3_qfe.080423-1303) Language: English (Regional Setting: English) System Manufacturer: Compaq System Model: EVO BIOS: 686Y2 v2.06 Processor: Intel(R) Pentium(R) 4 CPU 2.00GHz Memory: 256MB RAM Page File: 189MB used, 429MB available Windows Dir: C:WINDOWS DirectX Version: DirectX 9.0c (4.09.0000.0904) DX Setup Parameters: Not found DxDiag Version: 5.03.2600.5512 32bit Unicode ------------ DxDiag Notes ------------ DirectX Files Tab: No problems found. Display Tab 1: No problems found. DirectDraw test results: Failure at step 5 (User verification of rectangles): HRESULT = 0x00000000 (error code) Direct3D 7 test results: Failure at step 32 (User verification of Direct3D rendering): HRESULT = 0x00000000 (error code) Direct3D 8 test results: The tests were cancelled before completing. Direct3D 9 test results: The tests were cancelled before completing. Sound Tab 1: No sound card was found. If one is expected, you should install a sound driver provided by the hardware manufacturer. Music Tab: No problems found. Input Tab: No problems found. Network Tab: No problems found. -------------------- DirectX Debug Levels -------------------- Direct3D: 0/4 (n/a) DirectDraw: 0/4 (retail) DirectInput: 0/5 (n/a) DirectMusic: 0/5 (n/a) DirectPlay: 0/9 (retail) DirectSound: 0/5 (retail) DirectShow: 0/6 (retail) --------------- WHQL Logo'd: Yes WHQL Date Stamp: n/a VDD: n/a Mini VDD: nv4_mini.sys Mini VDD Date: 4/13/2008 22:04:32, 1897408 bytes Device Identifier: {D7B71E3E-436C-11CF-4765-7820B4C2CB35} Vendor ID: 0x10DE Device ID: 0x002C SubSys ID: 0x007210DE Revision ID: 0x0015 Revision ID: 0x0015 Video Accel: ModeMPEG2_A ModeMPEG2_B ModeMPEG2_C ModeMPEG2_D Deinterlace Caps: n/a Registry: OK DDraw Status: Enabled D3D Status: Enabled AGP Status: Enabled DDraw Test Result: Failure at step 5 (User verification of rectangles): HRESULT = 0x00000000 (error code) D3D7 Test Result: Failure at step 32 (User verification of Direct3D rendering): HRESULT = 0x00000000 (error code) D3D8 Test Result: The tests were cancelled before completing. D3D9 Test Result: The tests were cancelled before completing. ------------- Sound Devices ------------- Description: Default Sound Playback: No Default Voice Playback: No Hardware ID: Manufacturer ID: Product ID:
  • 1 more comment
  • eatinga Dec 22, 2008
    please help
  • eatinga Dec 27, 2008
    MY PC STOPPED Producing sound.i tried to uninstall the sound card and reinstall it ,it finds the hardware but complains that a problem occuerred during installation.when i try playing ,Windows says i have no sound card or appropriate mixer device so therefore, the volume control option is not available. .I've tried everything from unstalling to reinstalling the hardware to even trying to look for sound cards all together. Any possible suggestions on what to do about this?.please assit(include the appropriate procedure).my SOUND device is Intel Intel(R) 82801BA/BAM AC '97 Audio Controller. the volume mixer menu went away.,when i try playing anyting it reports an error(no mixer devices found).
    SYSTEM SUMMARY
    System Model: EVO
    BIOS: 686Y2 v2.06
    Memory: 256MB RAM
    DxDiag Notes
    Direct3D: 0/4 (n/a)
    WHQL Logo'd: Yes
    VDD: n/a
    Vendor ID: 0x10DE
    Device ID: 0x002C
    Revision ID: 0x0015
    Revision ID: 0x0015
    Registry: OK
    D3D Status: Enabled
    AGP Status: Enabled
    Sound Devices
    Description:
    Hardware ID:
    Manufacturer ID:
    Product ID:
    Comment posted on Dec 22, 2008
    please help
    Still need a solution for this problem? Try our Premium Assistance plan
  • atineric Jan 02, 2009
    my pc complains of no mixer devices found.i try installing sound drivers it says it-error found during installation.error code 10.please help.
    summary;
    System Model: EVO
    BIOS: 686Y2 v2.06
    Memory: 256MB RAM
  • 34 Answers
Ok, is your sound card an onboard (included with *********** board) or not. If it is not onboard sound card, i suggest to remove it from the motherboard and then clean the contacts with pencil eraser (rubber) use the eraser to remove the carbon and dust that accumulated in the sound card contacts. reinstall it and reintall back the driver. it should work by then. Or if you have an onboard sound device try to go to the CMOS setup of the motherboard and make sure that the onboard sound device is enabled in CMOS.
Posted on Dec 22, 2008
    President:
  • 1,901 Answers
Did you get the driver from HP? Here is a link to install (or download) the driver for your system. It may be beneficial to download it to your computer in case you need it again.
SR1603WM Audio Driver
2 Suggested Answers
abangkuraden
  • 34 Answers
SOURCE: No sound!
Hi, I'm Azrul. Compaq presario srt1603wm uses the realtek AC'97 hardware. There are many drivers available for realtek.
Posted on Dec 21, 2008
My media card slots are not working any longer. I have a Compaq Presario Model sr1603wm. The drives do not show up under My Computer. Any idea how this could be fixed? These are the card slots not working,...
Have you tried unistall and reinstall the drivers?Go here http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph07165&tmp_track_link=ot_recdoc/c00471056/en_ca/bph07165/loc:2&lc=en&dlc=en&cc=ca&lang=en&product=1118242#N1070
and try to install the drivers again
Jan 12, 2010 | HP Compaq Presario SR1603WM (ED861AA) PC...
I have a compaq sr1603wm and I was wondering what motherboard I can use to replace the stock one and if I would need to replace the power and or fan thanks..
You need and AMD motherboard that supports the Sempron processor -939 Socket. It's a little difficult to find them now, but they are still available. Since you have a brand computer. You make have to give up some perks like front usb port or the audio cable might be too short to mount on the new board. Be prepared for some compromise when installing a different board.
See Link:http://cgi.ebay.com/Compaq-SR1603WM-AMD-Sempron-1-8Ghz-1GB-160GB-DVD-RW-PC_W0QQitemZ270488804698QQcmdZViewItemQQptZDesktop_PCs?hash=item3efa639d5a
Copy link to browser.
Good luck
Nov 24, 2009 | HP Compaq Presario SR1603WM (ED861AA) PC...
Compaq sr1603wm issues...
Your computer is infected with a virus. The only solution for that problem is that you should reformat your hard disk and install a new copy of Operating System to it again. If you do have important files on that drive, you can back-up them by plugging it to another computer and there you will the content of you drive. Hope this will you..Thanks..
Oct 23, 2009 | HP Compaq Presario SR1603WM (ED861AA) PC...
Where do i download a sound driver from?
www.driverguide.com try them out you will find your driver there. Thanks for using Fixya.com
May 22, 2009 | HP Compaq Presario SR1603WM (ED861AA) PC...
No audio device found
Go to your manufactor website and download the audio driver.
Jan 17, 2009 | Compaq Audio card Sound Card
Sound Driver of a Compaq Presario C700 Notebook PC
Reinstallations of XP sometimes do not install all of the sound files needed. Do a google search for UAA, it is Microsoft's audio file. Download it, install it and then run Windows update. The drivers for your machine should be under the Hardware section of the updates.
Jan 07, 2009 | Compaq Presario C700T Notebook
No sound!
Dec 21, 2008 | Compaq Audio card Sound Card
No sound
dear surindershar,
you said c738tu latop..think that yours is compaq persario dual core series..you said u installed sp3. so you should also instal audio drivers for sound. you can very well download from hp website or else CLICK THE LINK :
http://www.zyxware.com/articles/2008/01/09/compaq-presario-c738tu-laptop-drivers-for-windows-xp
u can follow the steps listed there..
Sep 05, 2008 | Compaq Presario 700 470024-192 Notebook
Computers & Internet Logo
647 people viewed this question
David Payne
David Payne
