Question about JVC TH-A85 System
Bass speaker stops working every now and then
The bass speaker of my JVC TH-A85 system randomly stops functioning. It will shut off in the middle of a movie, or when im just watching tv or listening to radio. After a while it automatically comes back on. Does anyone have an idea what the problem is?
  • Erwin Wijsbek Apr 23, 2007
    Nope no answer. And actually all speakers stop at the moment it happens. But since they're all connected to the bass speaker (subwoofer), i figured the problems must be in that one.
  • Erwin Wijsbek Apr 30, 2007
    Yes that seems to be it, the headphone mode it goes in by itself. I think i got it fixed now by blowing in it, to get dust out.
Hi, Ive finally found the problem with my system :o) Its not the subwoofer its the DVD unit!!! think outside the box. Mine was randomly switching into headphone mode, so i pluged some headphones in took them out and walla its working fine. Not sure why this happaned perhaps some dirt or something else got inside there???? Let me know if this helps
Posted on Apr 28, 2007
I have a Th-C50 home theater and lost my subwoofer system cord, can I use a regular s-cord to make that connection? or is it useless with out the cord?? Please help!
Yes you can use any 2-core cable to carry the bass signal to the subwoofer. As the bass speaker cone is the largest cone in your speaker set I would recommend a good quality cable of decent gauge (thickness) to carry the bass signal.
You just need to make sure you have the right connectors for the amp and sub and make sure you connect positive to positive and negative to negative.
Hope this helps,
Chris
Mar 02, 2011 | JVC TH-C50 System
WOOFER NOT WORKING JVC th-m606
mosfet's might have shorted and blew up a capacitor and might have took some surface mount parts with it.it will be in the middle board with the metal shroud (shield). try to replace it .
Aug 12, 2008 | JVC TH-M606 System
How to adjust bass and treble
this is kinda vague i hope this helps! first turn the equlizer to flat make sure eveything is equal. then turn he volume about 3/4 of the way up. this is around the point where th radiostartsto send distortion to the speakers (the easiest way to blow speakers) . thenstartwith the bass. eeryones ears are different i usually tue the bass to a notch or so below half ao if the radio ges to +12 i wouldput it on 4 or 5. next the mids are usully set at about +2 or 3. then thetrebbel is set a hairhigher than the bass. make this your maximum listenig volume so you dong damage the speakers. Hope this helped! let me know
Sep 15, 2010 | JVC Car Audio & Video
JVC TH-M606
You need to take apart tthe sub woofer and check the connection to bass speaker for continuity. It sounds like an internal broken connection to speaker on sub woofer unit.
Sub woofer shuts off
please check sub cable first with another good one and then change sub itself.because it draw too much power.
Jan 05, 2008 | JVC TH-C50 System
Problem with my MX Gt 88!!
use the speakers it came with it works fine for me i have mine hooked up to a 300w inverter anything less i dont get the best sound you cant turn the volume up too loud on the reciever it will draw too much power and shut it off or blow the fuse in you car unless the inverter you are using has an external fuse on it my inverter warns me that i am drawing to much power so when i hear the beep i turn it down a notch and works fine but ya try using the speakers th system came with
Nov 02, 2007 | JVC MX-GT88 CD Shelf System
Bass of woofer in my system is not working
take it to a tech for repairs.good luck
May 02, 2007 | JVC TH-C40 System
SubWoofer
Sounds like your original and this sub have bad amps. The amp for the sub is not the same as the amp for the other speakers. The old unit has a dead amp and this new one is on the way out. (Pulling too much current on high bass)
Mar 30, 2007 | JVC TH-M505 System
Sounds but no bass
Check your setting for the sub first. If that doesn't pan out it is likely to be the amp.
Dec 28, 2006 | JVC TH-M505 System
Systems shuts off if sound gets too loud.
Yes, i had this same problem. If it was too loud, at level 37+, any loud boom would shut down the subwoofer, subsequently shutting down the speakers. As such, I figured it might have been the 8 pin dim cable, but that wasn't it. What solved the problem was lowerin the BASS level. Not the level on the subwoofer, but the actual BASS level. I had it at +10 (the max) and it was too much for the system to handle. I don't think I ever had it like that so I'm assuming someone, maybe my daughters, moved the settings. But anyway, moving the bass level back down to either 0 or +3 at most maintains the "boom" effect of the subwoofer minus the shutting off of the system.
Oct 20, 2006 | JVC TH-C60 System
JVC TH-A85 System Logo
194 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
