Option audio OAX502 500W car amplifier "alarm" mode
I have an option audio 500W car amplifier (OAX502) during the install, wires running from amplifier to sub were crushed and either shorted to ground or shorted together, fuse did not blow but amp got hot. red "alarm" light is now on (must be in protection mode?), does anyone know how to fix this problem? is there a reset for protection mode?
any help will be much appreciated
thanks.
  • Anonymous Apr 29, 2009
    Yeah I got the same prob bro. Except i dont think my amp got hot. I've checked all my connections and stuff a couple of times but i think it has something to do with the amp itself. It seems to have shut down and wont reset or something. Still working on it, if i cant find the prob i'll take back the stupid thing, as its only a couple of months old and hasn't done much work.
    Any one out there with a fix/solution???
  • cjhbrits Nov 25, 2009
    how do I reset my Rx v3900 amp
  • 81 Answers
SOURCE: Amp Protection Mode
no, your output transistors maybe 2 of them are gone or the small power supply that feeds the other circuitry has become defective.
Posted on Dec 15, 2006
The Marv
  • 72 Answers
SOURCE: Amp goes into protect mode.
I would definately suspect wiring. If you can use a volt meter. Put it on the b+ to ground and see what the reading is should be 12+ then try the ground to remote wire should be 12+. If it drops below 12 volts when car starts. Recheck wires for loose connection. Also double check the wire you have the remote wire connected to. You might even want to disconnect from the amplifier and use a jumper wire from the positive terminal on the amp to remote on the amplifier and see if it stays on then. If it stays on you will have to find the loose connection or find a different wire to get remote power.
Posted on Feb 05, 2007
cheebster
  • 39 Answers
SOURCE: amp heats up and goes into protect mode
Hi Saint108. You're describing it well, and i know what the problem is already. The MA audio amp, can't hold with a 2 ohm load. It's too low for that amp, that's for sure. Those are budget amps and they are not well built enough to handle low ohm setups like that. It's overheating and there's no ways around it.. Other than wiring your subs differently ! Just wire your sub directly (not in parallel) in a 4 ohm load, you will notice it will stop overheating that much. Do it quick, you'll most likely fry your amp giving it such hard work !! The HUM you're hearing could be related to it also. Try that, and keep me posted on the status. Thanks ! Cheebster.
Posted on Jul 02, 2007
osborne382
  • 306 Answers
SOURCE: Amp stuck in protection mode.
check to make sure your ground wire is attached to a clean metal surface no more then 18" away from amp. check all wires to ensure none are touching other terminal. all else fails remove one sub and see how it play, if its works great switch subs. could be a defective amp. if it is the amp and you payed for it with a credit card or bank card you can do a charge back from the bank to get your money back if the store wont replace it. thell the bank "you want to do a charge back cause it wasnt as discribed).
Posted on Nov 12, 2007
  • 125 Answers
SOURCE: car amplifier install issue
check the remote cable from your head unit to the amp first.
Posted on Apr 20, 2008
Signs of a blowed 15 inch subwoofer
Melted voice coil? Short circuited voice coil due to overload? does your amplifier work properly? Is the (-) properly grounded? If the SUB is in working condition and there is nothing wrong with the amplifier.
1) The amp is not powerful enough to run the sub
2) The amp is not properly grounded or powered
3) Remote Sensor wire is not connected
4) RCA Cables or Hi - input sensors are not connected
Check out the installation to verify or the sub may be damaged
Apr 25, 2013 | Tsunami Car Audio & Video
I just installed a new xo vision x349nt dvd receiver in my car . My rockford fosgate p3001 amp turns on but the subs doesnt come on but when i would take the base control out and put it back in i can hear...
Make sure and check the RCA wires in the back of your radio that send audio to the amp and make sure that they're connected to the OUTPUT/SUBS RCA's and not an input rca's. Also, check your ground and make sure no speaker wires in the subs are shorted. Try one speaker at a time see if that helps.
May 18, 2011 | Rockford Fosgate P3001 Car Audio Amplifier
Protect light is on ,no sound?
Make sure you have a good ground connection. The ground wire should be solidly connected to the vehicle chassis in a paint-free location. If the ground is connected badly, the protect light will come on.
Mar 08, 2011 | Legacy Audio Legacy - Red Series: 2...
How to instal a kac-x401m car audio amplifier
12v- red wire runs to your battery, recommend 4ga
remote - blue wire run to a accessory wire or a remote turn on at the radio
ground - black wire connect to bare metal, recommend same size wire as the power.
Rca - connect to head unit or a Hi-level converter if you have a stock radio.
speaker wire- connect to your sub 2ohm or 4ohm depending on your setup.
Oct 23, 2010 | Kenwood KAC-X401M Car Audio Amplifier
I melted the input for my 12 volt connection well just the plastic around it. Is there anyways i can fix this, or does someone know where i would be able to send it in to be fixed? My amp still gets power,...
The high current drain due to a possible short in the sub output drivers must have pushed the connectors to melt off and fail.
Your amplifier driver MOSFETS might have shorted to bring about the protection on. Make sure that the wiring to the sub woofer is not touching a ground or shorting.
You can ask any audio tech. to have a look within and test for shorted driver outputs.
Sep 17, 2010 | Digital Audio 1500 WATTS CLASS D MONO...
Sub cutting out
500W x 1 @ 2ohm
How did you "switch the sub from 2ohms to 4 ohms"?
If you have the swr-1222d as listed, your only options are wiring 1 or 4 ohm, as it is a dual 2 ohm voicecoil.
If it was wired @ 1 ohm - you may have already done the damage to your amplifier - as it is not rated @ 1ohm mono.
There are 3 reasons the amplifier will go into protect mode while playing...
Thermal - overheating due to too low impedence.
Ground Loop/Short Circuit - Blown voicecoil, bad amplifier ground, tinsel slap, etc.
Overload - Impedence not within specs.
Disconnect every wire (including RCAs) from the amplifier. Reconnect only power and ground - make a short wire to loop from power terminal to remote terminal.
If the amplifier stays on without turning off - remove the jumper, add the remote wire, and try again.
If it turns off - the problem is internal and needs repair.
Still on? plug in 1 rca, and re-try.... then the other.
Still going??
Now use an Ohm Meter - or Digital multimeter set to ohms 20, and check both voicecoils. They should read 2ohms +/- .5ohm.
If they are OK, wire up the 4ohm load (series the voicecoils) and turn the gain on the amplifier to 1/2.
Retry -
If the amplifier continues to fail at higher volumes - the thermal protection relay has become weakened because of your improper wiring, and will need to be repaired to solve your issue.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jun 10, 2009 | Alpine Type-R SWR-1222D Car Subwoofer
I cant hook up my amp
Hello cesar199064,
These are the steps you required to install your amp and subs:
1) Purchase an amp wiring kit with 2 or 1/0 gauge power and ground wires.
2) Decide on a location to mount the amp where it will get proper airflow and will not interfere with operation of the vehicle. Closer to the battery is better. Decide on the location and install the sub enclosures.
3) Locate a place on the metal body of the vehicle within about 3" of your amp for the ground. Connect the ground wire to the amp ground terminal and to BARE METAL on the vehicle.
4) Run power wire from battery positive (+) using one of the amp kit ring terminals through a 100A fuseholder to the amp positive terminal. DO NOT install the fuse yet.
5) Run a "remote" wire from the remote turn-on lead (usually blue or blue/white) of your dash mounted head unit to the amp turn-on terminal. Run a set of RCA cables from the preamp or subwoofer outputs on the head unit to the amp inputs.
6) Run speaker wire, preferably at least 12-gauge, from the amp output terminals to your subs.
7) Check all of your wiring. Make sure that no insulation was damaged or peeled off during the running process. Make sure there are no loose strands touching adjacent terminals or bare metal.
8) Use a multimeter set to read "ohms" and test from the negative battery post to the amp ground terminal. You should read "0".
9) Install the fuse.
10) Turn on your head unit and listen to those big Kickers thump.
11) Adjust the amp settings according to your manual.
The best place I've found for in depth information on audio installs is The Install Doctor. You'll find step-by-step procedures, color photos, wiring details, and even the tools required. I recommend that you begin with the "tech docs" link and read through some of the PDF documents.
Hope this helps.
May 08, 2009 | Kicker ZX10001 Car Audio Amplifier
Orion hcca 250 digital reference & orion XTR 12" 500w dual subs
If you have one sub dual voice coil, just paralel the sub and conect to brigde amp. Simple...
Mar 02, 2009 | Orion HCCA-D5000 Car Audio Amplifier
Very confused
Could be you have a bad connection at the battery or at the amp or it could be that you are using a battery source wire to the amp that is way too small. Is the voltage at near 12 volts when the amp is switched off? If it is then either of the two problems I mentioned may need to be addressed. Don't forget to check and see that your ground wire is big enough and short enough and attached to the chassis good enough to carry all the amperage that it must during operation. The size of the fuse on the amp will give you a pretty good indication of which wire size you should be using for both the ground and the hot wires to the amp. A side note: be sure to keep your ground wire very short. On the order of 18 inches or less. A long ground wire can cause some kinds of problems. Good luck.
Jan 10, 2007 | Dual 2-Channel Bridgeable MOSFET Amplifier...
404 people viewed this question
 Grubhead
Grubhead
