I have no auido device i remove it on mistake how do i install new
  • 34 Answers
Ok, locate the CD that is included with your computer. Run the CD and install the sound card driver.
Posted on Dec 22, 2008
I install new window xp its sound is not coming out in control panel sound and audio device in VOULUM written NO AUIDO DEVICE VOICE and audio are the same its off
If you were to log on to the manufacturer's web site, usually one is able to download if available, by model number, All available Driver downloads as required.
This is the best way of ensuring up to date drivers for your system and they are free of charge!
There are no XP drivers to be found with Microsoft as XP is no longer supported.
Some manufacturers may have a limited number of Drivers still listed.
I hope this helps.
Feb 04, 2011 | Computers & Internet
I am tryin to remove the factory radio from a 2000 Nissan Altima and install an aftermarket radio. but i cant seem to figure out a way to get the trim panel around the radio and HVAC module out. And i can...
  • disconnect the negative battery cable from the Altima's battery.
  • 2
    Pry up the trim panel surrounding the gear stick. The trip panel is held in place by plastic clips that will disengage when the panel is pried up. Use a flat-head screwdriver to pry up the panel. The panel doesn't need to be completely removed, just pried up enough to reveal two Phillips screws along the bottom of the radio trim panel.
  • 3
    Remove the two Phillips screws along the bottom edge of the radio trim panel, just above the gear stick. Remove the two Phillips screws from above the radio. Remove the ashtray.
  • 4
    Pry the radio trim panel loose with your fingers or a flat-head screwdriver and remove it.
  • 5
    Remove the four Phillips screws holding the radio in place. Set the screws aside for use later. Slide the radio forward and disconnect the wires from the back of the device.
  • 6
    Slide the cage included with your new stereo into your dash adapter. Slide the stereo into the cage and dash adapter.
  • 7
    Connect the wires from the dash to the back of your new stereo. All stereos have slightly different connections methods, so refer to the owner's manual accompanying your new stereo for the proper connection procedure.
  • 8
    Slide the stereo and dash adapter into the dashboard. Use the previously removed Phillips screws to mount the stereo in place. Replace the radio trim panel and gear stick trim panel. Reconnect your battery.
  • If you are putting a aftermarket stero make sure you buy a stero harness that plugs into the cars harness, on the back side of the harness you just installed will have open wires to conet to your new stero. If you cut the wires from your car to try to splice it to the new raido it can cause problems with the electrical system includeing making the transmission shift or act funny. you can pick the harness at wall-mart, car auido, best buy, or any car auido place.
  • Dec 22, 2010 | 2000 Nissan Altima
    Auido device is getting disabled every time i reboot i want fix that issue manually please help me to solve this particular problem
    REINSTALL YOUR AUDIO DRIVER WITH NEWER VERSION.ELSE RELOAD YOUR OS AND INSTALL ALL DRIVERS THAN YOU VILL GET SOLVED...
    Nov 12, 2010 | Compaq Presario C700T Notebook
    No sound after upgrade from xp to win 7 no audio device installed everything else is fine device manager says no auido devise installed please help
    need to go to manufacturer site and download chipset and audio drivers if hp go to hp.com if dell, got to dell.com .
    Dec 27, 2009 | Toshiba Satellite L20-S310TD Notebook
    I had a friend install my new Goodman GMH950704CX 95% 92,000btu 2-stage multi speed furnace. When I switch the thermostat to HEAT and turn it up to 80 degrees, the inducer fan comes on, then the igniter...
    he didnt hook up the secondary heat exchanger drain properly. common mistake and he probably threw away the bag of parts to do it which came with the furnace . loook at your installation instructions
    Sep 29, 2009 | Goodman GMS90703BXA Heater
    I remove audio drive how can back to installation
    right click u r moouse in the device manager on the audio card and re insall it
    Jun 20, 2009 | Gigabyte GA-945GCM-s2C socket LGA775...
    Microphone is not working
    check in the control panel --> system ->device manager-->sound devices, that your sound devices dont have a ! on them. If it has one then you need to install drivers for it.
    Run the hardware mic wizard in the control panel under sounds/auido devices
    Also very common is bad mic. Buy new mic.
    May 24, 2009 | Mercury Computers & Internet
    Sir By mistake i deleted sytem codecs from the add and remove buttons, pl help me out to retrive
    Delete the piece of hardware from the device manager, reboot, when it says it found new hardware re-install the driver for that hardware.
    Apr 21, 2009 | Computers & Internet
    Device Driver
    make sure you downloaded the right drivers and for the right operateing system and version then run the setup files again.
    May 23, 2008 | ASUS A6U Notebook
    Motorola headset bluetooth h500
    i can not ear auido in my head set
    i installed software than i connected my device than i can"t ear any sounds on my headset
    Apr 29, 2008 | Motorola Mobility H500 Wireless Headset
    Computers & Internet Logo
    20 people viewed this question
    Alun Cox
    David Payne
    David Payne
