I have a HP Officejet L7780 All-in-One which has recently had the top unit replaced by HP. No matter how many times it seems to try it can't get the printer aligned and gives up on it after a few minutes. Is there a common cause or solution to this?
    Genius:
  • 2,120 Answers
You must replace both cartridges with NEW ones to get a sucessful alignment.
Posted on Dec 22, 2008
Partial print on incoming fax
Check your incoming line and settings or try to reinstall the drivers. Also, check the user manual for HP Officejet Pro L7780
Jun 25, 2013 | HP Officejet Pro L7780 All-In-One InkJet...
The auto-document feeder on our HP L7780 OfficeJet Pro printer doesn't pick up the papers anymore. The 'gears' are spinning, but the papers aren't advancing. I've cleaned the rollers, but that still didn't...
I put an elastic band around the black roller as it doesnt seem big enough and it works nearly every time now. Have done this with another L7780 Pro as well which fixed it completely on that one.
Jun 09, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Hp l7780 all in one
I just purchased a hp officejet pro L7780 all in one wireless trying to set up system - was suppose to have a poster sheet to guide me -- NO GUIDE POSTER - can i view one on line somewhere at no cost -
Nov 11, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
HP L7780 compatibilty to Windows Vista
Unplug cables blow them or use can air, if this is connected wireless, then try a hard connection with cables, if it is usb, get a tansfer cable. Also check the ink cartridges, too much ink on them replace them.
I’m happy to assist further over the phone at https://www.6ya.com/expert/sherri_bf92738d7f5863ad
Jun 06, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
Occasionally bottom line of document only partially prints
Goto Office button-> Print-> properties-> Change paper size to A4
May 05, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
Open Questions:
My Ricoh 3035 / Savin 8035 prints uniformly light pages, and tells me to add toner, with a FULL toner bottle. The developer unit itself is completely packed with toner. There are no other errors set. The issue described is recent, within the last 500 copies. Prior to that this machine was running perfectly. I've had this copier for a couple of years. It was used. It NOW has 617,871 prints/copies/faxes as of today. I replaced the developer unit remanufactured and new developer at 591,810. The transfer belt and cleaning blade are new at 607,638. I replaced the PCU with a completely remanufactured unit at 607,688. The fuser was replaced with remanufactured unit also at 607,688. I was STILL having some issues with bad quality copies, so I narrowed the matter down to a defective drum in the remanufactured PCU. I replaced the drum, and at THAT time, I installed every part in the Savin Maintenance Kit PMB082150K, which I previously received with the copier. I also replaced the PCU Entrance Seal and tape the long mylar one at the top of the drum. When I installed the developer unit, I initialized the settings, pursuant to the Service Manual, and the same with the drum, and the appropriate one each time I previously cleaned the ID Sensor Today, I went through the trouble of replacing the ID Sensor, initialized the same, and it made no difference. The copier has run just fine for the last couple of months, and then as I stated in the question, about 500 copies ago, all of the copies suddenly became light. No, it's not the density setting. I've done everything except do a factory reset. Incidentally, I have the Ricoh 3035 Service Manual, and also the Parts Manual. Experientially, the only computers I have ever purchased are 2 of them, for my office, in 10 years. Other than that, I have built every computer I've ever made, from parts. As far as this copier, I have done the copier maintenance, per the maintenance schedule, myself, and when it appears that maintenance needs to be done. This problem however, is driving me nuts. As I said, the only symptoms of the light copies are that add toner light that comes on periodically, and toner absolutely packed into the developer unit entrance such that its spills out when I remove the PCU. One last thing, and this is an when all else fails kind of thing: since the toner bottle is full, I open the front door, and using a channellock, I fix the add toner problem by rapping very lightly on the end of the PCU, and the developer unit! This DOES fix the toner out problem every time, but it does NOT fix the light copies. Simply opening the door, sliding the toner carrier out, putting it back, and then closing the door, and repeating that process a couple of times sometimes also works.
Jan 21, 2019 | Ricoh Aficio 3035 Digital...
k24674
Marvin
Marvin
