Need to do a manuel reset
Played around with some of the setting and lost reception and need to to a system reset but am unable to get a picture to see the menu to do a system reset is there another method to do a system reset?
    Habit-Forming:
  • 74 Answers
Unplug receiver for at least 1 minute.
Posted on Dec 23, 2008
  • ccdhair Dec 24, 2008
    If I might make another suggestion please do not give me a two rating. I would prefer none.
    You can also try leaving it pluged in and removing the card then re-inserting it. You should get information on the screen if not a picture.
I have played around with the settings of my nikon s26oo coolpix camera and now it is taking very bad phot'os. Can Someone please help me to get back to the default settings??
To reset the camera back to the default setting, remove the battery for 15 mins, replace the battery then open the camera's Menu and set the Date & Time.
Feb 22, 2013 | Nikon COOLPIX Cameras
My kids changed the color on my 61 inch RCA and now i cant get it back to normal. Everything thats suppose to be purple is brown and pinks are orange and yellows are pale. Everything else is ok a little...
Someone probably played around with the "Tint" settings in the TV menu. The easiest way to fix it is to go into the TV picture menu and reset everything to the default settings. There's probably one option for "Reset to Factory Default" or something along those lines. Since every TV is different with this, you should read your owner's manual to find how to enter the menu and find the reset button.
May 04, 2011 | Televison & Video
Can see green, blue and red seperate pictures
That is just settings go to menu on the remote pull up MENU the find the "settings" it will say "picture" then all you have to do is get the lines in sequence so they are all even. I'm not a "tech" person but i have played around with this TV for a while..
Sep 26, 2010 | Mitsubishi WS-65869 65" Rear Projection...
Poor reception on one tv channel only rest are fine
If OTA, check that your antenna is pointing at the station's transmitter. Look at antennaweb.org or tvfool.com (antennaweb is very conservative with the stations that it will suggest that you can get. Both assume external antennas.) If you have an amplifier, check if it is working (I lost a local VHF channel recently when the antenna splitter/amplifier got a power surge after a lightning strike - despite it being the nearest station.)
Consider resetting the tv to the defaults and rescanning for channels. (The reset is under Menu > Picture Settings > Advanced Settings (if you use Customized Picture Mode; there is a second reset under Audio settings for those customized functions.)
I hope this helps.
Jun 16, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Magnavox tv has cable channels 2-13 only. Lost original remote. Using a universal remote. Tried to auto program. It started scanning but when channel 14 came around, just fuzzy snowy picture all through...
The set needs to be switched from antenna to cable in the setup menu. It is capable of either antenna reception or cable reception. Ch 2-14 are the same frequency for antenna and cable but above 14 they are different. That is why the picture is stoping at 14. After you switch it to cable auto program again. Thanks for using fixya.
Nov 12, 2009 | Televison & Video
Unable to enter convergence menu
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV2_bing.gif may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 08, 2009 | Toshiba 42H82 42" Rear Projection...
Black box showing up while viewing DVDs
This sound like a problem with the Closed Caption, on many sets if the C.C. is set to text a black box apears, and since it only happens on DVD you might look at the DVD menu and see if it has this Text featcher in the Closed Caption menu and turn it off
Feb 13, 2008 | Televison & Video
SONY DSC-W100
it can be possible to select reset icon by selecting menu option.
it is not possible to take this type of pictures because at auto flash mode the subject can't be covered witin flash range .therefore picture may underexposed however the forground within flash range may correctly exposed.If we do all this at flash off mode the motion of subject will appear  as blurred due to slow shutter speed.
Oct 04, 2007 | Sony Cyber-shot DSC-W100 Digital Camera
My Canon Powershot SD630
What do pictures taken at night/poor light look like ?? if they are an improvment ,
your Exposure/Auto-Light/White Balance settings may be horribly configured.
Firstly I'd try Resetting the camera to default settings by using the settings menu .
>Menu >Settings >Reset default settings
This should eliminate poor settings as a suspect for the problem.
Sep 28, 2007 | Canon PowerShot SD630 Digital ELPH / IXUS...
No sound
Go into the TV Menu and access the sound settings, for the UK it would normally be set to I. This MAY need to be changed to a different setting. Try the options that are listed. Might fix it!!
Jul 28, 2006 | Sanyo C40N
Televison & Video Logo
282 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
