Miele novotronic w865
Hello i have a miele novotronic w865 washing machine. the machine was set normally, the program starts and runs through the cycle but the drum doesn't turn: i've tried this several times with the same result and i've tried to reset the machine by turning off,turning dial to finish, turning on again and restarting cycle. could i do something to fix it or will i have to have it serviced? many thanks. christine
  • 61 Answers
SOURCE: water runs into tub but does not fill?
be sure the drain hose is not lower than the wash tub this will caust the water to run out, 2nd be sure the drain hose is not pushed to far into the house stand pipe and the there is rome for air to go inbetween the drain hose and stand pipe eather of these will cause the machine to siphon mostly on rince cycle or on the 2nd and third loads you do. last your house drain could be starting to back up fill the washer with water and listen to it drain if you hear a gurggling sound in the house pipe you may need a plumber to cleanthis out for you.
Posted on Jan 20, 2009
Gallois
SOURCE: Hi, i have a miele novotronic w 916 and it's not spinning
I mean this is not a filter error and i think the power main board inside on front bottom EL110 has an defekt and must change.
Or you can post the problem on my board www.avpc.de with photos for solving together and find another cheap used power board for it ...
Posted on Sep 09, 2009
reverendrave
  • 24 Answers
SOURCE: replace door seal miele novotonic w 502
Hello mc2739,
It's been awhile for me since I have done this so I searched on the internet and found the following. The instructions are pretty detailed. You may want to contact Miele if any problems
1. Open the machine door.
2. Turn the main power off and unplug the machine from the wall.
3. Completely remove the powder dispenser drawer (it will come out so far (and stop), then there is a small button at the rear of the dispenser which you need to depress to remove it fully, you'll see this button once you've withdrawn the drawer to its stop position.
5. Undo and remove the 3 x hexagonal head bolts surrounding the door seal (they are at approximately the 2, 6 and 10 o'clock positions). Note these bolts actually secure the front panel to the machine chassis, they do not retain the door seal. Don't worry the front will not drop off.
6. Now look at the aperture of the powder dispenser drawer (you have of course removed the actual drawer earlier). Locate the lower left hand corner of the aperture, and you'll see a recessed philips head screw in a hole. Undo and remove that screw.
7. Now, you'll need to get on your hands and knees. You DO NOT need to tilt, or lift up the washing machine to do the next bit. Locate the underside of the front panel right at the bottom. You'll notice that it sticks out about half an inch or so and is proud of what I would call the kick plate which extends right down to the floor. You need to look on the underside of the front panel, about an inch or so in from the left hand edge. There you will see a spring loaded clip which when closed is located within a slot on the underside of the front panel. Using a flat bladed screwdriver, you need to carefully lever the spring clip open whilst gently pulling the whole front panel (from the left side) ajar. It will just suddenly pop out once you've done it.
8. Open the pump access door lower left hand side of the front panel) and unclip the drain tube from its plastic retaining clip.
9. Now carefully swing open the whole front panel, it opens like a door (hinged on the right hand side). It might be a little stiff as there are a whost of leads attached to it, but it is designed to open fully (with the leads attached) to about 90 degrees.
10. Next, unseat the rubber door seal from around the door opening area (on the chassis, not the front panel, obvioulsy), so that the seal the flops away from the chassis and lies just inside the machine.
11. You will notice that there is a thin steel band holding the door seal in place around the drum. On the right hand side (at about the 3 o'clock position), you'ss see a tensioning screw for the band. With a flat bladed screwdriver undo this completely and remove the screw (it is accessible from above with a long screwdriver). Be aware that there is 1 x washer and 1 x 'nut' type fitting that will fall out when you remove the screw. Locate these and retain them for later.
12. Now extend the steel band to its maximum opening (by moving the 2 x lugs apart where the now removed screw was).
13. You can now remove the steel band. Then pull it out through the hole/door aperture in the chassis.
14. Locate the small rubber tag at about the 12 o'clock position where the seal is attached to the drum and tug it. The seal will then come away from the drum. Remove the old seal completely.
15. Using your new seal, place this correctly around the drum (there is a lip on the seal and this has to go over the lip on the drum. Remember, the seal goes on the OUTSIDE of the drum. Ensure the 'tag' is at the 12 o'clock position.
16. Reassembly is then the reverse of removal.
17. Make sure that you do up the retaining steel band sufficiently and that you correctly locate the sela on the chassis front panel (there is a groove in the seal which will locate the seal in the aperture).
18. Finally, once you're done, put the machine through a few rinse cycles (where the water level is high) and look for leaks. If you have a leak, it is likely that your door seal has a rip/tear, or that it has not been correctly located around the drum - in which case you'll need to investigate.
Posted on Sep 17, 2009
SOURCE: Beko wma1510s washing machine dial problem
my beko wma 1510s will not spin and is heating up
Posted on Jan 03, 2010
  • 177 Answers
SOURCE: How do I use the washing machine, a miele novotronic w 969
The I is the pre-wash and the III is the main wash where you put the soap powder. the # star looking symbol is the fabric conditioner.
If you don't have a manual you can download this from the miele website.
Posted on Jan 18, 2010
Testimonial: "Thanx for the help. I managed to get my first wash very successfully. "
Miele Novotronic w963 motor does not turn after water filling
Hello, my question is, I have washing machine MIELE NOVOTRONIC W 963, is broken, Which Miele model HAVE SIMILAR MOTOR ,thank you . William
Jan 03, 2013 | Miele Novotronic W1918A Front Load Washer
Replacing door seal on w698 miele
Normally they're held on with 2 wire rings, 1 at the edge of the seal at the door opening and the other on the edge of the outer drum. Unplug your machine and remove the lid, this will help access and give you more light to work with. Remove the ring at the door opening first and pull seal from the lip. Access can now be made for the one at the drum. Do the same for the one on the drum.
When putting in new one reverse the procedure and start at the drum, make sure you have the seal the right way around, normally holes in bottom of seal for drainage. Thread the seal over the lip and then put ring on. Same process for the front. Put lid on and plug machine in and test for leaks.
Dec 29, 2012 | Miele W865 Front Load Washer
Loud bang at the start of the spin cycle followed by drum not rotating. Suspect drive belt failed?
You're probably right. I don't remember whether this particular model has an access hatch on the back, if it does, replacing the belt should be fairly straightforward. First put the belt around the motor pulley, then use a screwdriver or similar to lever and roll the belt onto the drum pulley.
Jun 30, 2011 | Miele W865 Front Load Washer
When I start any program on my Miele Novotronic W820, the machine fills with water and drum starts to turn but after a short time the main wash light flashes on and off. I've tried clearing the program,...
you may find that the water pump is not operating properly as the first fill of water is normally pumpt out first before the wash fill is started unplug the machine and take the back panel off and locate the water pump and check if you can move the cooling fan at the rear of the pump freely if not the take the water outlet pipe off and remove whatever is stopping the rotation of the pump replace all parts and run the machine to see if the fault has been found and cleared eric
Jan 05, 2018 | Washing Machines
Hi, I have a W526 Novotronic Miele
rinse light flashing is an indication the is a problem within the motor circuit. Brushes,motor or electronic.
Dec 24, 2010 | Miele Novotronic Premier 500 Front Load...
Miele w865 - door won't open after completed wash cycle
the solenoid sounds like it is defective on the door lock or the plug has fallen out of the door lock. if you remove the sealing ring clip which holds the door seal in place and pull back the seal you can reach inside the unit and make sure the plug is in place. check also there is power to the plug
hope this helps. if all else fails call the Miele service centre in your area and they will be able to help
May 08, 2010 | Miele W865 Front Load Washer
My Miele Novotronic W 844 Washing Machine will not completely spin dry my clothes. They are soggy at the end of the wash cycle. Help please! (My machine's settings are in German.)
Hi there are 3 possible causes.
1. Out of balance load (drum is divide into 3 sections if weight i one section is greater then 1.25kg than another section will not spin)
2.Carbon brushes ( Normally good for at least 10 years)
3. Vent from drain pump blocked.(Vent left front side of soap drawer. Visible when drawer removed)
Mar 19, 2010 | Miele Novotronic W1918A Front Load Washer
The motor on my Miele washing machine is running constantly even when not set on a programme. The water seems to empty out as soon as it comes in. I Have to release the Stop /Start button to stop motor.
what motor do you mean the motor that spins the drum or the pump motor if its the pump motor i would check the programmer as it tells the pump when to run, on a rinse water evacuate cycle it would seem that you are stuck in that mode call a loacl engineer
Jan 16, 2010 | Miele Novotronic Premier 500 Front Load...
My miele machine tends to bleach my clothes.
I would run a few cycles with just water added to the bleach dispenser, clean it out, and see if that helps.
Nov 06, 2009 | Miele Novotronic Premier 500 Front Load...
Washing Machines Logo
126 people viewed this question
Top Washing Machines Experts
