Question about Canon L220 Plain Paper Laser Fax
Canon L220 Fax ##323 Check Printer
We have a Canon L220 Printer with no instruction booklet. Error code ##323 - check printer is on display and we cannot receive any faxes
  • 45 Answers
Canon manual says ##323 is the laser beam detector defective. Try to substitute the laser assembly (RG5-3497)
Posted on Feb 20, 2009
  • Graciano Leitao Feb 20, 2009
    • Printer error codes
    No. Tx or Rx Definition
    New ##0322 [ RX ] Printer (LBP) fixing unit trouble
    New ##0323 [ RX ] Printer (LBP) BD (Beam Detect) trouble
    New ##0324 [ RX ] Printer (LBP) scanner trouble
    New ##0325 [ RX ] Printer (LBP) main motor trouble
  • 34 Answers
Download the instruction booklet or manual at www.canon.com
Posted on Dec 22, 2008
Check printer(##322) error in canon fax l220
Error # 322 is a Fuser not heating error. This usually means the fuser is bad or requires a fuser module. This is not something you can test without servicing the unit, so it would need to go to Canon or an Authorized Service Center for repair.
Jul 09, 2011 | Refrigerators
Check printer error ##322
##322 is a common error and it is the fixing unit that's not warming up!U can have it replaced and fixed!
Jan 26, 2010 | Canon L220 Plain Paper Laser Fax
CHECK PRINTER ##330 flashing message
From the message board archives:
Error codes:
## 322 Fuser not heating (Usually Bad Fuser Module)
## 323 Laser Beam detect error
## 324 Laser scanner motor rotation incorrect
## 325 Fan motor inop
## 330 Power Supply (Replace/Repair)
You must turn on error management to have the machine display error codes, otherwise it will just say "CHECK PRINTER".
To turn error management on, enter the following: Press Data registration, #, Set, 00000011, set, stop. Now after the "check printer" message there should be one of the error codes above.
Supposedly, Nation-Wide Repair Service fixes the bad power supplies for $45.00. They can be reached at 800-798-1814. You can also buy one for $148.00 from www.loyal.net I hear. The proper replacement power supply part number for both the LC7000 and LC7500 is HH3-5278 so I am told.
Aug 04, 2009 | Canon LaserCLASS 7500 Plain Paper Fax
Says check printer
If there is an error code with the 'check printer' then this would be more helpful. If the error code is ~ #323 then you have a laser unit fault- if it is #322 then you have a fuser unit issue. Both units are replaced as a unit.
Jul 01, 2009 | Canon CFX-L4000 Plain Paper Laser Fax
Error message E078 on Canon MF 8100 series after replacing drum
try to check your connection form your printer and if possible try reinstall the printer driver then try to run again the printer.
Jun 16, 2009 | Laser Canon imageCLASS 8180C Multifunction...
##322 error on display
Fixing unit faulty and it can be replaced!
May 12, 2009 | Canon L220 Plain Paper Laser Fax
Error Code for Fax Canon L220
You need to service machine and may be your fixing unit is problem
> If that replace Fixing Unit
Jun 19, 2008 | Canon L220 Plain Paper Laser Fax
Keep saying check printer
5.5.3.3 ##324 [Rx] Printer section scanner motor rotation rate abnormal 0003-5251
Cause
An internal mechanism is faulty.
Remedy
1) Check the connection between the laser scanner unit (J802) and SCNT board (J6).
2) Replace the laser scanner unit.
3) Replace the SCNT board.
Jun 05, 2008 | Canon L220 Plain Paper Laser Fax
Canon L220 Plain Paper Laser Fax Logo
2,730 people viewed this question
old marine
old marine
