Question about Cooktops
Neff Hob Wiring Problem
Good morning, I have a wiring issue with a Neff hob. It was supplied without a power cable so I have to connect one myself, this in itself isnt a problem but there is a junction box on the back of the hob with 5 separate connection points. Obviously at least one will be for the live connection and another one for the neutral connection. There is also a very basic diagram showing a 3, 4 or 5 wire connection option so that confuses things further!
  • 619 Answers
SOURCE: Terminal Designation
Ok if R is live use tester volt meter 110 volts connect tester from cord terminal one tester connect to R the nmulti tester read 110 volt if ok good .
Posted on Jan 10, 2008
SOURCE: Safety lock on Neff hob
to deactivate mine is as follows (copied verbatim from the manual)
to deactivate the childproof lock is the reversal of setting it -
turn all four hotplates to setting 2
turn off all the hotplates in order from right to left
touch the main switch for at least 5 seconds, once the five seconds is up you will hear an accoustic noise.
it is now deactivated
to turn it on with the childproof lock on you have to touch the main switch for 4 seconds
Posted on Sep 29, 2008
SOURCE: Neff Hob
Hold the power button for a few seconds
Posted on Nov 01, 2008
SOURCE: Neff T4344 hob, need instruction manual???
Try http://bshappliancecare.com/Neff/customercare.html
You can download a PDF manual for the T4344
Regards
Jon Morgan
Posted on Feb 06, 2009
  • 222 Answers
SOURCE: How do i unlock my neff hob? Red key above on/off
hi gud day, more of ceramic hob is touch control,try to stay ur thumbmark wen the unlock circle to unlock if u hear the sound it means is unlock also in the other wat u want to operate,or clean the surface coz some oil is coz of not operate properly. tnx gerbee
Posted on May 29, 2009
F4 code keeps flashing the hob is not hot as I have not used for a few days
Go to this website and they have a online helper to assist you with your issue. This is free. http://www.neff.com.au/service/support/induction-cooktops/not-working
Dec 04, 2017 | Cooktops
Hob ceran replace with new induction hob
Need looking at by NEFF , a big job .
Mar 16, 2015 | Neff Cooktops
Induction hob neff T4243 has cracked will I need to replace it
Did you crack your hob by means of impact or did it happen on its own accord?
I have a neff induction hob and has just cracked in 3 directions while cooking this evening. I am just trying to determine if there is a common fault with this neff product or I am just unfortunate. Mine is under warranty and have a engineer coming on Monday, so have the whole weekend with no hob as I have been advised not to use it.
Many thanks
Feb 28, 2012 | Cooktops
Glass on neff t4243 induction hob has cracked
hi,
is it possible to replace a cracked glass on my Neff induction hob?
where would I get the glass for my Neff induction hob replaced?
is it very costly?
the model number is t4483x2/09
How do i unlock my neff hob? Red key above on/off switch wont go off! Cant use hob.
Hi I have just had the problem of accidently locking my Neff Hob.
If you hold down the L Lock button for about a minute it unlocks.
Mar 18, 2009 | Neff 23 in. T4343 Electric Cooktop
Neff T1722SO Ceramic Hob - rings don't heat
Check the power supply to make sure it is getting 220V, the lights etc might still work if only getting 120V but burner won't without full power supply.
Mar 08, 2009 | Neff Cooktops
Wiring for Neff Hob-not supplied/no wiring instructions
The details of how to wire the T1213 hob are printed on the base of the hob next to the terminal compartment. For a single cable installation, Neutral is connected to terminals 4 & 5 which should already be linked with a copper link. Terminals 1,2 & 3 should be linked together using the links supplied (hidden in the side of the terminal compartment) and Live is connected to any one of 1,2 or 3. The Earth goes to the terminal beside the cable clamp.
Nov 28, 2008 | Neff T1323 Electric Cooktop
Neff T1722 so 02 ceramic hob
its normal for the ceramic hob to ON & OFF coz of the sensor inside the unit to protect for overheating.same here in phillipines.its normal.tnx gerbee
Jul 28, 2008 | Neff 23 in. T1443 Electric Cooktop
Neff 4 ring, ceremic top hob - how do I turn on!!
You press the "on" which is on the left. Press the picture of hob you require and press the up and down for temperature. Then put your pan on the hob and it will work. If you need to adjust the temp you need to remove the pan.
Oct 15, 2007 | Neff 23 in. T1443 Electric Cooktop
Cooktops Logo
467 people viewed this question
Top Cooktops Experts
Marvin
Marvin
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
