Question about Ingersoll Rand Rotary Screw Compressor 230 Volts Single Phase 5 HP 185 CFM
7.5 tas high airend temperature
Unit shuts down on high airend temp
    New Friend:
  • 33 Answers
1. Check your oil level, top up, or totally replace it
2. Check your cooler (Radiator looking thing) blow it out with a blow gun
3. Check your thermo valve (may need replacing)
4. Is the room that your compressor is in very warm, ambient air is a big factor in the running of your compressor
5. Do you have all the panels fitted to the machine? These are needed to aid airflow past your air-end
These are the main causes of high air end temperature. It may just need a good service
Hope this helps
Posted on Aug 30, 2012
SOURCE:
IR 75I COMRESSOR AIREND DISCHARGE TEMPERATURE HIGH WHY
This problem could be due to several items. Low oil level, Bad temp.probe. Cooler stopped up or dirty and not allowing enough air flow thru it or maybe a thermostat. Also temp. in compressor area can be causing problem also.
May 08, 2017 | Air Tools & Compressors
What cuases high a/e discharge fault on ingersol rand air compressor
Dirty coolers are always associated with high discharge temps,always make sure your coolers are clean
compressor oil filters being clogged can also raise your temp n cause the unit to over heat,and on the much bigger machines if the compressor oil pump fails then you will have severe over heating as the oil flow to the cooler is assisted by the pump!!things like regulating pressure should always be adjusted to the machines specs so it doesn't over pressurize n put load on your airend while the engine is at idle.
Jun 24, 2014 | Ingersoll Rand Stationary Air Cooled...
Fire in coalescer filter
high airend discharge temp oil level to low or no cooling taking place
Mar 03, 2014 | Ingersoll Rand Rotary Screw Compressor ...
My air compressor show continusly the alarm NO CONTROL POWER
No Control power is often caused by high airend temp or a faulty High AirTemp. switch(IATS Switch i.e High Air Temperature Switch). I suspect the IATS switch is bad and opening prematurely/coolent level not suffecent or bad filter condition because the att. temp. probe located next to the switch is set to give a temp alarm and shut down the compressor at 228 degrees.The hat switch is located in the end of the airend and should have a 1/2 " flex conduit attached to it. When this switch opens it cuts control power and series to emergentcy switch having two NC connection but if press emergency it gives alram emergency but if you remove cable 36 inintellisys control pannel. Thus the controller issues a No control power . This switch is set to open at 245 degrees. If faulty it may open at 150, 180, 200. Anything but what it is set at. You can check this switch with a meter. When the unit trips simply test for 110 volts at the switch or in the control panel if familiar with wiring . please be very careful while in any electrical panel.. 110 volts in, 110 volts out. NO 110 volts out or on one leg of the switch means its bad and should be replaced.After it cools for a while the compressor will run again.
Jul 04, 2012 | Ingersoll Rand Air Compressor Maintenance...
Frequent alarms "Control power loss" Often
Control power loss is often caused by high airend temp or a faulty High Air Temp. switch(HAT Switch). I suspect the HAT switch is bad and opening prematurely because the att. temp. probe located next to the Hat switch is set to give a temp alarm and shut down the compressor at 228 degrees.The hat switch is located in the end of the airend and should have a 1/2 " flex conduit attached to it. When this switch opens it cuts control power. Thus the controller issues a control power loss. This switch is set to open at 245 degrees. If faulty it may open at 150, 180, 200. Anything but what it is set at. You can check this switch with a meter. When the unit trips simply test for 110 volts at the switch or in the control panel if familiar with wiring . please be very careful while in any electrical panel.. 110 volts in, 110 volts out. NO 110 volts out or on one leg of the switch means its bad and should be replaced.After it cools for a while the compressor will run again.
Jun 08, 2011 | Ingersoll Air Tools & Compressors
I have a 7-41 I.R. compressor. Recently serviced with 1200 hrs done. It now only runs for about 20 mins before shutting down. After 15 mins she starts again. I have tried bypassing water temp sender and...
make sure the cooler(s) are clean. Next check the airend discharge temperature switch commonly called a HAT (High Air Temp) switch. These switches will reset as the compressor cools down. I would be able to access the switch quickly. Run unit until shutdown remove wires and see if switch is open. if open you found your problem
Jun 01, 2011 | Ingersoll Air Tools & Compressors
We have an Ingersoll Rand- 100hp air compressor. We only run this periodically- when we have a power curtailment and trying to reduce power consumption or if our primary air compressor faults out. When...
replace the hat switch. hat = High Air temp. This switch is located on the end of the air end and usually has 1/2" flex conduit on it. Remove the conduit. It goes to a box located on the frame near and under the airend. Remove the cover from the box tug on the wires at the hat switch to see which two wires need to be disconnected.disconnect wires unscrew hat switch. Put a new oring on the new hat switch and install new hat switch. Hat switch is the only switch that will give high temp and lose control power. Let set a while and can reset unless probe is broken off.
May 31, 2011 | Ingersoll Rand Stationary Air Cooled...
I have a sullair ls - 120 we have been having problems with it getting hot and shuting off oil levels have been fine we have tryed different oil types we have took apart the unloader valve cleaned it and...
Get yourself a temperature gun and check a couple things:
1) Measure the oil injection temperature to the airend. This is a line going into the bottom side of the airend. 2) Measure the discharge temperature from the airend (this should be the same reading as the temperature gauge/readout on the compressor, but check to be sure)
You should get a temperature rise of about 25-30 degrees F over the airend. If you have more rise, you probably have an oil restriction: try an oil filter change.
If your oil injection temp is more than 160 degrees F or so, check the operation of the thermostatic valve. The thermo valve is a T shaped valve in the oil circuit. The oil line out of the bottom of the sump probably goes to a tee which splits flow to the cooler and the thermo valve. The oil goes through the cooler then to the other side of the thermo valve. The thermo valve should then mix the hot oil from the sump and the cool oil from the cooler to maintain the injection temp in the 150-160 degree range.
If you have cool oil coming from the cooler (should be maybe 140 F or less, and the injection temp is high, the thermo valve is bad. You can get a thermostat kit from your vendor to repair. If you've replaced the cooler, this thermo valve is probably the problem.
Mar 30, 2011 | Air Tools & Compressors
Ingersoll Rand SSR compressor shuts down loaded or unloaded with no alarm, and then shows ready to start . Will not run more than a few minutes either loaded or unloaded. installed meter on incoming power...
When it shuts down, press DISPLAY SELECT button once and use the up down arrows to see the code just before shutdown.
HIGH AIREND TEMP
HIGH AIR PRESSURE
LOW SUMP PRESSURE
PRESSURE OR TEMP SENSOR FAIL
CHECK MOTOR ROTATION
MOTOR OVERLOAD
FAN MOTOR OVERLOAD
STARTER FAULT
I am assuming this has a Intellisys controller.
Aug 25, 2009 | Air Tools & Compressors
I have a ef3 vulcan, when reaches temp, the pilot goes out.
Set the thermostat to 350 degrees,get a thermometer and put it in the oil,when the unit shuts off look at the temp of the oil.If the temp of the oil is higher then the thermostat is bad if not the hi-limit may be.Let me know.
Apr 04, 2009 | Vulcan EF3 Deep Fryer
Ingersoll Rand Rotary Screw Compressor  230 Volts Single Phase 5 HP 185 CFM Logo
579 people viewed this question
Top Ingersoll Rand Air Tools & Compressors Experts
elunsford
Joe Garcia
Joe Garcia
John Trevino
Are you an Ingersoll Rand Air Tool and Compressor Expert? Answer questions, earn points and help others
