Question about EliteGroup ECS P4M900T-M2 Socket 775 Motherboard
Usb ports usb port controller disabled...how can i enable it?
  • 781 Answers
Usually these ports are enabled when Motherboard drivers are installed you may have to reinstall your motherboard drivers
Posted on Dec 23, 2008
The USB port is not responding .
  • Well check if any of the ports or drivers are disabled
  • Go to Control Panel click on System and Security and select System.usb-port-not-responding-axg5e5uexnub0ytmax4t3nsm-4-0.png
  • Then Select Device Manager
  • In Device Manager choose Universal Serial Bus Controller
  • Select each Port double click it select Drivers Tab and check if the port is enabled/disabled
  • Enable if the text near it says "Enable the selected device"
  • If these don't have any problem then you have to restart your PC and press F2 or F12 to go to Setup page ( when your prompted to press the button or in some cases you may not depends on the PC)
  • Locate the ports option and enable it if it is disabled
Dec 07, 2015 | Computers & Internet
My laptop cannot recognize my usb port 6.1.7600.16385... i cant use it to upload my pics and download games from it, i also want to transer my files in the phone to my laptop..
first you must check in your bios settings have disabled your usb ports .if it is disabled in your bios ?? you must enabled it. if still have the same issue ?? check "device manager" option from control panel and enabled your usb ports.
open control panel -> administrator tool -> computer management -> device manager.
Sep 09, 2011 | Computers & Internet
My usb port do not work. It did not recognize any devise.
hello
Use Device Manager to disable and re-enable all the USB controllers. This lets the controllers recover the USB port from its unresponsive condition. The USB controllers represent the USB ports in Device Manager. If you are not comfortable with advanced troubleshooting, try the steps in the "Workaround" section.
To disable and re-enable the USB controllers, follow these steps: Click Start, and then click Run.
Note If you are running Windows Vista, click Start, and then use the Start Search box. Type devmgmt.msc, and then click OK. Device Manager opens. Expand Universal Serial Bus controllers.
Note You might have to scroll down the list to find this item. Right-click the first USB controller under Universal Serial Bus controllers, and then click Uninstall to remove it. Repeat step 4 for each USB controller that is listed under Universal Serial Bus controllers. Restart the computer. After the computer starts, Windows will automatically scan for hardware changes and reinstall all the USB controllers that you uninstalled. Check the USB device to see whether it is working.
hope this helps
Jan 27, 2011 | HP Pavilion dv7-1240us Notebook
My U.S.B port are not working
Pl check from device manager whether the USB ports are enabled or not. If disabled, pl do enable them.
May 23, 2010 | Acer Aspire 5100 Notebook
USB ports not working
Method 1: Use Device Manager to scan for hardware changes loadTOCNode(2, 'resolution'); Use Device Manager to scan for hardware changes. After your computer scans for hardware changes, it might recognize the USB device that is connected to the USB port so that you can use the device.
To scan for hardware changes, follow these steps:
  1. Click Start, and then click Run.
  2. Type devmgmt.msc, and then click OK. Device Manager opens.
  3. In Device Manager, click your computer so that it is highlighted.
  4. Click Action, and then click Scan for hardware changes.
  5. Check the USB device to see whether it is working.
If scanning for hardware changes fixed the problem, you are finished. If this method did not fix the problem, go to Method 2.
Method 2: Restart the computer loadTOCNode(2, 'resolution'); If scanning for new hardware did not fix the problem, try restarting the computer. After the computer has restarted, check the USB device to see whether it is working.
If restarting the computer fixed the problem, you are finished. If this method did not fix the problem, go to Method 3.
Method 3: Disable and re-enable the USB controller loadTOCNode(2, 'resolution'); Use Device Manager to disable and re-enable all the USB controllers. This lets the controllers recover the USB port from its unresponsive condition. The USB controllers represent the USB ports in Device Manager.
  3. Expand Universal Serial Bus controllers.
  4. Right-click the first USB controller under Universal Serial Bus controllers, and then click Uninstall to remove it.
  5. Repeat step 4 for each USB controller that is listed under Universal Serial Bus controllers.
  6. Restart the computer. After the computer starts, Windows will automatically scan for hardware changes and reinstall all the USB controllers that you uninstalled.
  7. Check the USB device to see whether it is working.
Jan 02, 2010 | Evesham Axis PC Desktop
The usb ports will not work,therefore the mouse nor the keyboard will work
Try the mouse in a computer where the USB ports *DO* work.
It is possible that your system does not have the correct "device-drivers" for the USB ports. Thus, those USB ports seem to be "dead".
Turn the computer off.
Connect a PS/2 keyboard and a PS/2 mouse.
Turn the computer on.
Click START
Click Control Panel
Click System
Click Hardware
Click Device Manager
Expand the "USB ports" section of the tree.
Look for "yellow" or "red" marks.
Double-click one of those "problem" devices.
Choose "Reinstall Driver".
If it asks to be able to connect to the Internet, click "yes, this time".
Hopefully, this will install the correct drivers for your USB ports.
Nov 05, 2009 | Dell 2 Button Mouse 6u226
USB ports do not work
1.) Check your CMOS/Bios settings to see if any USB ports are disabled.
2.) If not, check to see that USB ports show in your operating system's device manager or settings. Enable them if they are disabled. Otherwise, you may need to reinstall the drivers that came with your model of notebook computer.
If using Windows XP, for example, go to Control Panel, System, Hardware, Device Manager, Universal Serial Bus Controllers. If the latter is not present and you have USB enabled in CMOS/Bios, you will need to install the drivers. If "Universal Serial Bus Controllers" is present, look within to see if they are all enabled and working properly.
If not, re-install the drivers.
3.) If the above does not work, you may have bad USB ports that will require service by an authorized repair service for your notebook computer.
Oct 16, 2009 | Dell Inspiron XPS M140 Notebook
Presario A900 A976TU USB Port Issues
It may be that you need to update your drivers
Start here
Microsoft's built in drivers may not be making best use of your hardware and causing the problem you describe.
The driver may be for the motherboard and not usb.
Either way it provided you with the opportunity to update other drivers too
Aug 24, 2009 | Compaq Computers & Internet
How to can i enable usb ports with no mouse?
click control panel click system, click hardware and device manager. or you can do add hardware on control panel.
hh
Aug 11, 2009 | Dell XPS 400 PC Desktop
Vista not recognizing PowerShot S30
1. connect U r camera to Back side Mother Board USB Port not for extension or front side port.
2. Check in bios USB controllers are enabled or disabled. if disabled enable it.
3. in windows device manger check for usb controllers
Jul 01, 2009 | Canon PowerShot S30 Digital Camera
EliteGroup ECS P4M900T-M2 Socket 775 Motherboard Logo
126 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Iqbal Husain
Iqbal Husain
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
