Question about EliteGroup ECS P4M900T-M2 Socket 775 Motherboard
My usb controller is not enabled i cant use the usb ports..
  • 34 Answers
Go to the CMOS setup of your motherboard. to do it turn on your computer, and it will display in your screen to press a certain key such as del or f1 or f10 key to access the CMOS setup. once inside the CMOS setup, look for the enable USB controller. enable the USB controller then waaala. your USB controller is now working.
Posted on Dec 22, 2008
The USB port is not responding .
  • Well check if any of the ports or drivers are disabled
  • Go to Control Panel click on System and Security and select System.usb-port-not-responding-axg5e5uexnub0ytmax4t3nsm-4-0.png
  • Then Select Device Manager
  • In Device Manager choose Universal Serial Bus Controller
  • Select each Port double click it select Drivers Tab and check if the port is enabled/disabled
  • Enable if the text near it says "Enable the selected device"
  • If these don't have any problem then you have to restart your PC and press F2 or F12 to go to Setup page ( when your prompted to press the button or in some cases you may not depends on the PC)
  • Locate the ports option and enable it if it is disabled
Dec 07, 2015 | Computers & Internet
Usb wont work
check this things
1.make sure the minimum hardware and operating system requirements of the hardware to be installed are met.
2.just make sure the latest bios code is installed.
3.then make sure the usb is enabled in the BIOS. power on the system, press f1 to access the system configuration utility.click devices and i/o ports and then click usb.
5. make sure the usb controller and hub are listed in the device manager as will as any installed devices for the usb option.
6. then you can try the device in all available usb ports.if it works in other usb ports, the non working ports probably defective.
Nov 04, 2012 | Dell Inspiron 570 Desktop PC (I5707163PBK)
My laptop cannot recognize my usb port 6.1.7600.16385... i cant use it to upload my pics and download games from it, i also want to transer my files in the phone to my laptop..
first you must check in your bios settings have disabled your usb ports .if it is disabled in your bios ?? you must enabled it. if still have the same issue ?? check "device manager" option from control panel and enabled your usb ports.
open control panel -> administrator tool -> computer management -> device manager.
Sep 09, 2011 | Computers & Internet
Can't use usb ports
You can check if your USB controller is enabled. You can it by right-clicking on My Computer, and then click Manage. Click Device Manager, and then locate USB controllers. Try to right click on the device and check if it is enabled.
Jan 22, 2010 | Gateway M360X Notebook
The usb ports will not work,therefore the mouse nor the keyboard will work
Try the mouse in a computer where the USB ports *DO* work.
It is possible that your system does not have the correct "device-drivers" for the USB ports. Thus, those USB ports seem to be "dead".
Turn the computer off.
Connect a PS/2 keyboard and a PS/2 mouse.
Turn the computer on.
Click START
Click Control Panel
Click System
Click Hardware
Expand the "USB ports" section of the tree.
Look for "yellow" or "red" marks.
Double-click one of those "problem" devices.
Choose "Reinstall Driver".
If it asks to be able to connect to the Internet, click "yes, this time".
Hopefully, this will install the correct drivers for your USB ports.
Nov 05, 2009 | Dell 2 Button Mouse 6u226
USB ports do not work
1.) Check your CMOS/Bios settings to see if any USB ports are disabled.
2.) If not, check to see that USB ports show in your operating system's device manager or settings. Enable them if they are disabled. Otherwise, you may need to reinstall the drivers that came with your model of notebook computer.
If using Windows XP, for example, go to Control Panel, System, Hardware, Device Manager, Universal Serial Bus Controllers. If the latter is not present and you have USB enabled in CMOS/Bios, you will need to install the drivers. If "Universal Serial Bus Controllers" is present, look within to see if they are all enabled and working properly.
If not, re-install the drivers.
3.) If the above does not work, you may have bad USB ports that will require service by an authorized repair service for your notebook computer.
Oct 16, 2009 | Dell Inspiron XPS M140 Notebook
How to can i enable usb ports with no mouse?
click control panel click system, click hardware and device manager. or you can do add hardware on control panel.
hh
Aug 11, 2009 | Dell XPS 400 PC Desktop
Why isnt my computer detecting my sansa mp3 player?
Check the usb port is enabled .
Go to Run and type "Devmgmt.msc" and press Enter.
Go to Universal Serial bus Controller. See if there are any red colored cross? If yes, right click and enable those USB Ports.
If it is enabled try with other usb ports . If it is not detected go to control panel ->add hardware to detect the player .
Hope this helps .
Mar 08, 2009 | SanDisk Sansa e260 MP3 Player
Usb ports
Usually these ports are enabled when Motherboard drivers are installed you may have to reinstall your motherboard drivers
Dec 22, 2008 | EliteGroup ECS P4M900T-M2 Socket 775...
External hard drive cannt detect
Could you let me know, what happens when you insert the External HD in the USB port............and also go to Device Manager and check if their is any Yellow exclamation mark across USB Controllers......if so, then Right click and uninstall all the USB ports and Restart the Computer.......If you see a RED mark, then just Right Click and Select Enable.....just follow the steps as given....and let me know...Take care
Jul 31, 2008 | Computers & Internet
EliteGroup ECS P4M900T-M2 Socket 775 Motherboard Logo
66 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Computer Links
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
