Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
Not responding I have a 2.0 micro Cruzer. It was working alright up until the other day. Now it is not recognized on the computer when i plug it in (i have tried two laptops and two desktops). I have a lot of info on it that i need desperately. The light does not come on and i do not know what happened to it. any suggestions?
  • 2 more comments
  • Anonymous Jan 01, 2008
    My SanDisk 2Gb Cruzer was working for a number months and sudenly is not recognized by my XP computer, except one power flashing once I plug in. Thanks for any suggestion to recover data.
  • linford Jan 04, 2008
    I have the same problem with my 2gb cruzer, when i plug it in it doesn't read thanks for any solution.
  • Anonymous Mar 31, 2008
    same here
  • bigcarm2002 Apr 01, 2008
    Suddenly, the Sandisk micro drive won't light up, and no computers will recognize it in any port. Not after reboot, not on different operating systems, not after running virus scan, not after anything. The problem is not any computer, then, it's the product. So, my thinking is that Sandisk just made a crappy product that gives up the ghost quickly.
Have a 2.0 micro Cruzer. It was working alright up until the other day. Now it is not recognized on the computer when i plug it in (i have tried two laptops and two desktops). I have a lot of info on it that i need desperately. The light does not come on and i do not know what happened to it. any suggestions?
Posted on Apr 23, 2008
Kring. I just had the exact same thing happen to my 4.0 G micro cruzer. It just seems totally dead for no apparent reason. I also have tried several other computers. Did you ever find an answer? I think I will just have to buy a new one or look for a different manufacturer.
Posted on May 07, 2007
    Problem Solver:
  • 46 Answers
Http://windows.ittoolbox.com/groups/technical-functional/windows-xp-home-l/xp-wont-recognize-my-flash-drive-1129063 try that link sir!
Posted on Apr 08, 2007
SOURCE:
Cruzer will not open, it will hang the computer
If all the hardware is working proprely (Cruzer, USB ports, ) I know of one instance where a SanDisk will not open, namely if the security feature is activated and you are using the key on Linux or MacOs.
Also, if you have reformatted it to NTFS (instead of the original FAT32) it might not be recognized by LINUX and MacOS
I would suggest you turn your compturer on until your operating system is fully up, then plug in the Cruzer. The OS should recognize it. If it does not then maybe the key is defective.
Try also to access it on some other computer.
Hope that helps
Aug 20, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Cruzer Micro 4GB will not light up or be recognized
You used the drive for 12 hours. maybe it was damage due to overheat.
when you plug the drive, did you hear a beep?
Aug 14, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
My cruzer micro lights up, but not recognized by my computer
Turn off CPU, Unplug Power cable, And all usb devices, let it sit for about 20mins. Plug it all back in. Turn on the CPU! Also make sure if your device requires "DRIVERS" or if you have a CD download and install that before anything.
Mar 23, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Heating up, light not coming on
cruzer micro 4GB, loaded with data. works perfectly in all systems except my xp. Problem didn't originate until after ghosting system to correct different problem. Now, error message states flashdrive not recognized. must then get behind pc, and gently work with it until i can hear the shift in the duo core processors and the orange light on the flashdrive comes on. Please help.
Mar 10, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
My 2GB U3 Cruzer is not recognized by my Vista laptop
here is the solution
1 correct soldering all the four junctions power, earth(ground),two data terminals.
2 replug
3 if still shows no recovery but drive shows in my comp , then do a data recovery with softwares from the net.
4 if still no recovery send it to data recovery expert.
Feb 01, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Sandisk Cruzer micro 4 gb
try to connect it firs to other computer, if other computer can detect it,format it..if not,that means your sandisk wont be usable anymore.
Oct 16, 2008 | SanDisk Cruzer Micro MP3 Player
Not responding
i do not know if you solved the problem some of those little micro cruzers have sliding locking switch that slide back and forth to lock it no one else can use it.. take real close look at it see if it does that might help you use it....
May 24, 2017 | Sony 1GB Micro Vault Ultra Mini USB 2.0...
WON'T RECOGNIZE OWNERS LAPTOP
Reformat the drive then it should be fine.
It would work.
Jul 06, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Nothing comes up on PC
Put into USB. Open up my computer and click on c: and "arrow back" until you see "removable divice". This is your removable USB disk. Let me know what happens.
Jan 30, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk 4GB cruzer URGENT problem! Please, please help! :)
it may have overheated and became stuck. Stick it in a plastic bag and put it in the freezer for 1/2 hour then try it. Do not leave it out without power for long or moisture will condense on it.
Nov 28, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
1,105 people viewed this question
Top SanDisk Computers & Internet Experts
Alun Cox
k24674
Damen Wong
Damen Wong
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
