Question about Lexmark X3480 All-In-One Printer
How can I get rid of the Fax facility.
I do not get any faxes sent to me, yet every time the phone rings there is interference because the all-in-one is receiving a fax. It is getting very annoying and I cannot find any way to disconnect the Fax facility without losing connection to the internet which is through my phone (not wireless). Is there a way of eliminating the fax from the other printing, photocopying and scanning. I DO NOT WANT THE FAX FACILITY INSTALLED ON MY COMPUTER - PLEASE ADVISE ME HOW TOI DE-INSTALL IT.
  • 34 Answers
Click start / settings / printer and faxes. once there delete the fax icon.
Posted on Dec 22, 2008
Will not accept incoming faxes
Have you set the Fax to Auto-answer or is it waiting for you to manually answer the fax? Change this by pressing Setup and Press 3, Press 3 again. Press the right arrow to toggle On or Off.
Make sure that the rings to answer is set appropriately. Press Setup 3 4 to change.
If you have a PBX or ISDN converter phone system, check that you are using the correct phone jack - for phones and faxes.
Do you have a voicemail service on the line? This will force you to receive faxes manually and only when you are present.
If you have an answering machine connected to the line, check that the answering machine is not the problem by disconnecting it and trying to receive a fax. Long welcome messages can make the calling fax machine hang up early. Insufficient time between the end of the message and the beep can make it impossible for the OfficeJet to spot the fax tones; the same is true with loud messages.
If this is the problem, record your message again, keeping it short (10 seconds but speak softly and slowly).
If you have a distinctive ring on the fax line, make sure that the OfficeJet is programmed to recognize the ring (some ring patterns cannot be interpreted and you'll need to contact your phone company to change it).
Check that other computer hardware is not causing an issue (modem with auto-answer, other interference). Unplug everything except the OfficeJet and try to receive a fax to check for interference. Then reconnect one item at a time and try getting a fax again to determine which item is causing the probelm.
I hope this helps.
Apr 08, 2010 | HP 5510 4-in-one Printer
Cant send fax
Go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set. Make sure the phone wire which you insert in fax machine getting proper dial tone and getting out going calling facility.
Have a nice day and do not forget to rate please...!
Mar 17, 2010 | Samsung SF-565PR/XST Printer
Can't receive a fax
Mar 15, 2010 | HP OfficeJet 6210 All-In-One InkJet...
I have an Office BX610FW printer/copier/fax. I
You just need to change the Rings To Answer option so that it is the maximum 9 rings. This means that that the phone will be allowed to ring 9 times before the fax answers the call. This option is found in the Setup menu, under Communications and then Rings To Answer. Hope that helps.
Regards,
Epson
Dec 01, 2009 | Epson Office Equipment & Supplies
No ring tone canon jx200
sounds like you have phone problem call local phone company to check out line
Jan 13, 2009 | Canon FAX-B160 Plain Paper Bubblejet
Is my fax shutting off?
Make sure your your phone line is ANALOG not DIGITAL
Jan 09, 2009 | HP LaserJet 3055 All-In-One Printer
How to de-install the FAX on my Lexmark all-in-one.
Scroll through the menus and set your fax to MANUAL MODE
Dec 28, 2008 | Lexmark X3480 All-In-One Printer
Setting personalized ring
Its called distintive Ring. This is the instructions from the manual -
VERY IMPORTANT
If you have Voice Mail or a TAD (Telephone Answering Device) and want to keep
one of your phone numbers dedicated only to fax calls, you must leave the fax machine
in MANUAL mode at all times while using the distinctive ring feature. Here’s why:
Manual mode will never pick up a call by itself, since it is «Neutral ». When the fax
machine is in this « neutral » mode, the Distinctive Ring Feature can be activated. The
distinctive ring feature is actually an answering mode. So, do not activate FAX ONLY
mode or FAX /TEL mode while using distinctive ring; otherwise, the fax machine will
answer calls for all the numbers.
Registering the Distinctive Ring Pattern
Set the fax machine to MANUAL mode.
2 Press Menu/Set, 0, 1.
3 Press to select DISTINCTIVE:SET?, and then press Menu/Set.
4 Press to select the prestored ring pattern you want to assign, and then press
Menu/Set. (You will hear each pattern as you scroll through the four patterns.)
Be sure to choose the pattern assigned by the Telephone Company.
5 Press Stop/Exit.
and a link to the manual if you need it -
http://static.tigerdirect.com/pdf/brother-IntelliFax-775-Manual.pdf
Feb 21, 2008 | Brother IntelliFAX 775 Plain Paper Thermal...
Lexmark X3480 All-In-One Printer Logo
251 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
