For a few weeks, I could not turn off my monitor. Everything else worked just fine so we kept the monitor on. Power went out today and now I cannot turn monitor back on. How can I fix the power button?
SOURCE: Samsung 913N Monitor went out after a power outage.
try a known good monitor on the PC, is the light blinking green or orange?
www.aa1consuling.com
SOURCE: Power Button Light Flickers, wont' turn on
Your monitor has a common problem, the power supply board is blown. Because of the heat trapped inside the monitor parts called capacitors have been damaged. We have a repair guide on our web site for the Samsung 214t series and your 204 is very similar and they use the same parts to repair them. Check out our site at: www.ccl-la.com/badcaps.htm
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
SOURCE: The monitor does not turn on.
there are only two parts involved in this one is main board and another inverter power board. and these requires service centers help. Please get assistance from only authorised service center.
SOURCE: Monitor blinking on and off. I had this problem
Please read below if you decide to DIY:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
SOURCE: samsung Syncmaster 205 BW,screen went black,power
Please look for bad caps as shown in my pictures, http://s807.photobucket.com/albums/yy352/budm/Samsung%20205BW/
Common problem on all LCD monitors.
