Question about HP DesignJet 488ca InkJet Printer
HP Designjet 488CA cartridge error
Please help. In the error group the Cartridges light keeps blinking and I can not print.I have removed all the cartridges and cleaned the contacts and print heads with alcohol.I have restarted the printer multiple times. nothing seems to work.Is there a way to reset the printer to its default status,I bought this machine used and I have no manual.I would appreciate any suggestions.
  • bobcolum Sep 02, 2008
    We are experiencing the same cartridge error (light blinking) on a used plotter. We replaced the black cartridge and it was printing the test plots fine. While printing a 11X 17 test plot the paper hung up and the cartridge light started flashing. I removed each cartridge (all original HP) put the original HP black cartridge back in and restarted several times. I can print the "black cartdridge test" successfully but the "color cartridge" test does not print. The operations manual indicates that the issue could be a bad cartridge but all of them have ink. It seems that only "all black"
eagle338
  • 4889 Answers
SOURCE: will not print at all
You can try restoring the printer to factory settings..and try agian it has worked most of the times for me..Let the catridge be in the printer when you do this..
Posted on Oct 27, 2007
SOURCE: remove and check color cartridge error
i was woundering are these new cartages or refiled ?
cause our wont work with refilled caratages
so this is how i found that out !
Issue After you install a print cartridge, the scan, copy, and fax lights begin to flash at the same time. The printer will not print. One of the following error messages may display on the control panel:
  • Color or Right Print Cartridge is not compatible
  • Incorrect Print Cartridge(s)
  • Print Cartridge Problem
  • Incorrectly Installed Cartridge(s)
  • Black or Color Cartridge(s) Failed
Solution Follow the steps below until the above issue is resolved. All of the following steps may not be necessary to resolve the issue. When the lights stop flashing, the issue is resolved. NOTE: Either one or both of the cartridges could be causing the problem. Step one: Remove, inspect, and reseat the problem cartridge The print cartridge may not have full electrical contact with the printer. Removing and reinstalling the cartridge may help. NOTE: HP cannot guarantee the quality of remanufactured or refilled cartridges.
  1. Make sure the printer is on. Press the Power button if it is not lit.
  2. Open the printer cover, and then wait until the print cartridge carriage is idle and silent.
  3. Press down lightly on the end of the problem cartridge to release it. Figure 1: Removing the tri-color cartridge c00838141.gif
  4. Slide the cartridge out and inspect it. CAUTION: Do not touch the copper electrical contacts or the ink nozzles. Figure 2: Electrical contacts and nozzles c00838142.gif 1 - Copper electrical contacts 2 - Nozzles
    • Check the electrical contacts for debris.
    • Make sure all the clear nozzle protective tape has been removed. CAUTION: Do not attempt to remove the copper electrical strip. Figure 3: Removing the clear nozzle protective tape c00838143.gif 1 - Protective tape
    • Look at the number on the print cartridge label and make sure it is compatible with your printer. Compatible print cartridges are listed in the Printer Reference Guide supplied with your printer.
  5. If the cartridge is compatible, reinstall it in the printer:
    • Color cartridges go into the left carriage slot.
    • Black cartridges go into the right carriage slot. Figure 4: Sliding cartridge into place c00838144.gif
Step two: Clean the problem cartridge contacts If the steps above did not solved the problem, follow the steps below to clean the electrical contacts on the print cartridge and in the carriage in the printer.
  1. Gather the following items to clean the cartridge and print carriage:
    • Clean distilled water. Use bottled or filtered water if distilled water is not available. Tap water may contain contaminants which could damage the cartridge.
    • Clean cotton swabs or any soft, lint-free material that will not stick to the cartridges (coffee filters work well).
    • Sheets of paper or paper towel to rest the cartridges on during cleaning.
  2. Open the printer lid and wait until the print cartridge carriage stops moving.
  3. Remove the cartridge and place it on a piece of paper with the nozzle plate facing up. NOTE: If you are removing a print cartridge, try to clean the contacts quickly enough that the cartridge is not outside of the printer for more than 30 minutes. The ink can dry and clog the nozzles if the cartridge is outside of the printer for too long.
  4. Unplug the printer.
  5. Dip a swab in the clean water, and then squeeze it to remove most of the moisture. The swab should be only slightly damp.
  6. Clean the print cartridge contacts. The illustration below shows the contacts. Do not touch the nozzles. Figure 5: Electrical contacts c00838145.gif
  7. Clean the contacts in the print carriage, inside the printer. The illustration below shows the carriage and the contacts.
  8. Either let the cartridge sit for several minutes to allow the cleaned area to dry, or use a new swab to dry it.
  9. Reinstall the cartridge, plug the printer back in, and close the printer cover. Figure 6: Print carriage contacts c00838146.gif
Step three: Repeat reseating and cleaning steps If the problem is not solved, repeat the reseating and cleaning procedures above.
Posted on Apr 07, 2008
secretgeek50
  • 57 Answers
SOURCE: HP PSC 1315 All-In-One InkJet Print Cartridge Error
Hello -
Did you perhaps not mean to post under the 1315? I am not sure if you have this printer or another model. The 1315 normally takes a different number ink cartridge.
Meanwhile - gotta tell you that the 1315 is the buggiest printer I ever had. If you purchased it recently and can find your receipt, I'd take it back! Since they've pretty much done away with the 1315, if it was a recent purchase, it was likely a clearance item from some place.
Try taking all the ink cartridges out, uninstall the printer entirely, and reinstall it (the entire printer, not just the cartridges). Blow your printer out with canned air as well - dust, pet hair, people hair, fuzz and general paper fibers can build up more than we think, and cause error messages and other printing problems.
That should help, if it was the 1315 model.
That being said, note that if it still doesn't work, and you have the 1315, save yourself a lot of grief and toss it in the trash and buy another cheap printer! 1315 is Bug City!
Posted on Jun 12, 2008
gisvc
  • 40 Answers
SOURCE: hp 3180 print cartridge light blinking
hi,
is the ink cartridge you replaced hp brand or did you refill it this is an incompatibility code from the software. some brands and cartridges are not fully compatible and creates an e code error code. if it is hp brand it is likely a defective sensor chip in the ink cartridge. i would for best assurance return the cartridge for a different one and then recheck. if niot you may need to restore your software or reinstall it most of the time this will fix the problem.
hope this helps..happy computing!
Posted on Mar 30, 2009
Comp-U-Doc
  • 148 Answers
SOURCE: Blinking lights plus E sign for cartridge error -
Look carefully to make sure there is no paper jammed inside. Sometimes there can be a small piece of paper that tore-off in the gears causing a paper jam.
If you are satisfied with my answer, be sure to click on the "Thumbs-Up". If you have further questions, please feel free to ask them. Thanks for using our service!
Posted on May 11, 2010
Designjet 488ca printing streaks
Please follow the link :
http://h20000.www2.hp.com/bc/docs/support/SupportManual/bpp02529/bpp02529.pdf
Mar 21, 2013 | HP DesignJet 488ca InkJet Printer
HP Photosmart 7400 once switched on goes to printer busy but will not print
HI,
Please reinstall your drivers.You can go to control panel,add/remove programs and uninstall your printer driver.
Sep 04, 2008 | HP Office Equipment & Supplies
My printer lights ( all three) are blinking with error message of "cartridge problem" I have tried to replace the cartridge with no success and cleaning the cartridge but no luck. Please help.
In this case you will need two new cartridges to identify the problem.
Take one new color cartridge and one black. Now, remove both the old cartridges and install the new ones and restart the printer.
Most probably your issue should be resolved.
Please ensure that you are using the following cartridges only.
Print cartridge information Part name Part description Product number Print cartridge Black HP No. 15 (equivalent to HP C6615 series) Print cartridge Tri-color HP No. 78 (equivalent to C6578 series)
Apr 08, 2011 | HP DeskJet 920c InkJet Printer
My 450c suddenly developed a problem with the cartridge light flashing,I've tried changing the 4 catridges cleaning and pressing all the buttons to no avail I can't get the machine to do anything.Has...
John I suspect that the cartridge light is flashing too. Raise the cover to service the print cartridges, remove one cartridge at a time and reinsert it. While doing that watch the ready light. It should blink 3 times even with the lid raised to acknowledge a good cartridge. If one by one all the cartridges give 3-flash ready lights then the problem may not be cartridges or they may not be primed.
Nov 12, 2010 | HP DesignJet 450c InkJet Printer
Ink light blinking and printer not printing
Did you remove the tape from the new cartridges? Are they HP cartridges?
Jun 27, 2009 | HP PSC 1410 All-In-One InkJet Printer
Hp 1410 all in one keeps saying prin cartridge error
Follow the steps given below and check for the results
=== Cleaning the ink Cartridges ===
Even if the cartridge is new, follow the steps below to clean the print cartridge contacts. Print cartridges have a substance on the contacts to keep them from corroding during storage that may cause poor electrical contact between the print carriage and the print cartridge.
  1. Verify that the product is turned on. NOTE: If the HP product is not turned on, you will not be able to remove the print cartridges.
  2. Open the unit to access the print cartridges.
  3. After the print carriage (the part that holds the print cartridges) stops moving, unplug the power cord without turning off the unit using the power button. If you turn the unit off the print cartridges will be capped to prevent them from drying out and you will not be able to remove them. You must unplug the power cord to prevent the print carriage from moving.
  4. Remove both print cartridges.
  5. Verify that the part number on the cartridge is the correct part number for the unit.
  6. Using a cotton swab or lint free cloth (like a coffee filter) lightly moistened with distilled, filtered, or bottled water, clean the electrical contacts of the cartridge. Figure 1: Electrical contacts c00055424.jpg NOTE: When an all-in-one is used frequently for black and white printing but infrequently for color printing (for example, an all-in-one that is used primarily as a fax machine), the color cartridge will still eventually fail and need to be replaced. The pins in the print carriage can cause dents on the contact points of the color cartridge over time (usually between six and twelve months).
  7. Wipe the contacts with a dry, cotton cloth, as shown, to dry the contacts and finish cleaning. Figure 2: Wiping the contacts c00055425.jpg
  8. Reinsert the cartridges and lock them in place.
  9. Close the top cover or access door and plug in the power cord.
  10. If the error continues, repeat these steps. If further cleaning fails to clear the error, proceed to "Step two: Cleaning the print carriage contacts" below.
Step two: Cleaning the print carriage contacts Have the following materials available to clean the print carriage contacts:
  • Cotton swabs or any soft material that will not come apart or leave fibers.
  • Distilled, filtered, or bottled water (tap water may contain contaminants that can damage the print cartridges) CAUTION: Be careful not to get ink on hands or clothing.
Do the follow to clean the cartridge contacts inside the product:
  1. If the unit is off, turn it on.
  3. After the print carriage stops moving, unplug the power cord. Do not turn the unit off before unplugging the power cord.
  5. Using a cotton swab or cloth lightly moistened with distilled, filtered, or bottled water, clean the electrical contacts of the print carriage as shown below. Figure 3: Cleaning the carriage contacts (your model may look slightly different) c00130268.jpg
  6. On models equipped with locking latches, lower the latches. Figure 4: Latches in the lowered position (your model may look slightly different) c00055427.jpg
  7. Wait five minutes for the contacts to dry and then plug in the power cord. The unit will begin to reinitialize. Wait until the process is complete before proceeding.
  8. Reinsert the print cartridges when prompted and then close the top cover or access door.
  9. If the message recurs, replace the print cartridge indicated by the message. If you are using refilled or remanufactured cartridges or non-HP cartridges, replace them with new HP cartridges. HP cannot guarantee that refilled or non-HP cartridges will function correctly in HP products. If a new HP ink cartridge is defective, return it to the place of purchase with the receipt, or contact HP to obtain a replacement.
  10. If the problem still exists, replace both print cartridges. Since the cartridges are electronically connected through the printed circuit board, the cartridge not indicated in the message might be the causing the failure
If the issue still persists then try the following steps to identify the problem ink cartridge
1. Remove both the ink cartridges
2. Insert the Color ink cartridge first and close the ink access door
3. Check if you are getting any error message or the ink cartridge light is blinking
4. Now remove the color ink cartridge and then insert the black ink cartridge and close the ink access door
5. Check if you are getting any error message or the ink cartridge light is blinking
Replace the problem ink cartridge anc then check
May 17, 2009 | HP PSC 1410 All-In-One InkJet Printer
All lights keep blinking!tried unplugging and reinstalling.Dead?
If the Resume c00121686.jpg light continues to blink and the print cartridge cradle does not move to the right side of the printer, try these solutions:
  • Remove and reinstall the print cartridges. Verify that the print cartridges are in the print cartridge cradle before pushing them forward into position.
  • Verify that no obstruction prevents the print cartridge cradle from moving freely on the rod.
  • Verify that the vinyl tape has been removed from each of the print cartridges.
If the problem persists, contact HP Customer Care.
Jan 14, 2009 | HP Photosmart C3180 All-In-One InkJet...
Orange cartridge light error keeps on blinking!
clean the carriage home
check the data cable for the carriage home
check the media sensor on the left of the plotter media bar
Mar 12, 2008 | HP DesignJet 450c InkJet Printer
Hp designjet 430
This usually is solved by removing and reinstalling the ink cartridges...make sure the electrical contacts are clean (use a dry paper towel) on both the print cartridge and the carriage.
If the error still happens then the carriage or trailing cable are bad and will need replaced.
Nov 28, 2007 | HP DesignJet 430 InkJet Printer
HP DesignJet 488ca InkJet Printer Logo
344 people viewed this question
Clive
Clive
