Question about Akai PT4799HD Rear Projection Television
Akai pt4799hd service code
I read another post of some one asking for the service code, but he was shot down. Does any one know the service code for the PT4799HD? I would like to do some geometry corrections, and i can not find a reliable service manual. Is it a remote feature, or a buttion combo on tv turn on?
Thank you :)
  • 4 more comments
  • Joesipaq Dec 23, 2008
    yes, that was the first thing i did - i though it would be the easy way out... And all the resistors are within tolerance, the most out is about 2% below, but I re-organized them to even out with a higher one so -2% and a +2% one because they are in parallel. As for the fuse, i can only assume it is working... the convergence is off only by so little, and the perfect focus had a broken off sensor so that it would not work. It then gave me the SEE FACTORY DATA error... and that ever since. So the service code would be much help.
    Thank you :)
    i was also wondering, about another TV i am working on, if it has stk392-110s in it, and i need to replace them, what should i replace them with? i could simply get 110s but i have been reading that upgrades are possible - for the heating issues because they can handle more wattage
    Thank You :) And I always buy The ICs in a bundle of 2. I don't want to have to open it up in a couple more months because I was too lazy to do it right the first time!
    Thanks again!
  • Joesipaq Jan 10, 2009
    This tv since i got it also- when i try perfect focus, has said- SEE FACTORY DETAILS, and will not continue. Any ideas how to fix this?
    I tried to run the perfect focus from the service menu, which worked, then add/del but it did not keep it in memory.
    yes there are ladywinn and you are one, thank you!
    But in regards to the addition of my question, do you know?
    Thanks, and i have been letting my friends know :)
  • ladywinn
    ladywinn May 11, 2010
    Has the STKs been replaced?If not replace both of them.Then try convergences.If already replace and still needing to aline ,let me know and i will give you service code.Also have pico fuses and resistors been CK?
  • Akai Master
  • 5,138 Answers
STK392-110s Do Not hold up some get so hot the pins fall off of them, USE STK392-180s always replace Both of them!
SERVICE CODE - Press Mute-1-8-3 with set on !
OK now use vol- and vol+ and ch- ch+ to adjust up&down-------- mute to stop where you need to ajust Press menu to adjust When done with alinement Press ADD to save your adjustments/ to change colors (7)sets RED (8) GREEN (9) BLUE.
Posted on Dec 23, 2008
  • 1 more comment
  • ladywinn
    ladywinn Dec 23, 2008
    Press (7) for RED Press (8) for GREEN Press (9) for BLUE
  • ladywinn
    Just in case Found another way to Enter Service Menu
    Turn set OFF with handunit PRESS Mute 1-8-2 power.
  • ladywinn
    ladywinn Jan 10, 2009
    Thank You for Using FIxYa Tell all Your Friends When in need of Help to a Problem This is the Place to come to for Correct Answers! I ll Bet This Made your New Year. Their is Alot of Good People Here Who do try there best to Help.
What is the price range?
I'm afraid nobody can decide that, but you. I'd suggest looking up your model on ebay and/or amazon and see what those are listed for. Price yours accordingly.
Mar 30, 2014 | Akai PT4799HD Rear Projection Television
Akai PT4799HD "Mode not supported"
If its HD the set is only HD ready which means it does need a compatable box.
Dec 04, 2012 | Akai PT4799HD Rear Projection Television
Where can i get a akai pt4799hd replacement bulb
Tries website Tv repair, to buy the bulb.
Mar 26, 2010 | Akai PT4799HD Rear Projection Television
Where can i get a convergence chip for PT4799HD akai tv?
I'm fairly certain that particular Akai model contains Samsung parts. You can contact Samsung at 1-800-726-7864 to check pricing and availability of the part you seek.
Jul 12, 2009 | Akai PT4799HD Rear Projection Television
Pt4799hd akai projection tv is all orange
check the brightness control on the three colors controls, they could be off.
May 05, 2009 | Akai PT4799HD Rear Projection Television
Pt4299hd wi game compatible?
The answer is yes. I have the PT4799HD and the wii system and it works just fine. It is currently hooked up to the analog audio video input . But a HD cable is available for the wii as an accessory.
Feb 21, 2009 | Akai PT4799HD Rear Projection Television
Need akai pt4799hd setup code
Do NOT attempt to enter the service mode to align convergence if you cannot align the convergence with the user's menu. If the convergence cannot be corrected with the user's menu, it means that one of your convergence IC's has burned out and possibly burned out the fuse next to it. If you change any settings without first replacing the bad parts, you will only make things much worse. I believe that set is actually a Samsung, and has the 2 convergence IC's on their own board mounted above the small signal board. If you do not know how to identify and replace shorted convergence IC's, allow a qualified tech to handle it for you.
Sep 03, 2007 | Akai PT4799HD Rear Projection Television
Burning smell and distorted picture
One of the components in the horizonatl deflection circuit went bad like a capacitor,the price will depend on the actual part that went bad and your location,the service call in NY could be 300.00 but in pittsburgh might only be 150.00.I still belive is wort repairing.
Oct 18, 2006 | Akai PT4799HD Rear Projection Television
Akai PT4799HD Rear Projection Television Logo
334 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
