Question about Microsoft Xbox 360 Console
One red light appears no picture
One red light appears and then a message saying contact microsoft on my xbox 360
    Genius:
  • 1,234 Answers
Hello sir
Solving Your Red Light Flashing:
1) Remove your hard drive and/or memory units.
2) Run "Initial Setup" under the system blade.
3) Decline inserting HDD or memory unit when prompted.
4) Sync your controller and pop in a game.
Please Rate
Posted on Aug 27, 2010
I am having a problem with my xbox360. a single red light problem and also in game,picture gets blurred and pixels gets stretched....help
If you get the Xbox 360 1 red light message, it means that the problem is either with the DVD drive, or with the hard drive.
Fortunately, the Xbox 360 1 red light message is not something that you should worry about. In order to identify which of the two drives the Xbox 360 1 red light messages is referring to, just look the code number that the screen displays. DVD drive errors are identified with the codes E64, E65 and E66, whereas hard drive errors are identified with codes E67, E69 and E79.
Once you identify which error the Xbox 360 1 red light message is pointing to, fixing it is really easy. The guide available at Fix-xbox360.info will tell you what to do in each case, as well as what to do in case you get any of the other Xbox 360 lights messages. Check it out.
Jan 08, 2011 | Microsoft Xbox 360 Console
My xbox 360 was saying error e74 now it will just turn on but screen is blank.pls help me
Nov 15, 2010 | Microsoft Xbox 360 Console
When I turned on my system, it had system error contact xbox customer support. There is a red light flashing on the bottom right, around the power button. I don't know what to do. Please help.
Some of us suddenly when we turn on our Xbox 360 console one day we got one red light flashes on the ROL (Ring of Light) around the Xbox 360 power button, and we got an Error message appearing on the TV screen "System error" also might occur with any error code like E66, E67, E68, E71, E74 or E77, all the same.
When you get any of these messages appearing on your screen with one red light flashing on the ROL of your Xbox 360 console that's an indicator of a hardware problem with the console connection to one of the parts connected to it as the hard drive or cables.
So, first disconnect all power and AV cables from the back of your Xbox 360 console and also unplug the power cord from the wall socket, wait for a minute then reconnect them all back and try to turn on your Xbox 360 console once more.
If that doesn't work, it seems then to be a fault with your Xbox 360 hard drive so turn off the console again and remove the hard drive then turn on your Xbox 360 console without the hard drive, supposed then to work fine, it might be an intermittent issue and when you reconnect the hard drive your Xbox 360 will work fine all after, or it will just work fine without the hard drive so it will be then definitely a fault with your Xbox 360 hard drive so call Xbox 360 customer support to exchange the hard drive for you.
The Xbox 360 console might even keep giving you the same error code even after you remove the hard drive so it will then appear to be a fault with your Xbox 360 console not the hard drive & also in a case like this we need to contact Xbox 360 customer support to exchange the console.
Read more: http://xbox360help.blogspot.com/2007/03/one-red-flashing-light-xbox.html#ixzz14pQlSds6
Nov 09, 2010 | Microsoft Xbox 360 Console
My xbox 360 shows one red light on the bottom where the x is and an error message pops up. what should i do?
You are suffering a hardware failure im sorry to say, If you get the red ring in the player three section, at this stage i recommend contacting microsoft and checking the warranty status of your console. I hope this helps. Good Luck.
Nov 22, 2009 | Microsoft Xbox 360 Console
1 red light on my xbox 360
Contact microsoft because its an error sign, unlike if it was 4 red lights.
0800- 587- 1102
that is the uk number
Good luck
Apr 23, 2009 | Microsoft Xbox 360™ Premium White Console
Xbox360 and the 3 red lights
Three of the lights on the Ring of Light on the front of your Xbox 360 console flash red View products that this article applies to. if (!loadTOCNode) {var loadTOCNode = function(){}} Expand all | Collapse all if (kb_page_object) { kb_page_object.kb_imageExpandHoverText = 'Click to expand this image'; } SYMPTOMS Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360... loadTOCNode(1, 'symptoms'); Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. uparrow.gifBack to the top CAUSE The three flashing red lights may indicate that there is a hardware problem with... loadTOCNode(1, 'cause'); The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. uparrow.gifBack to the top MORE INFORMATION If you are experiencing this problem, you can submit a console-repair request on... loadTOCNode(1, 'moreinformation'); If you are experiencing this problem, you can submit a console-repair request online. However, before you submit your request, first try the following two steps to verify the problem:
  1. When you turn on the console, look at the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps in one of the following Microsoft Knowledge Base articles: 906101 (http://support.microsoft.com/kb/906101/ ) Troubleshooting your Xbox 360 Power Supply when the light is red 906102 (http://support.microsoft.com/kb/906102/ ) Troubleshooting your Xbox 360 Power Supply when the light is orange 906103 (http://support.microsoft.com/kb/906103/ ) Troubleshooting your Xbox 360 Power Supply when the light is not illuminated
  2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the problem re-occurs.
If your console continues to display three flashing red lights, your console may have to be repaired. For more information about how to start the repair process online, please visit http://www.xbox.com/support (http://www.xbox.com/support) , and then click Repair your console in the upper-right part of the Web page. Note Online console repair service is currently not available in all countries and regions.If you want to instead contact Xbox Customer Support directly, please visit http://www.xbox.com/support/contact (http://www.xbox.com/support/contact) for information about how to do this.
Dec 06, 2008 | Video Game Consoles & Games
System error it says. a red line appears at bottom left of the console green light. A messege appears with black backround telling me to contact customer support what do i do to fix it?
This problem is typically caused by a hardware failure. Turn off your Xbox 360 console, disconnect and then reconnect all cables. Turn your Xbox 360 console on again. If an Xbox hard disk is attached to your Xbox 360 console, turn off your Xbox 360 console, and then remove the hard disk. Turn on your Xbox 360 console, and then test for the error message. If you don't see the error message, turn off your Xbox 360 console, and then reattach the hard disk. Alternate testing with the hard disk attached and removed to see whether the error message occurs only when the hard disk is attached. If an Xbox Memory Unit (MU) is plugged in to your Xbox 360 console, turn off your Xbox 360 console, and then remove the memory unit. Turn on your Xbox 360 console, and then test for the error message. If you don't see the error message, turn off your Xbox 360 console, and then reinsert the memory unit. Alternate testing with the memory unit inserted and removed to see whether the error message occurs only when the memory unit is inserted. If you continue to experience this problem, contact Xbox Customer Support. For more information about how to contact Xbox Customer Support, please visit the Xbox Support (http://www.xbox.com/support/) Web site.
Oct 19, 2008 | Microsoft Xbox 360 Console
Xbox 360 elite 1 red light
The number for Microsoft is usually listed on the back of any game manual.
I hope I was able to fixya problem, and Happy Gaming!
Oct 18, 2008 | Microsoft Xbox 360 Elite Console
X box 360
yup, you need to do exaclty that, possibly a mainbpard problem. the free phone number is on xbox.com, they will arrange to pick the console up and repair it. All 360 consoles have a 3yr warranty, will take about 2-3 weeks to repair and get it back to you.
Aug 10, 2008 | Microsoft Xbox 360 Console
Switch computer on and the light is red but on the screen it says system error contact xbox customer support
SYMPTOMS loadTOCNode(1, 'symptoms'); You receive the following error message in multiple languages: System Error. Contact Xbox Customer Support. CAUSE loadTOCNode(1, 'cause'); Typically, this error message is caused by a hardware failure. THINGS TO TRY loadTOCNode(1, 'whattotry'); Note If you receive an error message and see one flashing red light on the front of the console, see the following article in the Microsoft Knowledge Base: 907536 (http://support.microsoft.com/kb/907536/) Xbox 360: One red light flashes on the Ring of Light and you receive an error message 1. Turn off the console, disconnect and then reconnect all cables. Turn the console on again. 2. If an Xbox Hard Disk Drive is attached to the console, turn off the console, and then remove the Hard Disk.
For more information about how to remove the Hard Drive, click the following article number to view the article in the Microsoft Knowledge Base: 906204 (http://support.microsoft.com/kb/906204/) Xbox 360: How to attach or remove the Xbox 360 Hard Drive Turn on the console, and then test for the error message. If you do not receive the error message, turn off the console, and then reattach the Hard Disk. Alternate testing with the hard drive connected and removed to see whether the error message occurs only when the hard drive is attached. If the on-screen alpha-numeric error is E67 in the error message, see the following article in the Microsoft Knowledge Base: 917874 (http://support.microsoft.com/kb/917874/) Xbox 360: One red light flashes on the Ring of Light, and you receive error E67, E68, or E69 3. If an Xbox Memory Unit (MU) is plugged in to the console, turn off the console, and then remove the Memory Unit. Turn on the console again and test for the error message. If the error message does not reoccur, turn off the console, and then reinsert the MU. Alternate testing with the MU inserted and removed to see if the error message occurs only when the MU is inserted. 4. If you continue to experience this behavior, contact Xbox Customer Service.
Jul 17, 2008 | Video Game Consoles & Games
Microsoft Xbox 360 Console Logo
32 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
