Question about Canon Digital Rebel / EOS-300D Digital Camera with EF-S 18-55mm Lens
CF Card not found
My Canon EOS 300D does not recognize any CF card. I have tested the cards in other cameras and they work.
  • tedsymonds Jan 19, 2009
    I had the same problem. I looked down the card slot and sure enough, one of the pins is bent. Camera now on way to repair shop.
  • 477 Answers
Ok here is the issues with the Canon 300D digital Rebel XT model of camera. First issue bent pins or broken pins the CF card reader on this camera is Surface mounted soildered onto the bottom half of the mainboard a large ammount of disasimboly is required. After removing the mainboard next you need is a desolder rework station. to carefully remove the CF card reader from the mainboard one messup and it might be easier to replace the mainboard. Sometimes. next issue is the power issue if you have no bent pins or missing pins, and the battery door is pushing on the door closure switch and the memory card door is pusting on its door closure switch then most likely you issue is 1 of 3 fuses underneath the power switch. these switches are the size of a few grains of salt very very small.I charge 150.00 to change the fuses and 225.00 to replace the CF card reader as long as none of the traces are damaged. if they are damaged the main board would need to be replaced and it is around 250.00 + depending on the parts cost at the time. If your good at soldering go for it. if not then let the experts do it.
Posted on Jan 22, 2009
I saw your post from about 5 months ago and i figured you would know possibly what my problem is.Heres my isue, I bought used camera's body Canon eos rebel d300 but it wont recognize card,couldnt turn it...
The 02 error definitely refers to a CF card problem. If none of these cards are new and have been used in other cameras, this could be the problem. Try a new one.
May 01, 2011 | Canon Digital Rebel / EOS-300D Digital...
Windows 7 unable to recognize EOS 300D
Try using a card reader instead of the camera.
Oct 07, 2010 | Canon Digital Rebel / EOS-300D Digital...
Im getting an Error 99 on my EOS-300D Digital Camera when I turn off my YN 465 Speedlite flash gun (still mounted) and then I start shooting manually without the flash. Help please, its a bit annoying, but...
To fix this err99 issue, do the following
1. Turn off the camera. 2. Remove the lens, battery, and CF card. 3. Allow the camera to sit without power for approximately 20 minutes. 4. Insert a fully charged battery, and turn on the camera.
If it appears again, then proceed to next steps 1. Turn off the camera. 2. Insert the CF card. 3. Turn on the camera. 4. Format the CF card in the camera.
If you still get the error you should send your product to canon for servicing.
Apr 15, 2010 | Canon Digital Rebel / EOS-300D Digital...
Canon EOS 300D will not take photo's
do you get black frames or no record at all???
Seems like your sensor went dead on you....
Jul 09, 2009 | Canon Digital Rebel / EOS-300D Digital...
Accessing internal memory on the Canon Digital Rebel EOS 300D
There is no internal permanent memory. There is a buffer that holds data momentarily while the data is written to the memory card, but the buffer is flushed after each shot or series of shots. Sorry.
Jun 09, 2009 | Canon Digital Rebel / EOS-300D Digital...
Tech help
In the manual on page 127:
Err 02
There is a problem with the CF card. Do one of the
following: Remove and reload the CF card, use another
CF card, or format the CF card.
found manual at:
http://dms.sjmc.umn.edu/Equipment_Guides/Digital_Camera_Guides/CanonRebel.pdf
Jun 23, 2008 | Canon Digital Rebel / EOS-300D Digital...
CF FULL
I just had exactly the same problem with my 20D. I removed and reinserted the battery and it fixed the problem.
Dave
Dec 08, 2007 | Canon Digital Rebel / EOS-300D Digital...
Canon Digital Rebel / EOS-300D Digital Camera with EF-S 18-55mm Lens Logo
176 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
