Question about HP LaserJet 3050 All-In-One Printer
FAX received full of black stripes
This recently happened: All the faxes we send have black stripes over half of the page. The faxes can not be read at the recipient's side.
We receive clear faxes.
Please assist and thank you.
Maureen
  • 34 Answers
Try to unplugged your fax and wait for 30 seconds then plug it again. try copying using your fax if the copy have no black stripes. if it does not have then its fix. sometimes electric fluctuation makes the electronic erratic.
Posted on Dec 22, 2008
    Scholar:
  • 80 Answers
If you are using upper tray to send the fax than kindly open the fax gently and clean the lens with some cotton and spirit and than try to send the fax you will get the best result. to open the fax unit gently refer the user manual or this open by lifting it up side and you can see the lens inside it so clean the same ok.
Black Stripe on outgoing faxes
If the stripe is a thin line, the scanner glass is dirty, if it is wide stripe you have a bad scanner block. EXPENSIVE
Jul 01, 2010 | Brother IntelliFAX 4100 Laser Fax
Is there a Fax modem available to be connected with scanner, copier and printer (three in one already with us.)
your unit has a fax installed in the unit.
Look at page 29 in your manual it will show how to send and receive a fax.
send a fax page 29
receive a fax page 32
print reports page 33
feature purpose
1 Phone Hook: the green LED in the shape of a phone indicates that the fax
line is in use when lit.
2 One-Touch Speed-Dial Buttons: use to access the first 6 speed-dial entries.
3 Auto Answer: when the green light is on, fax transmissions will
automatically be accepted.
4 Speed Dial: use to access speed-dial numbers that have been set up from
the front panel or with the HP Director software.
5 Redial/Pause: redials the most recently dialed number when in the ready
state. Inserts a pause (hyphen) when in the dialing state.
6 Keypad: use to dial fax numbers, and enter numbers such as the quantity
of copies or percentages when reducing or enlarging. You can also enter
text using the keypad for fax header, use speed dial entries, and specify
menu items.
7 Fax Resolution: use to set the fax resolution to Fine, Standard, 300 dpi,
or Photo. It will remain at the most recent setting until changed.
8 Start Fax - Black: starts a black and white fax.
9 Start Fax - Color: starts a color fax
Apr 27, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Every Fax we send has stripes going down it making it hard for the receiver to read our faxes. It doesn't happen when we receive fax, print or make copies.
You say it makes copies without the stripes. Do you use the automatic document feeder (ADF) when you make copies, or open the top and lay the paper on the platen? If you get stripes when using the ADF, the ADF scanner area needs to be cleaned. It's the smaller glass area to the left of the main platen glass. Use a damp cloth and remove any dirt or debris.
Jun 15, 2009 | Canon PIXMA MX310 All-In-One Printer
When I send a fax from our Brother Intellifax 2800, the person receiving the fax gets the fax but half of the page is blacked out, what is the problem?
sounds like your cis (contact image sensor) which lights up and reads your original, is bad. that component is located under the keypad/control panel. if you make a copy, it should also be partially balck if that is the problem.
razors
Mar 25, 2009 | Brother IntelliFAX 2800 Laser Fax
HP 5030 do not send fax properly
Open the document feeder and clean the scanner glass.
Dec 30, 2008 | HP Officejet 5610 All-In-One InkJet...
Fax Machine Problem
the glass strip is bad, this is what reads the fax.
look in the manual under Maintenance for the location
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=6e9b3b779afac7942ef639a6224550b2&q=Sharp+UX-P100
Jan 30, 2008 | Sharp UX P100 Plain Paper Thermal transfer...
Recipient receives a black page
What happens when you make a copy on your machine?
Dec 11, 2007 | Sharp UX 300 Plain Paper Thermal transfer...
HP LaserJet 3050 All-In-One Printer Logo
171 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
