Question about Solis Master 5000 Espresso Machine
Solis Master 5000 Espresso Machine - Need Repair
I need to get my Solis fixed. bad grinding -too corse
  • Anonymous Mar 17, 2014
    solis master 5000 steam in display
If you can remove the grind hopper(two screws) you can re-index the grinder for a finer grind.
Posted on Mar 14, 2008
SOURCE:
How can I determine what parts I need to repair my espresso machine and where do I get parts and service?
Solis Master 5000 Espresso Machine - YouTube
? 9:49
www.youtube.com/watch?v=MjBmlQXElag Sep 2, 2010 - Uploaded by Day Tooley
I have been enjoying the Solis Master 5000 for a year. It's time to ... I haven't been able to find an actual user manual online...for some reason.
Nov 03, 2015 | Solis Master 5000 Espresso Machine
Why won't my solis 5000 grinder turn to produce a finer grind coffee?
Have to turn it while it is grinding. Don't force it or it will break.
Jun 04, 2014 | Solis Master 5000 Espresso Machine
The dredgedrawer notification will not turn off on my solis 5000 espresso machine
Grinds sometime get lodged behind the drawer. When you replace the dredge drawer it doesn't go all the way in. Clean out behind it really well (maybe air blower fro computer) and try it again.
Feb 17, 2014 | Solis Master 5000 Espresso Machine
Coffee maker trips gfi
Try it in a different outlet (one that is not a GFI). It could be the GFI is bad
Jan 28, 2013 | Solis Master 5000 Espresso Machine
No water supply on Solis Master 5000 Manual
open steam valve and run water couple minuts,after try again if light show up again thats mean machine is somewhere clugged
Aug 23, 2009 | Solis Master 5000 Espresso Machine
Solis Master5000 no water or steam
Can you get hot water from the unit? If yes then the pump is working, next thing is have you tried to set the grind to the coarsest setting, if yes then there is a blockage in the line, try descaling the machine, if that does not fix it, you might have to open it up or send it into a repair center.
Apr 06, 2009 | Solis Master 5000 Espresso Machine
Solis master 5000 Espresso Maker is leaking
Before you go that far, what does the grind on the coffee puck look like; is it fine like powder or is it course. The water from the machine might not be able to go through the coffee and so the bypass is opening because of too much pressure. Try adjusting grind first.
Mar 24, 2009 | Coffee Makers & Espresso Machines
Solis Master 5000 Espresso Machine Logo
338 people viewed this question
Top Solis Coffee Makers & Espresso Machines Experts
graybeard32301
Pierre Laplante
Colin Stickland
Colin Stickland
Are you a Solis Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
