Question about Refrigerators
I can't get my fridge to turn back on after defrosting it.
It's a Kelvinator Classic fridge/freezer and I defrosted it by switching it off, letting the ice in the freezer compartment melt and then I cleaned the inside. When I plugged it back in again it doesn't want to turn on again. I did check the plug, that's not the problem. I know these fridges need to be level in order to work and I might have shifted it around a bit but I have the fridge postioned as level as possible and it still doesn't want to turn on again. Please help and thank you!
    Novelist:
  • 161 Answers
Check the defrost timer.
The defrost timer could have automatically cycled to the defrost mode which means it should come back on in 15-20 min. If it doesn't then the timer could be stuck in the defrost mode.
Posted on Dec 22, 2008
Kelvinator fridge not cooling
Try defrosting the fridge. Check the cold plate at the back of the food compartment once the fridge has been defrosted and turned back on again. The cold plate in the freezer (around the walls) will be cold to touch as will the cold plate at the back of the fridge,
Oct 20, 2013 | Refrigerators
I have a Kelvinator Fridge P120 Product Code: 10325 and we have no manual for the defrost or temperature dial settings can you help me with a pdf Manual?
Hi Aaron, Apparently this is a Fisher & Paykel fridge made by Kelvinator.
F&P has a support page for manuals, etc., here. I found a fridge / freezer user manual, here. F&P maintains that this manual is applicable to all of their fridge / freezers, so don't be put off by all the model numbers covered (the P120 model is specifically listed however).
If this is not the correct product, please let me know & I'll see if I can find the one for your appliance. I hope this helps and good luck!
Mar 05, 2012 | Refrigerators
My Kelvinator N245C fridge freezer is ok but fridge not cooling when i open the freezer door , the cold air through to fridge air outlet ok but when the freezer door shut and than no air to the fridge the...
first look for an air vent in the bottom of the fridge(a small grill on the inside wall) & make sure nothing is blocking it, like bread eg: if there isn't then unplug your fridge & let it defrost, check the drain outlet in the back of the freezer, sometimes a small item like a frozen pea gets into the drain & the water freezes around it causing the air not to return to the freezer from the fridge, to push air into the fridge you must be able to get air out or it presurises,
Nov 01, 2011 | Kelvinator 12 cu. ft. / 340 liter Chest...
We bought a kelvinator ref KTD300MN. I would like to ask if the freezer inner rear wall should form some ice? thanks.
No.
DEFROST PROBLEM
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can't flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won't turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it's bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it's in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Mar 26, 2011 | Kelvinator Refrigerators
Freezer is working ok, fridge is warm, a couple of days now. Kelvinator N476c, approx 10yrs old. Some water is leaking in fridge and has previously leaked on the floor at different times, not consistently....
Hi
Check the back wall or floor of the freezer section for frost. Check the freezer or evaporator fan to see if it is running. Check the condenser coils under the unit for blockage from dust. Check the condenser fan to see if it is running.
If you have frost in the freezer there is a problem with the defrost system and the freezer will start to warm eventually as well as the fresh food section. If that is the problem you can check the defrost terminator, defrost heater/s, and the defrost timer or adaptive defrost control If used on your unit or the main control board if so equipped. These things usually require dismantling the freezer and other areas of the refrigerator to be checked.
You could defrost the freezer by disconnecting the power to the refrigerator and letting it sit for at least 24 hours with the doors open to allow the frost to melt completely but it will build up again in 1-2 weeks and start the warming up again.
Also check the bellow link:-
http://www.repairclinic.com/Refrigerator-Troubleshooting?red=Refrigerator-Repair-Help#itsnotcool
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Jan 04, 2011 | Kelvinator Refrigerators
Kelvinator Fridge/Freezer C 340 RM does not switch off
the problem is your thermostat in your frig.the dial with numbers on it.it is no longer sensing properly and theres nothing you can do but replace.that is as long as your dial is not broken[the plastic pice with the numbers] God bless ,tom
Jan 10, 2009 | Kelvinator 12 cu. ft. / 340 liter Chest...
Fridge & freezer no longer cold
if you only removed the ice you can see without removing the back panel then you need more defrost time yes. but the frost will come back, something in the defrost system has failed. so the answer is yes to both questions off for longer and something more serious too.
Apr 06, 2008 | Freezers
Fridge not working
sounds like the defrost system is defective, frozen. possibilities are fan in freezer wuit or defrost heater open or defrost timer bad. try these first, if not fixed call.
Mar 28, 2008 | Refrigerators
Kelvinator fridge/freezer problem
It could be a thermostat but is more likely to be a defrost problem. If it freezes up within a short space of time I would suggest contacting a fridge guy who should be able to diagnose either the defrost heater, defrost thermostat, defrost timer or thermostat. Hope this is of some help.
Sep 14, 2007 | Frigidaire FRT15G4B Top Freezer...
Refrigerators Logo
301 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
