Question about Wmh Tool Group Jet 13" Planer Molder
How to make crown molding with a jet 13" planer /molder
What size board do I use to start with when making crown molding and what side is done first? The bevel on the back or the face?  I have been searching the internet for hours for information on how to use a molder for making trim and all I can find is how to cut it and install it.   Thanks for your help!
  • 32 Answers
You may want to go to the Forum at OWW (Old WoodWorkers.com). What your attempting to do requires several Passes. I usually Rough out BOTH Face & Bevel, then make 2 more cuts each, to get to the Finished dimensions. I usually start with a Face Cut 1st, leaving some Flats for Square then do the Bevel Cuts to Desired dimension, then back to the Face, & take it down to where the Finished product is where I want it.
Posted on Jan 17, 2009
Need a manual for Craftsman Contractor series 12 1/2 Planer #351.23383
Go to the Sears Parts Direct web site and search for the Planer model number. I got two results, the second one had a link for the manual. Here is a direct link: 351233831 CRAFTSMAN 12 1 2 PLANER MOLDER Manual
Jul 06, 2014 | Craftsman 12 amp 12-1/2" Bench Planer...
Table on jet planer will not lower and board is stuck
Unplug the machine, and rotate the motor backwards. Look at the cutter to determine you are going backwards. Eventually things will free up, but it will take a while. Then clean out everything real good, and keep it clean. Consider a shop vac hooked up to a discharge if it has one.
Nov 25, 2013 | Jet JPM-13CS, 13" Closed Stand Planer /...
Board is stuck in planer and I can't get it out
Unplug the power cord. Then rotate the motor backwards until the board is free. It will take a lot of turns for the unit to free up. Look at the blade to make sure you are rotating the motor backwards.
The infeed roller is uneven and it snipes the boards
Sniping is common, try feeding waste stock in before or after your good wood, whichever end is getting sniped. The planer will not notice the end of your wood, and cut it flat.
Oct 03, 2013 | Powermatic 1120003 PM15 Planer/Molder
My Jet Molder/Planer cuts the last four inches of the piece slightly thinner. The piece is straight and fully supported on the table. The feed rollers seem evenly adjusted. What's up?
The problem you are describing is called "snipe" and it can be caused by alot of different things. Even the best woodworkers have to fight this problem.
- you did the right thing by making sure that the matrial is supported, but if the oppisite side of the board is'nt true it will carry over onto the face. The only way to "true" a board is to use a jointer.
-when jointing a board you only want to do one side(face or back) and one edge,then it is ready for the planner.
-Now for solutions other than jointing-
1) Make sure that the infeed table and bed plate are clean, and wax or lube so that the board moves freely.
2) Try taking a lighter cut.
3) try a different piece of wood to see if it is only affecting that material (wood that is bowed is more likely to snipe) If it is bowed try feeding the material with the bow down..
4) make sure material is supported
Also your machine may have a bedplate adjustment to help with snipe you will have to look at the manual to find out.
If you take a close look at your machine you will notice that the length of the snipe is also the distance from your rollers to your knives, This means that the board is not laying flat and is being pushed up into the head until it can be supported by the next feed roll.
I hope this helps
Nov 28, 2010 | Wmh Tool Group Jet 13" Planer Molder
Where do i find molder knifes
Moulder knife blades, are usually available for a particular machine only fromm the manufacturer. I suppose a machine shop could make some up, but it would too expensive IMO.
May 03, 2010 | Wmh Tool Group Jet 13" Planer Molder
I have a Jet planer 15 and the wood gets stuck
I think you are trying to remove too much wood in one pass.Don't cut so deep and see if it will feed thru then. hope this helps you
Jan 17, 2010 | Wmh Tool Group Jet 13" Planer Molder
I want to wire a 3 phase planer up. I have three
install 30 amps 3phase breaker, then wire it up with royal cable 5.5mm x 4wires
Nov 25, 2009 | Powermatic 1791297/Model 209 5HP 3Ph 230V...
Wmh Tool Group Jet 13" Planer Molder Logo
1,197 people viewed this question
Top Wmh Tool Group Masonry Tools Experts
Vernon Taylor
Tom Chichester
Are you a Wmh Tool Group Masonry Tool Expert? Answer questions, earn points and help others
