Question about Datacard Parts Plastic ID Card Printer - P/N 564806-001
How to clean plastic id card printer sp55 plus
  • 34 Answers
All you have to do is do the following 1. use a very soft brush 2. buy a cleaning kit from the manufacturer of the id making machine. this cleaning kit is needed (it is compose of a card make of cartoon and a cloth on its side to absorb alcohol) place an alcohol in it to clean the rollers, and print head.
Posted on Dec 22, 2008
Datacard error PR 01739
Upgrade the printer firmware (Go Green firmware update) as you are likely using the newer eco friendly ribbons. The older firmware versions do not recognize this ribbon, which leads to the PR01739 error.
Download firmware here:
Dec 02, 2012 | Datacard SP55 Plus Printer
THe datacard sp55 color card printer is printing monochrome(black and white). I have done lots of setting changes but still couldn't manage tro print the right color. And the duplex module is not on the...
The printer needs to be serviced, The Monochrome issue could be related to a problum with the RFID chip in the take up wheal of the ribbon, but the duplex offset can only be adjusted by an authorized service provider using a special password and diagnostic tool. offers a depot service.
Aug 26, 2010 | Datacard SP55 Plus Printer
I have a Datacard SP55 plus and recently I started to get two white lines on the id card that I am printing and it goes right through the persons name so it is very noticeable I am not sure how to fix...
You have a physically damaged print-head.
The print head is in the cover and us user replaceable by pressing the lever inside the cover.
Print heads are considered consumables and need to replaced at maintenance. You can contact Datacard at there web site and they can have someone come out and change for, as well as service the printer. Or you can buy one online about $550 and change your self.
Apr 23, 2010 | Datacard SP55 Printer
Ms-01410 error
Having exact same problem, cleaned everything, right settings, right cards, new head and still having ms-01410 and ms-01424
Mar 03, 2010 | Datacard SP55 Plus Printer
Card jam in datacard printer
The rollers in the printer that move the card wear out and the rubber degrades over time, You need to have all the roller replaced and the printer should function like new. Contact for pricing on parts or service.
Feb 19, 2010 | Datacard SP55 Printer
Datacard sp55 printer won't recognize ribbon
PR-01726 Ribbon Out
Out of print ribbon.
Possible Cause 1 : The print ribbon Cartridge is empty.
Solution 1 : Reload the print cartridge. Change the cleaning sleeve and replace the cartridge in the printer. Run a cleaning card as soon as printing is completed.
Possible Cause 2 : The printer ribbon is not loaded correctly.
Soultion 2 :Load the printer ribbon correctly and then close the cover.
Possible Cause 3 : This ribbon has been completely used.
Solution 3 : Use a new roll of ribbon.
Tips for Success
* When this message appears, replace the old ribbon with the new ribbon of the same type. The printer has already prepared the card data for this ribbon type. You can change the colors of monochrome ribbon (such as from dark blue to gold).
* If you must change the type of ribbon (such as (YMCKT to KT) when this message appears, install the new ribbon, cancel any cards waiting to print, and change the ribbon type settings. Finally, return to the card creation program to send the card data to print.
* If the ribbon was repaired, the wrong take-up spool was used. Repair the ribbon again, using the correct take-up spool.
If you cannot fix the problem contact your service provider for assistance.
Nov 23, 2009 | Datacard Group SP55 Card Printer
When i try to print card it causes a paper jam all time. it used to print card but not now i feel this is a grat pity cause its a good printer. It doesnt matter which place i put card it just will not lift...
fter a clear card option has been installed in a Datacard card printer SP35 Plus or SP55 Plus, a card jam error my occur. The same error may occur when after replacing the main control board.
To clear this error the printer will need to determine the sensor type. For the printer to recycle through and make this determination, a power on test card is required using the appropriate clear or opaque card type to force the firmware to redetermine the sensor type. Each time the card is changed from clear or opaque to the other type, a power test card will be necessary to redetermine the sensor type.
For additional information about Datacard printers currently on the market, SP25 Plus, SP35 Plus, SP55 Plus and the SP75 Plus, contact our id card experts toll free at 888-485-4696.
Nov 19, 2009 | Epson AcuLaser C4100 Printer
SP55 Datacard
The printer does not know the the model of the ribbon installed and thinks it is a monochrome (single color) Print ribbon. You can verify this in the Driver toolbox under the supply tab, or in the advanced printing options.
The Datacard SP series printers use an RFID Radio freq. tag in the take up spool end of the ribbon. This identify s the ribbon model and supply use settings for the printer.
Make sure you have the most recent driver and firmware from Datacard, There is a firmware Update Available to help reading "weak" RFID tag's
Next try removing the RFID tag from another (old) ribbon and see if it that fixes the problem)
Aside from that you:
May have a counterfeit (non-Datacard) ribbon
A bad RFID tag
Someone removed your RFID tag
You need a firmware update (weak RFID tag)
A bad RFID reviver in the printer, which is a fairly cheap repair.
Basically try a new print ribbon if that does not correct the issue, have the printer serviced.
Apr 07, 2009 | Datacard SP55 Plus Printer
Datacard Parts Plastic ID Card Printer - P/N 564806-001 Logo
161 people viewed this question
Top Datacard Office Equipment & Supplies Experts
Safe-Card ID...
Don  Farrell
Don Farrell
Are you a Datacard Office Equipment and Supply Expert? Answer questions, earn points and help others
