No sound on TV Bravia KDL32u40xx Analogue Channels
I cant get any sound on my new flatscreen, when trying to tune into the analogue channels - fine on the Digital but not on Analogue???
Any ideas?
Many thanks
Kay Cavilla
  • Anonymous Dec 22, 2008
    I have exactly the same issue... (KDL-40w4500)
SOURCE: can't get digitall channels
I have the same problem, If anyone could help it would be appreciated.... I have the coaxial cable plugged in which on another TV had all 85 channels, and I changed the TV from analog to digital and reprogrammed it but I still only get like 4 or 5 local channels?
Posted on Jul 22, 2009
SOURCE: lost digital channels
Got to -
Menu -> settings -> set-up menu -. auto start up
Rescan your tv for all channels.
Any more problems, call sony. 08456000124 local rate number
Posted on Dec 16, 2009
  • 10 Answers
SOURCE: Hi Digital channels lost and will not hold
this is a fault of your digital tuner on the mainboard on some models they can be replaced alone others you may need to replace the whole board
Posted on Apr 23, 2010
Testimonial: "Thanks very much, I did suspect this however has put to rest the question of purchasing a brand new TV"
ssemul
  • 202 Answers
SOURCE: I have a Sony Bravia
(1)Reset your tv from setup menu then auto tune analogu chanel.
(2)if still no sound then update your tv softwear from sony site.
(3)If still sound not then need to replaced main board problem.
Posted on Oct 20, 2010
sonicboomele
  • 1557 Answers
SOURCE: My Sony Bravia television froze
there is a fault within your digital tuner ! shutting the tv down with all cables and power disconnected may fix it but if not the tuner will need replacing. a cheaper option i would go for is to by a seperate set top box reciever .
best of luck
merry christmas
please take the time to rank this advice below
thank you
Posted on Dec 23, 2010
How do I get my Sky channel back on analogue after re-tuning freeview
Go in to analogue tuning. Tune just the analogue side of the TV.
Sep 05, 2014 | Televison & Video
I have a panasonic viera 42 in plasma. It has a built in freeview receiver. It is in the bedroom and receives a signal through a booster from the main sky box. I can get free view channels on it but can't...
switch tv to analogue tv and auto tune on tuning menu making sure sky is on. It should find it around channel 69. If quality poor then change output frequency to a lower channel. You do this with sky menu and instruction book. Info is changing RF output in book, or google it.
Apr 30, 2014 | Panasonic PV-M1349 Combo
How can i tune my tv in to recieve freeview channels?? tried everything with no luck. cant even get analogue channels? i know this isnt a problem with the aerial as other tvs work!!
In the US, you are not able to obtain free HD channels without a tuner and an antenna. Some HDTV's have built in tuners and depending on your location to the broadcasts, you may be able to obtain reception. It is possible that one of your TVs has a built in tuner if it is newer and this other TV does not. Analougue channels no longer exist as all channels have been converted to digital broadcast and would need to be converted if trying to view through an analogue TV. Thanks.
Feb 28, 2011 | Televison & Video
Hi i have hisence 42 inch tv will not tune in keeps saying no signal yet me old tv is fine
Hi there
I am assuming your new TV is now Digital. If so, it will be looking for a different signal to the old TV which was probably analogue. You may need a aerial upgrade/diagnostic to determine if you are recieving a digital signal. Or you can tune in the analogue channels, by switching the new TV to analogue, through the inputs/menu, and then i suggest autotune.
Hope this helps
TV_Doctor
Jan 03, 2011 | Televison & Video
My Sony Bravia television froze on a digital picture today and now when I change channels there is no picture and no sound. I tried to do a digital scan and it picked up no digital signals,. The analogue...
Your TV has a dual tuner - one for analogue and one for digital although they are contained on the same tuner board. It's possible that the digital tuner has failed, in which case the tuner board will most likely need to be replaced, but often this problem can be resolved with a "hard" reset. Turn the TV off and unplug it. Remove all the cables from the back, leave it for at least 5 minutes and then re-connect only the cable from the tuner source. i.e aerial/antenna. Make sure you are in Digital TV mode (DTV), then run the channel scan again.
If it works turn the TV off, re-connect all of your other devices and you should be able to resume using the TV as normal.
If this doesn't work, you may need to have the digital tuner replaced. The analogue and digital channel feeds are from the same source. As the analogue channels are working there is no obvious fault with the feed or cables.
Please try this first and then post back for further assistance if needed.
Regards,
BElectric
Dec 23, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
I have a Sony Bravia KDL-40V3000 but I cannot get any sound on the analogue channels. digital channels are fine. Only cables plugged in are ariel and power Please advise any solutions thanks
Oct 20, 2010 | Sony BRAVIA KDL-40V3000 Television
Lost digital channels, only getting analogue installed new antenna, no help other sony lcd is working fine
Got to -
Dec 12, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Televison & Video Logo
60 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
