Orange Led syndrom
Hello.
I have a32'' Viewpia lcd TV.
In standby mode led is orange, but supposed to be red and it wont switch on. Ihave seen same problem with same TV on forums but i havent found a solution.
  • mushang Jan 02, 2009
    I have the same problem after we had a power cut. Please help
  • nathali13 Mar 18, 2009
    Exactly the same problem here with a Viewpia 32"... Has anyone found an answer???
I found the following solution on internet:
VIEWPIA LCD
Make: Viewpia
Model: LC-32IEB2
Fault: Unit held down with only orange LED lit
Remedy: Remove the main metal screen cover from main board and check the input
voltage on to the main 3.3Volt regulator IC202 it should be bang on more or less
5Volts, if not replace capacitors C905 330uf 10v C908 470uf 10v both are to be
found in the main power supply section.
J Williams
www.jvsvisual.com
Unfortunately I'm not very technical so now I will need to find someone to do this for me...
Posted on Mar 18, 2009
Hey got it fixed-problem is that power supply unit (PSU) is dead- cost me approx 100 EUR- good thing is that fits most classical philips lcd tv PSU- should be found at any TV repair shop
Posted on Mar 19, 2009
Viewpia TV 26 orange led syndrom repair unsuccessfull need help !
I would just replace this, repair is just to costly when a replacement is less than $150
Sep 23, 2016 | Televison & Video
Viewpia TV 26" orange led syndrom repair unsuccessfull
Sounds that you're nothing in electronics. It is a useless effort to discuss anything with you about electronics. Just contact any service technician. Sorry.
Apc smart ups 2200 all led flashing 3 orange 2 red 1green,what is that? and How to Fix It?
this problem is caused control board with that. the solution is replacement.
Jul 21, 2014 | APC Smart-UPS 2200VA LCD 230V...
When you switch on the tv it goes to standby mode, and when you press standby it turns on to a orange light then goes back to a red light, any idea whay this is happening ....
My Westinghouse LCD tv has the same lights on it It goes orange or red when there is no signal from that source... or while it is calibrating itself to the new frequency etc.
Oct 19, 2013 | LG 42PM3MV 42 in. PLASMA TV
Tv wont turn on
This is on protection mode due to errors inside the TV. Turn off TV manually, switch off power and remove plug, and retry after 48 hours.
Jul 29, 2012 | Sherwood LTA26T04 LCD TV
Viewpia lcd tv backlight not working
Measure the input voltage to back light inverter board, from the main power regulator board. If it is found OK, replace back light inverter board.
Jul 27, 2012 | Televison & Video
Panasonic PTL500U LCD HiDef projector. Unit occasionally powered up briefly, lamp lit, then shut down, standby LED flashed orange/red. Sometimes lamp lit and sometimes not. Technician diagnosed bad ballast...
If you take the back off you might find a couple of bulged electrolytic caps on the power supply board that need change, or just buy a new power supply at www.partstore.com
Dec 22, 2010 | Televison & Video
What does it mean when that blinking green light turns to orange one in lp 350?
Hi
This would be "Standby"
When you press standby, the display and audio turn off and a blank screen is displayed for 15 minutes.
You can change the amount of time the projector stays in standby mode; see “Standby Time” on page 27 for details.
The LED lights orange while the projector is in standby.
• If you press standby again within 15 minutes, the projector returns to normal operations immediately. The LED changes from orange to green.
• If you press standby again after 15 minutes, there is about a 60 second delay before the lamp turns back on. The LED flashes green while the lamp is re-lighting.
• If you don’t press standby again, the lamp turns off after 15 minutes. The LED lights orange while the projector is in standby.
The full manual can be found here:
Infocus customer support
Infocus LP350 Manual
I hope these help
Mike
Sep 18, 2009 | InFocus LP350 Multimedia Projector
VGA shut down
call Polariod
replace 'box'
(their description, not mine)
May 07, 2009 | Polaroid 4241-TLXB 42 in. LCD Television
Televison & Video Logo
1,625 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
