Question about Maytag Neptune MDE5500AY Electric Dryer
Drum stopped turning on hot point dryer
It started out sqeaking and the drum only turned for very small loads of clothing then eventually stopped turning at all .whats the problem?
  • Maytag Master
  • 8,220 Answers
Open the door. Get a screw driver. Look up and remove two screws that hole the top on. Get em off and remove the top. Look down in the front and check the slides. I bet they are gone!. They are easy to replace. Sometimes you let them go too long and the bearing they mount on is worn out and you start hitting the droor, hence the squeal. You remove the front by removing 2 screws that hold it to the frame and lift it of. Replace the parts. All are mounted on the front. Clean out the lint in the filter housing. The bearing and slides cost around 25 bucks total. This is simple.
Posted on Dec 22, 2008
How do you dry clothes in this machine please
A fairly common problem! The official instructions are
Before using your dryer, wipe the dryer drum with a damp cloth to
remove dust from storing and shipping.
1. Load clothes loosely into the dryer and close the door. Do not
pack the dryer. Allow space for clothes to tumble freely.
2. Turn the Cycle Control knob to the recommended cycle for the type of load being dried. Use the Energy Preferred Automatic Setting (,) to dry most heavyweight and medium weight loads. See "Drying, Cycle, and Temperature Tips."
3. Select a temperature setting on models with a Temp/Fabric selector. The cycle descriptions include temperature setting suggestions.
4. Push the START button.
Stopping and Restarting
You can stop your dryer any time during a cycle.
To stop your dryer
Open the dryer door or turn the Cycle Control knob to OFE
NOTE: The Cycle Control knob should point to an Off area when
the dryer is not in use.
To restart your dryer
1. Close the door.
2. Select a new cycle and temperature (if desired).
3. Press START
Extracted from
Nov 14, 2015 | Whirlpool AWZ410 Front Load Washer/Dryer
Gas & Electric clothes Dryer sqeaks, rumbling, & noises
If your clothes dryer has any sort of uncommon noises coming from it they are fairly easy to repair. The drum turns with the help of a belt with a belt tensioner. The tensioner keeps the belt tight. The tensioner also has a roller with a bearing. If the bearing goes dry it will squeak. If the bearing locks up the belt will burn and you will smell burning rubber. Eventually the belt will break off. The roller can be ordered from most companies with the belt. It is advisable to replace the drums front seal that rides along the front panel. These will wear and squeak too in time. To service these parts the front panel must be removed to gain access. All parts are fairly easy to repplace with someone helping you to hold the drum up when re assembly come up. You can also ask me more questions if needed.
Thanks for stopping by reading my tips!
on Feb 06, 2010 | Washing Machines
Dryer will only spin with small load
You need to replace the belt that will solve all your problems.
Oct 17, 2012 | Dryers
Maytag electric dryer drum starts and stops turning but keeps going
I would think you are on the right track, possibly a belt, I would also check all the rollers or idlers while you are replacing the belt.
Enjoy and best wishes
Dec 20, 2011 | Maytag Dryers
Load clothes in dryer from the washer. Heat seems to be fine however drum stops turning after a period of time and heat inside dryer very hot but still sounds like a motor is running.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
Jul 08, 2010 | Maytag SDE3606A Electric Dryer
Dryer wont tumble when loaded.
check for a "glazed" drum belt or a broken "idler" pulley near or on the motor that keeps the belt tight on the drum
May 10, 2010 | GE DBXR463GB Gas Dryer
Drum making intermittent sqeaky noise for 3-4 minutes then stops
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
Jun 03, 2009 | Frigidaire Electric Dryer
My lint filter assembly is broken. I was drying a small load of clothes and the lint filter got tangled with clothes and came out into the drum. The dryer was stopped when I found this situation. ...
The drum should turn either direction. Part of the filter must be catching in the belt at the drum or motor when turning clockwise. CCW would push it out away from the belt so no pinching.
May 29, 2008 | Amana Dryers
Clothes dryer
dryer won't run, but hot air blow and humming when turned on
Belt is off, idler is off or broken. Replace the belt and idler. Make sure it is installed correctly with tension on the belt. It will take care of your problem
When I try and start my ge dbb3300eaoww dryer it buzzes as if it wants to start if I spin it with my hand it will work. I put a new belt on it and it does the same thing.
Motor start switch is bad. This is typically replaceable with out replacing the motor.
Will take care of the problem.
My drum will sometimes stop turning in the middle of a cycle, and the motor just hums. I pause the dryer, open the door, rotate the drum, unplug and plug the electrical, and then it will usually complete the cycle. Does that mean the belt is "occasionally" slipping? How do I check this?
Replace the belt. It has stretched to the point it no longer can carry the load. Should consider replacing the idler at the same time. This will take care of the problem.
Sep 15, 2007 | Dryers
Clothes not drying
A couple of possibilities to check. First, is the lint trap empty? If so, then the symptoms point to hot air bypassing the drum. Look for broken or misaligned plastic ducting inside the dryer itself. Check the exhaust air for moisture, as that is a better indicator than temperature. Don't forget that towels hold an enormous amount of water, & can be extremely long in drying, especially if not spun enough.
Jul 10, 2007 | Kenmore Elite HE4 Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
42 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
