Question about Hotpoint First Edition FEW12 Front Load Washer
Dru wont turn at all
I have a hotpoint first edition wm51 washing machine and the belt has came off. can someone please tell me how to repair it?
  • 1 more comment
  • sweetchocol8 Dec 22, 2008
    thank you replaced belt and machine worked fine for one wash. now will not turn.seems belt has slpipped off again
    belt is workin fine now. i didnt put it on correctly the first time but have now. thank you for your help
  • woody7405 Jan 03, 2009
    belt snapped dont know how to put it back on can you help me please
  • Hotpoint Master
  • 3,463 Answers
Hi, welcome to Fixya.
The belt has come off for a reason, and there are a few reasons for it to do so.
1- You have overloaded the m/c
2- It is not draining properly.
3- The main drum bearings have gone. Before replacing the belt spin the drum by hand, and if it is noisy or feels rough , then the bearings have gone.
That means calling an engineer.
4- Worn or broken belt.
To refit the belt, do the following.
Remove top cover, and rear panel.
Tilt the m/c forwards, and support it.
Reach inside and slip the belt over the motor pulley, then start feeding the belt round the drum pulley, it is fiddley, but this is the only way, as you get the belt futher round, it will get very tight, so don't trap your fingers, just keep on going.
If it slips off, start again.
Goodluck.
Plz rate my solution.
Thanks, And a merry xmas.
Posted on Dec 22, 2008
  • Barry Coates
    Barry Coates Dec 22, 2008
    Assuming you fitted the belt correctly, and that it was reasonably tight, then if it has come off again, then you have another problem
    Sorry can't provide more info than I already have.
Hotpoint wm51
get a new lock they are cheap
Apr 15, 2014 | Hotpoint First Edition FEW12 Front Load...
The first problem: when the tombour turns I hear a loud noise. Then the tombour does not turn any more when the machine is loaded with garment, but when it is empty, it turns slowly.
It is most likely either the belt or the idlers which the belt wraps around. Open the top (disconnect first) and have someone turn the drum while you watch to see if the belt is slipping.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Feb 25, 2011 | Hotpoint First Edition WMA12 Front Load...
The main wash is cold and the rinse is hot. hotpoint wm51
You have the hoses hooked up incorrectly or the water inlet valve is faulty.
Jan 13, 2011 | Hotpoint Washing Machines
HOTPOINT FIRST EDITION 800 WM51 USER MANUAL?
my hotpoint first edition 800 wm51 wont spin?
Nov 17, 2010 | Washing Machines
I have a Hotpoint washing machine model wm51 and the machine fills with water but stops and will not go into a wash cycle
could be heater fault listen to it if it works it should sound like a kettle warming
up it takes a while
Mar 02, 2010 | Washing Machines
Washer wont start hotpoint first edition 800, WM51
If you have established that the washer is getting power, then I would suspect that the door interlock is the cause of the trouble., try fitting a new one.
Please rate my solution.
Thanks.
Nov 04, 2009 | Hotpoint Dryers
Drive belt came off spindle on Hotpoint First Edition Washing Machine.Have tried to replace but back of machine does not remove, just a small access hole. How can I refit a new belt please??? John Bennett...
Remove rear panel, remove top cover,.tilt washer forwards, get someone to hold it for you, and fit belt round motor pulley first, then start feeding it round drum pulley, easing drum round at same time, it will be tight, so watch you fingers,
Thanks.
Sep 13, 2009 | Hotpoint First Edition FEW12 Front Load...
Hotpoint WM51 Washing Machine keeps tripping the electric
I had this problem; it was the motor arthing out on the body. It took a repair man half an hour to sort and it cost me £35. Hope this helps. Domo.
Jan 24, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Ok that rules out the heating element. There are a number of possible causes so bear with me while i go through them.
Can you open the door? If so leave it open then turn on the machine. Does it trip?
Jan 23, 2009 | Hotpoint First Edition FEW12 Front Load...
Drum wont turn
check for worn carbon brushs in the motor.good luck!
Dec 01, 2007 | Hotpoint First Edition WMA20 Front Load...
Hotpoint First Edition FEW12 Front Load Washer Logo
252 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
Eric Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
