Grundig Tharus plasma TV (110 PW 110-9410 TOP) 4 years old, now shows no picture. No warning. Just turned it off by remote and an hour or two later tried to turn it on and "nothing" just the little green LED. It has always made a muted "click" when it powers on but I notice there is another click now just afterwards at about the time interval usually taken for the image to appear. Like a switch sound. Tried turning it right off at master standby switch and wall socket. No result. Also, once it is in the "on" state with the green LED showing, it will not then respond to the remote, to be turned off again. We have had thunderstorms recently, but I have had the antenna and power unplugged during them. No trikes here though. Any clues? I note that all the internal component boards are LG !! All that money for supposed Grundig superiority. Any clues?
  • 2 more comments
  • John Mobbs Dec 22, 2008
    OK thank you for that suggestion.
    Where would the chassis number be found? Inside?
    I'll undo the 40 or so tiny screws that hold the back panel on, again tomorrow, and look for it.
    I only looked inside carefully to see if I could spot any obvious burnouts. Of course there's not that much componentry visible without further disassembly or the chassis (not my forte).
    Also checked two slow blow fuses that were accessible on clips on a fire protection board top RHS and they show OK on multitester.
    There are no blinking LED - in fact there's blinking nuthin :-)
    Thanks Ray Williams!
    That level of inspection would be beyond me.
    Guns? Are we talking Plasma or CRT?
  • John Mobbs Dec 23, 2008
    OK, spent some time today looking for anything that might be an LG chassis #, as suggested.
    The most prominent number on a paper label in the unit looked to be on the back of the display panel. It bears the following:
    P/N 3315Q-E005A
    H4203B001026
    Model PDP42V5
    Now, much of the circuitry and componentry of the panel rear is hidden by an aluminium panel that itself holds a component board. The whole unit is built around a solid aluminium chassis. It is behind this panel that I can hear the "click" when the unit turns on and then shuts itself off.
    I think I about reached my level of competence, curiosity and safety and I don't think I should disassemble further, even though it's out of warranty and tempting, with all the Phillips head screws accessible to do so. Even if I do see something awry, It will need a tech to do something about it. A user-serviceable fuse block wouldn't be so deep in the unit would it? But at least I haven't shelled out $200 for a tech to take the back off, replace an obviously blown fuse in a 2-minute job and tell me mumbo-jumbo. I think I'm off to a Grundig service tech (if I can find one) now. Thanks to those who attempted at least some level of primary diagnosis. Any late comments also welcome.
    A good general appreciation of the potential fault
  • 199 Answers
Apparently, you were not able to view the subsequent post of Benimur, with the indulgence of the others:
Appreciate your quick postback.
Normally the chassis number would be on a sticker paper on the metal bracket. Most LG chassis number goes to something like "CA-52".
Your post "
no blinking LED" is significant. It is indicative that the power although entering the TV is not reaching the electronics, more specifically the power supply board. Aside from the 2 fuses you indicate, there could possibly be more.
Of course, with fingers crossed, you could try another outlet in the event that a circuit breaker might have been tripped.
Would look forward to your next post on the chassis number. Cheers.
Hope this helps.
Posted on Dec 22, 2008
  • Bernie Role
    Bernie Role Dec 22, 2008
    This of course would require opening the unit, perform voltage measurements,determine faulty component and subsequent part(s) replacement. Further, a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron would be required. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings.Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
    Sergeant:
    Champion:
  • 272 Answers
It sounds very much like the power board. All the components on this board will have to be checked (capasitors etc) and re-solder all the dry joints. This board supplies the power to the guns (red, green and blue) and it is with these three colours that make up the picture on the screen. If you find that the board is faultless, then I would look at the guns to determine if the fault lies there.
  • James Raymond Williams
    James Raymond Williams Dec 23, 2008
    All TV screens have the guns. From CRT to Plasma.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Offhand the second click would indicate that the unit is going into protective mode. This is a result of the built-in diagnostic sensing fault in the system and to prevent further damage, halts the system. Normally, one of the LED lights would be blinking and the number/sequence of the blinks would indicate an error code. The code once deciphered would point to the probable faulty section/component.
Your post that the boards inside are LG is significant. If perhaps you can try to determine the Chassis Number, then we would have a fairly reasonable source of information as to probable faults and course of action.
Good luck and Thank you for using FixYa. Happy Holidays.
  • Louie  Role
    Louie Role Dec 22, 2008
    Your post "no blinking LED" is significant. It is indicative that the power although entering the TV is not reaching the electronics, more specifically the power supply board. Aside from the 2 fuses you indicate, there could possibly be more.
  • Louie  Role
    Louie Role Dec 23, 2008
    Hi again,
    A qualified professional may be to your advantage. PDP42V5 is an LG chassis used by other brands such as Sanyo, Visio, Thomson, TCL among others. This chassis uses DGK-420W power supply board known for a faulty blue capacitor that blows. C19 Value is 1uF 630V, another is C103 10uF/50V. This PSU supplies +5, +65 and +190 VDCs. Other possible faults are the 2 power MOSFETs 32N50Q.
    Should you still have a need for:
    Cheers.
How to restore factory setting of GRUNDIG tv model ST 21- 4410/4 ?
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1200 posts to different brand TVs now. Pull up older posts there.
Nov 12, 2012 | Grundig Televison & Video
Picture is fine for about an hour then goes fuzzy
Hello Townsend, It sounds like a problem called blooming, or you are having a problem with focus control which are signs of a problem in the horizontal and high voltage section of the tv in the case of plasma TV this would be the excitation circuit. I would suggest that you take the set to a TV repair shop to effect repairs.
Sep 12, 2007 | Dell W4201C 42 in. Plasma HDTV
Panasonic tv turned off, red light blinking and now when I turn it on I now have a portion of the screen from top to bottom with a thick black line with no picture
Wow! EXACT same problem I'm having...4 days later! Did you buy your's about a year ago like I did? Coincedence it breaks after 1 year?! AirForceGeo (in Waldorf, MD)
Feb 17, 2010 | Panasonic Viera TH-50PZ80U Plasma TV
Lost picture. When using main power button, the
Tries unplug,replug the tv an hour later might work.But this a temp.fix,must replaced the backlight video board sooner or later.
Dec 22, 2009 | Planar PDP-42BK 42 in. Plasma HDTV
TV wont power on but green light indicates power on
No,it ur backlihght video inverter board is dead,need a new board.
Sep 27, 2009 | Philips 50PFP5332D 50 in. Plasma...
Tuning a Grundig Tele Pilot 750c Television
It might be an old hotel tv. Try this, it worked for me
http://www.tvtuning.co.uk/makes/grundig.htm
basically you hold the i button whilst turning on the tv.
ta
Jan 07, 2009 | Grundig GF70-600 TV
Recent problem with picture
Plasma Tv panel only have a lifetime of 10000 hours. the phosphor inside the panel and the zenon, xenon gas only will last so long . Pretty much like a florescent light bulb.
Apr 10, 2008 | Televison & Video
Picture is snowy/dark
update: Well, we ended up calling the repair man and we had a bad Y-sustain board and also a bad Z-sustain board. According to the guy who fixed it, it was due to over use of the TV and using main power button instead of shutting off through the cable remote. 650.00 later and a few weeks later, we now have a fixed plasma. No real suggestions on how to get more life out of the new boards.
Sep 12, 2007 | Zenith P42W46X 42 in. Plasma EDTV
Televison & Video Logo
186 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
