Question about Apple PowerBook G4 Mac Notebook
Disc drive ejects blank discs...plays dvds
I can't burn anything. When I insert the blank disc and I have tried several different kinds...it ejects the disc and states that it is waiting for a disc to be inserted. It will not recognize the disc inserted. I have tried a variety of programs for burning and the same thing happens. It will play a dvd. I don't have a program disc to try. I can hear the drive spinning the disc before ejecting it.
  • vstoughline Dec 22, 2008
    ok...I tried to put that info in right after but it must have gone some where else...ooops. Here it is:
    I have a MAC Powerbook G4
    The drive is Matshita DVD-R UJ-835E
    The revision is GAND
    It can write to CD -r -rw and DVD -r -rw +r +rw
    it ejects everything but DVD movies. It wont read back up discs or burn them instead it ejects them. I can hear the drive every time I insert the discs a few seconds later it comes out.
    Thank you ; )
  • Sean Cole
    Sean Cole May 11, 2010
    Hi There,
    Damn frustrating isnt it! A few things I need to check before ploughing into a prognosis.
    1. What mac have you got?
    2. What drive is it? (You can check this by going to the Apple symbol in the top left, selecting 'AboutThisMac' then click 'MoreInfo...' and goto to Hardware>DiscBurning. It will tell you the drive model, firmware revision and what it can write to.
    3. Have you got a disc you have burnt (cd or dvd) on another drive that you are able to play in the machine.
    Once you have collated all that we can take it from there.
    All the best
    Sean
    PiDigital
    Sergeant:
  • Apple Expert
  • 250 Answers
Hi Again,
Sorry I didn't get back to you sooner. Work!
You need to let me know what type of PowerBook G4 it is as the instructions for each are different. However, what I will do is give you the links to the appropriate sites and some instructions for them:
  1. First you need to reset the Power Management Unit (PMU). To do this refer to THIS page. A little way down is a heading 'PowerBook and iBook models covered in this document'. Select the model listed in blue below this which will take you lower down the page to the instructions for your model.
  2. After restarting try your drive again. If it doesn't work, try a dvd drive cleaning disc.
  3. If it still doesn't work your drive is Kaput! If you're near Kent in the UK then I can help you out. If not find a local Apple Specialist who can replace the drive for you.
All the best
Sean
Posted on Dec 24, 2008
Insert disk all i get i load then it eject disk
Well it seems that your DVD player is having an issue reading the disc, I guess the first question is what kind of disc are you trying to insert? Is it a burned DVD or is it a movie dvd? This model is not a Blu Ray so if you are trying to use a Blu Ray disc then it will not read it. If you are trying to read a burned disc from someone then more then likely the disc was not finalized and is unable to recognize the disc, because the finalization process is where all the the information is written about what kind of disc it is and the format, codecs, etc. OR maybe the laser is dirty or the DVD player has kicked the bucket. Finally, the product DESC says it can read DVD-RAM, DVD-RW, DVD-R, DVD+RW, DVD+R, VHS formats, but I have found that some DVD units do not like certain brands of Blank DVDs. I hope this offers some ideas for you and good luck!
Oct 29, 2013 | Samsung DVD-VR357
Cd's appear to burn but do not play
change your burn software and file formats /if there are music files/
Apr 24, 2012 | Dell (1G055) CD-RW/DVD-ROM (Combo) Burner
The drive plays DVDs and can read doc files, but
This problem is normal and exists with many CD/DVD drives.
On some of the drives, if you put in blank discs and try to open the disc in My Computer or Windows Explorer, Windows displays no contents or a blank disc. Whereas on other drives, you get the error message that you mentioned about incorrect function.
What software are you using to burn CDs or DVDs? Are you able to burn CDs but not DVDs or you can't burn both the discs? Did you try a CDs with a different make/manufacturer? Some drives refuse on some disc makes. Try another disc and another writing speed, or try the lowest writing speed available with your software.
Hope that helps,
Regards,
Raspal
Mar 22, 2010 | ASUS SDRW-08D1S-U USB 2.0 Slim External...
Nec dvd+-rw nd-6650a stop burning dvds
It's time to replace the defective (and probably warranty-expired) unit.
If your computer is a notebook, not a desktop, it's best to take the computer to a qualified technician, to disassemble your computer, and replace the drive.
Jan 02, 2010 | NEC ND-6650A DVD RW Dual Layer Burner
Loading some DVD's
I have seen this same thing on a laptop. DVD drives use two lasers. One for CD and one for DVD. As you noted CDs are just fine and so is that laser. Although I believe the DVD laser is intermittent. And it will work with some DVDs and not others. Yes I have seen this before. What will probably happen a few months down the road is it will stop reading all DVDs.
It isn't economical to replace the failing laser. It is far cheaper to just replace the whole DVD drive. Lasers are like light bulbs. Some seem to last forever and some seems to burn out right away. Generic DVD replacements will generally work, although the face plate might not fit.
Another option is to get an external DVD that plugs into the USB port. And those Slimline models are really small (same size as laptop CD/DVD drives) and you can use them on other computers too.
Jan 29, 2009 | Computers & Internet
Burning problem
Try different brand. Your Drive is a sensitive type and it only accepts some DVD-R brands. Also try DVD-RW disc. I had the same problem but not specifically the exact problem. My drive is cd writer only. Same problem, I just used diff CD-R brand like Imation and Philips and the burning works like a charm.
Jul 26, 2008 | Lite On LITE-ON SOHC-5236V COMBO BK OEM...
Dvd rom problems with my macbook
Does the computer immediately return the discs after they're inserted or do you have to manually eject them? If it's trying to read the discs then there could be a problem with the type of disc. However if it just ejects the disc immediately, there could be a recognition problem. So, if your computer doesn't recognize that a disc is in the drive, you can check several things. 1. Check to see that the computer actually reads DVDs. To do this, open the System Profiler in the Utilities folder. Click on ATA/Devices and Volumes/Disc Burning. Those are three different options but each will tell you if the drive actually does run DVDs. If it shows DVDRW or DVD, but if it only shows CD or CD-RW, then it won't play a DVD. 2. If it shows that it accepts DVDs through the System Profiler, then you'll need to check to see if the actual drive is attached. You can open your computer through the battery with a screw driver. Once open, you'll need to check the connecting cable to the drive. If it's attached properly/securely, you may need to take it to a technician. The drive me be malfunctioning and need professional repair.
Feb 19, 2008 | Apple MacBook Pro Laptop Computer with...
Phillips DVDR3320V 'disc unknown' error
Hey there,
Have you tryed different types of DVDs. You might need to buy DVDs that say DVD RW.
Jan 27, 2008 | Televison & Video
Apple PowerBook G4 Mac Notebook Logo
1,595 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
