Question about Microsoft Visual Studio .NET Professional 2003 for PC
How to increase application memory
Hi i want to increase the physical or virtual memory of the .net application. How to do it in vb.net
    Problem Solver:
  • 10 Answers
Hello srinivasbn,
In Visual Basic you don't have to define or increase memory.
It goes on the fly.
In a module you can declare the variabelen you use in your program or declare them in the load sub.
I hope this is usefull for you.
Kind regards Fred.
Posted on Dec 24, 2008
When using internet sys runs very slow i'ts new normal prgrams installed pop up says to increase memory how
Does it specify if it's PHYSICAL MEMORY or VIRTUAL MEMORY?
If it was virtual memory, which is normal to receive Windows notifications about when running low, Windows would ask if you would like it to fix it for you; it would run its course in the background for a bit & ask for a restart.
If it asks to increase physical memory, then there's probably a program installed & your computer does not meet the memory requirements of that application; Although if it's really new and you have not added any new programs, there's a possibility that one (or more, if applicable) memory modules may not be working. they could either be busted or loosely seated. Yes, this DOES happen for computers out of the box.
Memory modules can be purchased from computer/electronics or select office supplies shops. You'll just have to find out what type of memory you have, how much is currently installed, & how much more the computer can support.
It's not as complicated as it sounds. Just click here to download & install the latest version of CPU-Z.After installation, just run the program & click on the Mainboard, Memory & SPD tabs, as seen below
This will help figure out whit kind of memory modules & how much of it will have to be purchased.
Aug 12, 2011 | Computers & Internet
Tip
Virtual Memory too low Warning Trouble in win xp and vista
When there is less physical memory than needed, then some virtual memory (virtual RAM) is created on the disk. When there is a limit set to the size of virtual memory usage and there is not enough of it present there is a warning that frequently comes "Virtual Memory too low". Solution 1 : This problem occurs when physical RAM + Virtual RAM (usually created on hard disk) together are not sufficient to take care of the currently needed RAM size, or this situation is about to arise. This usually happens when some fixed upper limit for Virtual Memory has been set. To solve this problem, you can either upgrade you physical RAM on your computer (recommended), or you can set the Virtual Memory to system managed size or you can do both. Setting Virtual Memory to system managed size means windows will set it to higher size whenever needed automatically,for this, <br /> Right click on My computer --&gt; goto properties, goto advanced tab, click on performance settings, now click on advanced, now click on advanced, now click on change button for Virtual memory. <br /> On this screen select the System managed size, press OK. After this re-start your computer. This will solve the virtual memory too low problem. Solution 2: Recommended solution is to upgrade your physical memory (RAM) according to requirements of the kind of applications that you run on your computer. If you upgrade RAM or not, the following procedure will help prevent this warning by increasing the virtual memory limit. <br /> Right click on My computer icon and click properties. <br /> This will show system properties window. Click on a advanced tab and click on the settings button under heading performance. This will open performance options window. Click on advanced tab and click on change button under heading virtual memory. Check if the space available is set to some custom value or double the RAM size ? If it is not double the RAM memory size , then select the size option set the virtual memory size double the RAM Size and press set button and press OK button. Restart the computer
on Apr 04, 2011 | Computers & Internet
Tip
Increase Physical memory of the system. Increasing Physical memory will increase...
Increasing Physical memory will increase the performance of the system.
1. Right click My Computer - Select Properties.
2. In property window Click on Advance tab --- Performance -- Settings.
3. In Performance Options window -----> Virtual Memory option Click Change button.
4. In Virtual memory window --- Select C drive --- Click on custom Size.
5. Change initial size to 2000MB & Maximum size to 4000MB -- Click on Set button.
6. Click OK and close all window. Restart system.
Regards
Achalesh Prem P
Vote for me
on Mar 05, 2010 | Computers & Internet
I was on the internet the other night an a popup said that my memory was low so what should i do an its really slow...
If too many applications are running in the background memory is reduced. Verify that you let Windows manage the paging memory.
For WINXP
Rigt click My computer on desktop.
Click Properties
Advanced Tab Click on Performance Settings.
Under Visual effects you may ask OS to adjust for best performance Under Tab Advanced make sure that Processor scheduling and Memory usage are set for Programs.
Verify on same tab that virtual memory is about equal to physical memory (or just let windows manage it)
Hope it helps
Sep 13, 2009 | HP Pavilion MX70 17" CRT Monitor
Virtual memory is low computer is very slow
hello frnd, you can increse your virtual memory manually...
1.go to properties of my computer
2.go to advance tab...
3. there is option to change virtual memory.
4.click on it and change virtual memory accordingly..
hope this will help you
Jun 30, 2009 | Dell Dimension 2400 PC Desktop
Upgrade memory for Compaq Presario R3000 PC Notebook
What OS are you running? 768 should be enough to run XP and keep you from getting that error message. On laptops their are normally just 2 slots for ram, so you would need to replace the 256 with the 512, which would bring you up to a gig of ram. Do you know if your computer has any spyware/adware on it? Sometimes malware can take up all your memory and generate just such an error. Do you know how many processes are running when you first login? Thank you.
Apr 10, 2009 | Compaq Presario R3000 Notebook
Low virtual memory
You have to increase the Virtual memory.
Hope This Helps!!!  Please Don't Forget to Rate my Response!!! Thanks!!!
PREM
Mar 04, 2009 | Dell Inspiron 1300 Notebook
I need to increase virtual memory
I don't wish to sound rude but if you don't know how to do this, you prolly should just let windows continue managing it. A few wrong keystrokes can have major repurcussions
Jul 15, 2008 | Computers & Internet
FREEZE
this happens if the rams are of different frequencies have a check with the both the ram frequency ...
if they are different then remove 1 ram ....
& try increasing the virtual memory in the OS ...
if you are using the windows xp .. then to increase the virtual memory just go to
control panel >system>advanced>advanced>virtual memory settings>increase the virtual memory for the drive in which the os is installed ....
increase nearly to the double of the ram memory you use ....
this solves your problem ..
any doubts you can reply me
i am always here to assist you
thank you
bye .....
dnt forget to rate the solution ...
Jun 22, 2008 | MSI KM4M-L Motherboard
Add memory to HP/Compaq nc6000?
Yes you should increase the memory. XP runs suitably well at 512mb. At 1GIB it blazes.
The memory meter is pegged because it is having to use the Harddrive as ram (Swapfile) which is 1000x slower than RAM.
XP with nothing on it, straight from the factory will run with 256, but after 3-6 months of use, and adding applications it will get progressively slower.
Mar 01, 2008 | Computers & Internet
Microsoft Visual Studio .NET Professional 2003 for PC Logo
445 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
