Question about Tech Solution TS-4500 Shredder
My shredder keeps running and won't stop in on/auto mode
I have a Tech Solutions TS4500 shredder and lately when I shred something it keeps running. I have to unplug it to mske it stop. I opened up the shredder part and cannot see anything stuck in the teeth. I spent about an hour trying to clean out paper parts from the teeth. I have shredded some papers with labels attached (sticky) and do see very small parts of label attached to the teeth. I tried to remove them all to the best of my ability. I hold the shredder up to the window and can't see anything blocking the teeth. Is there a reset or something? Can you help me figure out why this thing won't stop running? Thanks much.
  • 3 more comments
  • Anonymous Mar 12, 2014
  • Anonymous Mar 14, 2014
    MAIN GEAR TO SHRED ROLLERS ,TEETH BROKEN
  • Anonymous Mar 20, 2014
    teeth do not move but there is a motor noise same noise forward and reverse
  • Anonymous Mar 22, 2014
    model spl-txc122a worked fine and then jammed. after cleaning all paper out of teeth the shredder will not turn on.
  • Anonymous Mar 23, 2014
    shredder has stopped shredding
Does the shredder have the electronic eye to sense paper? Sometimes dust will collect on the sensor causing it to keep running.
Posted on Apr 16, 2007
SOURCE:
My Tech Solutions TS4500 paper shredder will shred approximately 1/2 page of one or several sheets of paper. But at that point it chokes and will not shred any further. It will back the unshred portion...
My experience has been that when a shredder chokes it usually is trying to tell you the bin is full but a cross-cut shredder is less susceptible. I do have a heavy duty cross-cut shredder that gets rather wonky when suffering from indigestion. Check whether the amount of bin content is affecting yours.
Jul 14, 2017 | Winsource Tech Solutions TS-4500 Cross-Cut...
Shredder won't turn off
sounds like insertion sensor is dirty or defective,
disable auto reverse, or clean/replace the "eye"
Apr 01, 2010 | Office Equipment & Supplies
UNPLUG THE SHREDDER.
If this model has electronic eyes (optics) to control the auto-start/stop function and you oil the cutters, chances are the optics are contaminated with shredder oil. Take a cotton swab with a little alchohol and clean and dry the optics.
If you removed the top cover, it is a possibility that you disconnected the wires from the PC Board.
Mar 01, 2009 | Royal VF1012mx Shredder
Tech Solutions shredder
It sounds like you may have a gear with a broken tooth you should contact the manufacturer to get more info. Usually when this is the case it will shred good for only a few revolutions and then reversing backs the gear up to a position that allows it to turn the cutters until it once again reaches the area where tooth is missing.
Mar 11, 2008 | Winsource Tech Solutions TS-4500 Cross-Cut...
Shredder Problem
Replace the paper sensor switch
May 27, 2007 | Tech Solution TS-4500 Shredder
TS4500 Shredder
there is one screw under the s/n sticker
May 08, 2007 | Tech Solution TS-4500 Shredder
Tech Solution TS-4500 Shredder Logo
1,480 people viewed this question
Top Tech Solution Office Equipment & Supplies Experts
Damen Wong
Damen Wong
Steve Allison
Steve Allison
Jim Keysor
Are you a Tech Solution Office Equipment and Supply Expert? Answer questions, earn points and help others
