Question about Denon DVDA1 DVD Player
Denon Link works erractically !
I have the Denon A1SR - A1 Combo. The Denon Link passes the signal for the Mark Knopfler Shangri-La DVD Audio at times and at times refuses to do so. At the same time if I insert a different dvd audio disc it works ok ! So the wire should be technially ok.
Also, I would like to know if I can replace the Denon Link wire with a high end CAT 6 Cable ?
5 Suggested Answers
SOURCE: No Audio/Video output with DVDs
lost dvd picture and menu screen through denon av2307 composite conection
Posted on Jun 11, 2008
  • 70 Answers
SOURCE: Denon dvd player freezes in
sounds like its stoping during layer switch, if the player is old its needs to be cleaned. its best to clean it once every 20hrs or so. if you do not have a disk cleaner you should go buy one first. if the player is new return it and get the best dvd player you can buy for any amount the toshiba xde. this player is phenomenal, the best you will be amazed. no i dont work for toshiba but ever since they started making hd dvd players(i know they stopped)there players have become the best. trust me if you dont think so just return it. no harm done. if you want a blu-ray get ps3 I dont like them either but i have to admit after buying (for movies only)my third blu-ray player it is by far the best one. almost as good as the toshiba on standard dvd playback but not quite. good luck.
Posted on Oct 02, 2008
  • 4 Answers
SOURCE: Denon 2910 CD player malfunctions
you could try this http://www.fixya.com/support/t244156-denon_2910_cd_player_malfunctions or clean the lens
Posted on Jun 14, 2009
SOURCE: I just doesn't load/read CD's.
I had the same problems with my four year Denon DVD-3910 and the only solution to it was to replace the laser unit with a new one.
There are some repair service on EBay that offer new laser units for only about 50 € and are also willing to change the laser unit for an extra charge of just 30 €.
After this replacement your Denon DVD-3910 will work fine again.
Posted on Jul 26, 2009
Cant get ps4 to pass signal thru avr to projector.
Possible PS4 HDMI Handshake Output Problem - AVS Forum ' Home ...
www.avsforum.com/.../1508885-possible-ps4-hdmi-handshake-output-p...
Dec 31, 2013 - 20 posts - ‎15 authors
Nothing seems to make the PS4 pass a signal through the AVR. .... can output videothrough the Integra, why can't Sony get the HDMI working? PS4 - 3D Playback Not Working :-(
Aug 12, 2014
Run HDMI Directly to TV or A/V Receiver?
Dec 19, 2013
AV receiver problem with Xbox One
Nov 23, 2013
Solution to HDMI @ 1080p receiver/display HDCP ...
Dec 14, 2008
More results from www.avsforum.com
My Denon AVR-X4000 won't output video signal from attached HDMI ...
forum.blu-ray.com > Audio > Receivers
Dec 21, 2015 | Denon AVR-3311CI 7.2 Channel Networking...
No enciende mi denon 1200
HOLA TENGO UN DENON 1200 LO ACTUALICE Y NO PRENDE NI HACE NADA XFA QUIEN PEDE AYUDARME
Nov 07, 2012 | Denon DN-S1200
SYSTEM ERROR EN LA PANTALLA
hola tengo un denon dns 1200 y sale en la pantalla systen error
Apr 19, 2012 | Denon DN-S1200
Configuration settings PIN code
Try Hard Reset your Phone
or
Here's a hints on how to repair or fix Nokia 5800 XpressMusic Digi Mic Knopfler problem issues.
A guide picture below which I included an schematic diagram shows each every components and line paths for quick test and check up procedures.
Digi Mic Knopfler Pin configuration:
1. L/R - microphone's left and right audio signals groundings
2. CLK - Audio Clock data
3. Data - Digital Microphone data
4. VDD - Power supply voltage
http://2.bp.blogspot.com/_8JZhVVmpICU/TBnMEY2FYyI/AAAAAAAAAiI/KWb0ERKLIPE/s400/digi+mic+knopfler+schematic.jpg
Locate and trace each and every components, line paths and corresponding connection as shown on a picture. The red highlighted components and line paths is for the power supply voltage which came from Power management IC (AVILMAS) Vsim2- approximately 2-3 volts.
Test and check this components and track the supply voltage from C220 to C2170 then through the digi mic knopfler pin 4.
http://4.bp.blogspot.com/_8JZhVVmpICU/TBnNuXjiK5I/AAAAAAAAAiM/zRyjq5oSGEA/s400/nokia+5800+xpressmusic+digi+mic+knopfler.jpg
The pink highlighted components and line paths is for Audio Clock data signal, which is came from the Audio Codec IC (Avilmas) then flow across R2201 and R2170 (valued 100ohms each) then to the Digi mic knopfler pin number 2. Check also the C2173 valued 22p Clock filter capacitor for possible damaged.
I included step by step procedures on the images like as follows:
* Check each components and line paths.
* Replace if found open or shorted
* Jumper the line paths if found open or cut
* Check or replace the digi mic knopfler for a quickest step might as possible.
http://4.bp.blogspot.com/_8JZhVVmpICU/TBnUknz7xAI/AAAAAAAAAiQ/McXux--YsDc/s320/nokia+5800+xpressmusic+digi+mic+knopfler+repair+gu ides.jpg
The microphone's digital data signals has also a line paths connected to the front side of the Printed circuit board, check and trace also this line paths which is connected to digi mic knopfler's pin 4
Feb 17, 2011 | Nokia 5800 XpressMusic Smartphone
I have a Denon AVR 790 for about 8 months now. Hooked up a combo DVD VCR player using the red/yello/white cables. It worked fine for about 6 months. Now I cannot get the DVD or VCR to play. I get sound,...
If dvd combo player is only video source connected with Denon AVR 790 then unplug yellow video wire from Denon and plug it directly in TV input, now video signal will go directly to tv and sound will come from Denon AVR 790 speakers during dvd playback.
This is simple bypass that wont effect surround sound of dvd playback.
Let me know if you have additional question.
Thanks.
Oct 20, 2010 | Denon Audio Players & Recorders
Hello DENON AVC-A1SR servicing manual
try
www.servicemanuals.net
Good folks
Jan 20, 2010 | Audio Players & Recorders
Denon Receiver AVR 1602 not playing Dolby Digital w/ Samsung BD
Dolby signals are passed via either an RF cable or optical link. Both the receiver and player need to have these switched on and that they are passing the correct signals. You clearly found the correct setting for the TV sound link. Now you just have to find the one for the DVD player.
Jun 02, 2017 | Denon AVR-3805 Receiver
Mistracking on dvd player
Hello!
It turns out there is a problem using hdmi cables with integrated amplifiers Denon dvd players (the 1940 series) - the hdmi cable processes the visual signal before the audio signal. Therefore there is what appears to be a lip syncing problem because there is a short 'time delay' between the visual and audio signals. I would advise anyone to simply use an AV reciever as they incorporate time delay technology so the visual and audio signals are in perfect sync. Luckily, Richer Sounds, where I bought the intergrated amp gave me a full refund, no quibbles or hassle. I would like to add I am unsure if the problem lies with just the Denon 1940 hdmi dvd players and intergrated amps or ALL hdmi players. Also, I was trying to achieve a simple 2 speaker set up with the amp.
The forum on What Hi-Fi document this problem with much better clarity and technical explanation that my understanding of the problem. However, the lesson learned is, if you want any speaker set up with your dvd player, use a dedicated AV reciever.
Best Regards, Graeme Young.
May 17, 2009 | Denon DVD-1940CI DVD Player
No picture
the reason you can't get a signal is the denon 1708 will not pass the 1080p, switch the DVD output res. to 1080i or 720p and it will work
dennis
Feb 02, 2009 | Denon AVR-1708 Receiver
Connecting new tv to DRA-685
you can use the headphone jack just get an adaptor to change from the headphone type to RCA type. adjust the volume of the tv to 3/4 of the way to give line level to the stereo, use an aux input on the stereo. if you had a suround sound dolby digital / DTS receiver then use the digital coax out to that type of receiver, but since you have an anolog 2 channel receiver you must use the only anolog source (the headphone).
May 21, 2008 | Denon DRA-685 Receiver
Denon DVDA1 DVD Player Logo
43 people viewed this question
Top Denon Televison & Video Experts
 Grubhead
Grubhead
Are you a Denon Televison and Video Expert? Answer questions, earn points and help others
