Question about Canon PIXMA MP210 Photo All-In-One Printer
Hp officejet l7780 rear access panel is open it not! need to reset
  • grandeeee2 Jan 07, 2009
    Rear Access panel is open - but it is not - have reset - unplugged and more - cannot print!
  • Canon Master
  • 419 Answers
The L7780 usually has a duplexer which has a rear access panel on it but this is NOT the panel that the printer detects as open.
In the L7780 anything that is connected/slotted into the rear slot/hole is considered to be the rear access panel. This means the duplexer (which is standard on the L7780) is seen as the "rear access panel".
Stand looking at the back of the printer
Inside the slot on the right side you will see a green circuit board with four metal contacts on it. Check that these are not soiled or damaged in any way. Clean if necessary.
On the right side of the dupler you will see only TWO metal pins that spring out and should make contact with two of the contact points. It's possible that these are damaged and/or broken. You may need to free, re-bend, etc... these CAREFULLY so that they stick out properly. Ultimately the goal is to ensure that the metal pins touch the appropriate contacts on the circuit board.
If all else fails, check your warranty and contact HP to see if they can provide a replacement duplexer. If the circuit board itself (in the printer) is damaged though you may need to return the printer itself.
Hope that helps.
Posted on Jan 24, 2009
  • knicoledncr
    knicoledncr Jul 14, 2013
    THANK YOU THANK YOU THANK YOU MARTIN
2 Suggested Answers
edwinmeyer
  • 57 Answers
SOURCE: Error: rear access panel open, but it's not and now it won't print. Help!
Check VERY closely edges, rollers etc, you likely have a small shard of paper mucking up the works.
Please rate FixYa Experts assistance, whether your rating is good or bad helps The experts immensely.
Thank you for taking the time.
Posted on May 26, 2009
Partial print on incoming fax
Check your incoming line and settings or try to reinstall the drivers. Also, check the user manual for HP Officejet Pro L7780
Jun 25, 2013 | HP Officejet Pro L7780 All-In-One InkJet...
I installed hp officejet pro l7780 but failed to calibrate.
Partial reset the printer
  • Remove the power cable from back side of the printer while its ON.
  • Press and hold "#" and "3" button, while holding them both insert the power cable and release the button after 10 seconds.
  • If printer turns OFF, press power button to turn it ON.
May 26, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
Won't recognize black cartridge on hp officejet pro l7780
Ok what you need to do is powerdown the printer the pull all ink out of the printer power it on without in then power it down again and replace the cartridges. If this doesnt work go into the control panels and select the color of the ink as only B&W and print a test page
Oct 18, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
May 26, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Rear access panel open
open the rear panel, check all path is clear. close the rear panel, mkae sure that the sides of the rea panel is locked in place. there is micro switch that detect the door panel. if the door is close correctly the micro switch os actived then you will get the error.
Jan 05, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Need to reset the number of rings before fax pickup on 2 hp offi
default ring is 5.
if need to change the ring, then you will be in maual answer mode.
better choice is to change the ring on the phone and the answer machine.
Dec 31, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
Canon PIXMA MP210 Photo All-In-One Printer Logo
887 people viewed this question
old marine
old marine
