Question about Vizio P2 42 in. HD-Ready Plasma Television
Screen Problem My problem is I have a Vizio 42" HDTV. What is happening is when i watch TV or dvd, i get green flashes on the screen. Its not just in one area. Its all over. I just got this TV. If there a setting that i am missing that will fix this problem? Thanks
Thanks for the help. I have Vizio come put and replace the mainboard. That is what they said the problem is. They came out and the TV is still doing it. Vizio is replacing the TV with a new one. Thanks again for the suggestion
Posted on Apr 16, 2007
    Champion:
  • 217 Answers
This is not a setting problem, either the digital board is going bad or the analog board, could be a loose LVDS cable, that hooks to the power board and the logic board, if you take the back off and hook it back up to the source, then get a plastic probe, do not use any thing metal, you will get shocked or damage the boards inside, take the plastic probe and while the tv is playing move around some cable and see if the picture gets the same problem, if so make sure all the cables are securely seated
SOURCE:
Snow on screen with no picture.loud noise on audio
42" Vizio TV flickering strobing easy way to repair VW42L ...
? 2:49
https://www.youtube.com/watch?v=Qba7_YHnXwM
Dec 2, 2013 - Uploaded by ozzysslayer
42" Vizio TV flickering strobing easy way to repair VW42L HDTV10A LCD TV ... EASY How to Fix Samsung LCD TV Flashing Flickering Screen!Missing: vp422hdtv10a ‎snow
Vizio Replacement Boards - ecoustics.com
www.ecoustics.com > ... > Plasma & LCD TV Forum
Apr 15, 2009 - I have a vizio p42hdtv10A that just went into a black screen. .... I have a Vizio VP422 HDTV10A that will not stay on or show a picture. I removed ... Vizio vp422 hdtv10a
Dec 20, 2011
May 13, 2011
More results from www.ecoustics.com
Dec 30, 2015 | Vizio VP422HDTV10A 42 inch 720p LCD HDTV
My vizio 42 inch, the green light at the bottom comes on but the tv screen wont and every 21 seconds the turns off then come back on over and over every 21 seconds.
I don't know if your refresh rate on your TV is adjustable or the signal being fed is inadequate. What connection are you using with the TV? If it's HDMI, make sure the cables are HDCP-certified. Otherwise this will always happen. If it is simply your TV, are environmental variables (dust, cold, heat, etc.) causing the TV to malfunction? Give it room to breathe and avoid cases without holes for the TV to breathe. TVs don't operate properly when they are stressed out.
Sep 23, 2013 | Vizio VW42LF 42 in. LCD HDTV
Vizio LCD dark screen and picture is flickering flashing
Your back light inverter is provably bad.
You can get get parts for this tv at www.interliquidparts.com
Nov 25, 2011 | Vizio 42 in. LCD TV
Can you connect a 2 yr old 42 in vizio to your computer to watch shows ????????// what type of cord is used and who sells them?/ Best buy , hh gregg, sam waltons house line opps wall mart / sams ???
Easiest will be the VGA cable (15 pins on each end), you will also have to set the PC to the native resolution of your TV otherwise you will get the message on the screen saying "format not supported".
You will also need an audio cable, it has male mini stereo phone plug at each end, one end will go into the green audio out athe PC sound card, the other end will go into TV PC audio line input (green jack).
Best Buy should have them.
You should down load the user manual and read all about your TV.
http://vizio.com/documents/downloads/hdtv/GV42LF/Manual.pdf
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Aug 06, 2010 | Vizio GV42L 42 in. LCD Television
My Vizio LCD TV screen fades to dark. Sound stays on.
I w having this same issue when watching a Blu-Ray disc. I found it to be dependent upon what picture mode the TV was set to. By this I mean certain picture modes would cause the TV to dim during dark scenes of a movie. Changing the picture mode helped a lot.
Feb 28, 2010 | Vizio VW42LF 42 in. LCD HDTV
Vertical purple lines appear when watching tv but not dvd
You unit should be under warranty. contact the manufacture for the nearest authorized servicer.
Jun 26, 2009 | LG 42LC2D 42 in. LCD HDTV
Vizio P50HDM No Picture/No Sound
replace the sustainer boards should correct this problem. New sustainer boards may cause red and green pixilation. If this happen, replace control board and TV is as good as new.
Apr 05, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Vertical lines on screen
1. Frist on the BURN MODE.
2. Check whether same
Vertical lines on screen ?? 3. If yes ..?
4. Then change the LOGIC BOARD or PDP
Jan 11, 2009 | Hitachi 42HDS69 42 in. Plasma Television
Vizio P2 42 in. HDTV-Ready Plasma
Search Google "Screen Burn-In."
Mainly Plasma screens are affected by it.
Sep 20, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
One green vertical line in HDTV Vizio 42
Try changing the H/V position in the TV Set Up menu. You can adjust the horizontal and vertical position of the screen and move it enough that the green line disappears from the screen.
May 18, 2008 | Televison & Video
Vizio P2 42 in. HD-Ready Plasma Television Logo
132 people viewed this question
Top Vizio Televison & Video Experts
Tony Nguyen
Tony Nguyen
Steve Allison
Steve Allison
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
