Question about Acer TravelMate 2355 Notebook
On my dell 1525 laptop number three key is not working n its keep typing in my search box like three three three...............in number if u kno3w what i mean
  • nickpower
    nickpower May 11, 2010
    make sure the key isn't stuck down, you may have to replace your keyboard.
    Problem Solver:
  • 10 Answers
You have to change the keyboard
Posted on Aug 13, 2009
How do I get rid of doctotext ads?
Try to clear your temp files. press the windows key+r then type temp. Delete everything thats deleteable on that folder. Close the folder and then press the window key + letter R again. type %temp% on the run box and delete everything deletable there as well. run an anti malware program such as malwarebytes.
Apr 02, 2014 | Dell Inspiron 1525 Laptop
I want to restore my dell inspiron 1525 laptop back to factory settings but when i press f8 , after i start my computer there is no
RTM - Read The Manual
Get onlineand got to www.google.com In the google search box type: "DellSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Look for Manuals and search them for Factory Restore.
May 12, 2012 | Dell Inspiron 1525 Notebook
I have a Dell inspiron 1525 with windows 7 installed but it has dodgy mouse keys which click away constantly making it hard to even type this paragraph. Is there anyway I can either decrease the...
Hi hope this finds you well, go to control panel in the top right corner in the search box type mouse and you should get a several mouse option click on the change mouse settings, you will get another window with various mouse options then go to the pointer options tap, change the motion speed and hopefully that should solve your problem. good luck.
Jul 02, 2011 | Dell Inspiron 1525 Laptop
We have a Dell inspiron 1525. After it warms up the number 6 is entered continually in every window the requires typing. reboot doesnt work because we can't enter the password. If we put the laptop in...
plug an external keyboard in and see if that resolves it if it doesnt then some foriegn substance is under your 6 key and causing it to be pressed down, remove what it is under the key and it should be ok
Apr 10, 2011 | Dell Inspiron 1525 Notebook
My dell inspiron 1525 often slows down
To speed up the computer we need to follow these steps this will run your computer operation much faster.
Click the start menu button and select run or search command box type in %temp% and then press enter you will see a box with lots of files single click on one of the file or folder then press the control + A key it will be all selected or highlighted, now you can press shift + delete key on the keyboard this will remove all temp files which is not necessary for the computer.
Type in the run or search box prefetch hit enter and follow the same process as the first one after that open control panel and select add/remove program it will show all the installed softwares in xp and in vista/win7 open programs and features icon once you see the unwanted list of installed programs highlight and remove it one by one, you need to identify the once which you do not require and then remove it by simply highlighting and hitting the change/remove button.
Run msconfig in the run box or the search box it will open a window click on the startup tab and deselect the one's which you dont require while system boots.
Nov 14, 2010 | Dell Inspiron 1525 Notebook
Dell Inspiron 1525 - No wired or wireless network
I suspect the Vodafone wireless adapter software is controlling the Dell wireless adapter. Start> in the search box type CMD
  • Reset WINSOCK by typing netsh winsock reset catalog
  • Reset IPv4 TCP/IP by typing netsh int ipv4 reset reset.log
  • Reset IPv6 TCP/IP by typing netsh int ipv6 reset reset.log
Next make sure the vodafone applcation is not running
Check you are getting a ip from the router by Start> in the search box type CMD
  • ipconfig /all
This will return a list of numbers - what you are looking for is a IP number for your wireless connection
A very useful tool to use for wireless issues is xirrus, http://www.xirrus.com/library/wifitools.php If you can copy the program onto the PC thats not working and install and run, this test if your adapter is working and also will display all the networks broadcasting in your area. Which will prove the hardware works.
Apr 03, 2010 | Dell Inspiron 1525 Laptop
Comunication software component are missing keeps
For most of my customers, this software is completely useless. If this is the case for you, I would recommend removing it from the list of startup items.
To do this:
1. on xp, click start, run, and type msconfig
on vista or windows 7, click start and type msconfig in the search box, clicking alow when the UAC window appears.
2. click on the startup tab
3. Locate the Dell communication program on the list (or all dell programs as I normally do) and uncheck the box
4. click Apply, then click done. The computer will prompt for restart.
5. After restarting on XP, a window will appear. Click the check box and click close.
Best of luck;
//halfs
Feb 16, 2010 | Dell Inspiron 1525 Laptop
My dell inspiron 1525 webcam wont work with yahoo messenger
This is happening because the Dell webcam central is accessing the webcam at the same time as yahoo messenger. Click on start and click on Run(XP), Type MSCONFIG in start search (Vista) and you'll get the system configuration utility. Open it and go to the startup tab. Uncheck anything related to Dell webcam. Click on Apply and OK and restart the computer. If yahoo messenger shows a black screen uninstall Yahoo messenger and reinstall with the more recent version.
Aug 09, 2009 | Dell Inspiron 1525 Laptop Jet Black
Dell Inspiron 1525 #keys "5" and "6" unresponsive. All others respond.
Its a keypad problem. For solving this problem, simply take out these keys out by pulling them outward and then clean the socket-type granule below it. And then again replace the keys to their location. Surely these keys will start working.
Rate this solution if it was helpful to you...
With Regards,
Shyny
Jun 20, 2009 | Dell Inspiron 1525 Laptop
Certain letters are not working
When keys go faulty the entire keypad needs replacing. You can't replace individual keys. I would suggest contacting dell and ordering a new keyboard, it's an easy fix: http://www.essortment.com/articles/install-replacement-keyboard-dell-inspiron_102151.htm
If you need to purchase one, I did locate: http://yallstore.com/laptop-keyboard-replacement-for-dell-inspiron-1525-p-4228.html For $16
May 23, 2009 | Computers & Internet
Acer TravelMate 2355 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
